  • Crimznn
  • Crimznn
23 Aug 2024 17:37 - 23 Aug 2024 19:27
I need to downgrade from 2.9.2 to 2.5.0 to run our old configs/ hal files
Category: Installing LinuxCNC
where can I get 2.5.0 after installing that image I have another older pc with it on there I just don't know the process to transfer it, I'll try that image with 2.7 and see if that works better
not finding the Linuxcnc in either they just seem like disk images no linuxcnc packages embedded if anyone has or knows a repository with the older versions please link them below
  • slowpoke
  • slowpoke
23 Aug 2024 17:36
E-Stop latch question was created by slowpoke
Category: HAL
I have an E-Stop latch configured in io.hal, it looks like the image below with the exception of the OR gate.It is working as it should.
I want to be able to reset to the OK state with an external push button (assume the external E-stop is not in the stop position)
My understanding is that all three inputs on the left need to be satisfied:
The ok-in pin seems to require a logic 1 (not just a positive edge)
The reset pin appears to just need a positive edge to latch the OK
Hence the addition of the proposed OR gate to poke the reset pin.
That still leaves the ok-in. From observation iocontrol.0.user-enable-out latches on and off when you click on the red X estop button in the axis GUI, so if I click on that once when I start Axis (to latch it high),  I can then reset any subsequent e-stops with my external button.
I suppose I could add yet another latch that gets set with my external button and then OR that latch output with iocontrol.0.user-enable-out and drive the ok-in pin with that 2nd OR gate.
I'm not sure if anything else causes iocontrol.0.user-enable-out to toggle low (other than clicking on the red X)? perhaps some other internal logic can toggle this low and I would be defeating that e-stop path if I latch the ok-in pin high.
Makes me wonder if someone else has come up with a more elegant solution to an external e-stop reset button?
23 Aug 2024 17:31
2.5 will most probably not run on new Linux distros, mostly because of huge changes Python made, and other stuff.
But there are always the original ISO for download, thanks to some very nice folks making it possible
2.5 should be in the 8.04 version of Ubuntu
www.linuxcnc.org/iso/ubuntu-8.04-desktop-emc2-aj13-i386.iso
There is also the 10.04 version that should come with 2.7
www.linuxcnc.org/iso/ubuntu-10.04-linuxcnc3-i386.iso
  • Crimznn
  • Crimznn
23 Aug 2024 17:31
Replied by Crimznn on topic Download older version (2.5.1)
I need to downgrade new router pc to 2.5.0 which of the downloads will be best?
  • Crimznn
  • Crimznn
23 Aug 2024 17:27
I need 2.5.0 same download link? ubuntu/linux
  • rajsekhar
  • rajsekhar
23 Aug 2024 17:26
Replied by rajsekhar on topic 4 Axis CNC MIG welding, weavy stuff problem
Category: Show Your Stuff
I am thinking of making a similar machine..
What kinematics is used here?
  • Aciera
  • Aciera's Avatar
23 Aug 2024 17:24 - 23 Aug 2024 17:25
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
Looking at the screenshot of your ini file it seems that you are loading both panels ('testpanel' and 'testpanel1') to the same location 'ntb_preview', not sure what that does but you may want to load the 'testpanel' to a different location like.
EMBED_TAB_LOCATION = box_cooling
  • Crimznn
  • Crimznn
23 Aug 2024 17:18
our old pc broke we sent it in to get fixed and overnighted a new one but it won't run I/O through the extra parport to the plc, I need to remove 2.9.2 and find the download for 2.5.0 or copy it from our other router pc I need some guidance mostly as far as the re-installation process and where I can find a repo or source to get 2.5.0
  • fsabbatini
  • fsabbatini
23 Aug 2024 16:38
  • fsabbatini
  • fsabbatini
23 Aug 2024 16:32 - 23 Aug 2024 16:34
Replied by fsabbatini on topic Cylindrical mapping
Cylindrical mapping
Thanks Bari! that looks awesome, lots of efforts in writing that software
Here is another video of Cylindrical mapping at real work
  • Moutomation
  • Moutomation
23 Aug 2024 16:22
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
I will do this first thing tomorrow morning.
  • Aciera
  • Aciera's Avatar
23 Aug 2024 16:14
İnstall glade
Category: Gmoccapy
Problem is your handler script does not load so start a terminal and type:
linuxcnc -l
note the minus and lowercase letter 'L' should load the last config.
  • Moutomation
  • Moutomation
23 Aug 2024 16:12
İnstall glade
Category: Gmoccapy
linuxcnc boots without any warning. I don't know how to get terminal output
  • Aciera
  • Aciera's Avatar
23 Aug 2024 16:06
İnstall glade
Category: Gmoccapy
Terminal output?
  • Moutomation
  • Moutomation
23 Aug 2024 15:57
İnstall glade
Category: Gmoccapy
Displaying 23551 - 23565 out of 24288 results.
Time to create page: 0.673 seconds
