  • scotta
  • scotta's Avatar
08 Aug 2024 20:44
Deadband should be a positive number. I'll need to force that in the code. What you've done is kinda like what Cakeslob suggested.
// apply the deadband
if (error > deadband)
error -= deadband;
else if (error < -deadband)
error += deadband;
else
error = 0;
// calculate the output value
vel_cmd = pgain * error + data->cmd_d * ff1gain;
Try increasing your pgain.
  • rodw
  • rodw's Avatar
08 Aug 2024 19:49
Ethercat installation from repositories - how to step by step
Category: EtherCAT
yes tested it works on my chromebook so it should work on any device Ethercat supports. Shame it does not have an Ethernet port :)
copy text to a file. call it ethinstall.sh and make it executable:
chmod +x ethinstall.sh
./ethinstall.sh
  • rodw
  • rodw's Avatar
08 Aug 2024 19:37
Category: EtherCAT
The Raspberry pi images do not include the Ethercat repositories but enabling some commented out code should enable it according to feedback from etherlabmaster
Try running a script something like this
#!/bin/bash
# Install companion repositories. NOTE: QTPYVCP does not support the raspberry pi.
echo "Install ethercat repository"
mkdir -p /usr/local/share/keyrings/
wget -O- https://build.opensuse.org/projects/science:EtherLab/signing_keys/download?kind=gpg | gpg --dearmor | dd of=/etc/apt/trusted.gpg.d/science_EtherLab.gpg
tee -a /etc/apt/sources.list.d/ighvh.sources > /dev/null <<EOT
Types: deb
Signed-By: /etc/apt/trusted.gpg.d/science_EtherLab.gpg
Suites: ./
URIs: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/
EOT
  • rodw
  • rodw's Avatar
08 Aug 2024 19:30
Replied by rodw on topic ethercat master service
Category: EtherCAT
no, out of my depth here but to me lcec.0 and lcec.1 imply separate instances of Ethercat. I would put them on different Linuxcnc threads so the timing is different.
  • Moutomation
  • Moutomation
08 Aug 2024 19:26
Category: EtherCAT
Hello,
Is it possible to install ethernet for raspbery pi? Are the iso files up to date ?
  • rodw
  • rodw's Avatar
08 Aug 2024 19:18
Replied by rodw on topic Installing Linuxcnc on Debian Bookworm
Category: Installing LinuxCNC
Yes its pretty easy to give a user sudo access. I think from memory using sudo then requires root's password.
You just need to add your user to the sudoers user group when signed in as root
usermod -aG sudo newuser
  • papaathome
  • papaathome
08 Aug 2024 19:09
Replied by papaathome on topic Installing Linuxcnc on Debian Bookworm
Installing linuxcnc on a standard Debian instance is described in the docs here
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
Just followed the procedure, it was a doddle.
I want to mention a few points I ran into. Maybe others can do there advanage with it.
First: There is a warining not to supply a root password when installing Debian. If you do give a root password then sudo is disabled.
Of cause I had supplied a root password (old habits dont die easily!)
I had two options, reinstall and don't supply a password or find out how to enable sudo. I opted for the second one.
If you search the internet then you can find several sites with advice how to do it.
In the instructions I used the command `adduser username sudo` is used. That command could not be found.
Solution: use `whereis adduser` then use the command with the full path.
The rest is just read first, check and check again then do exact what you are told to do. No further problems.
Now running kernel Linux 6.1.0-23-rt-amd64 with LinuxCNC installed.
Latency tests are a factor 2 better compared to running LinuxCNC life.
I have made some changes in the bios between testing with LinuxCNC life and the current situation but have not (yet) fully tuned this installation.
I want to try the next step, using the RTAI kernel.
Kind regards.
  • anfänger
  • anfänger's Avatar
08 Aug 2024 18:10
Replied by anfänger on topic Fehlmann Picomax 100 Retrofit
Category: Milling Machines
Long time no news here...
to make it short, I installed a Mesa 7I85S and with a lot of help from here I got my servos running with digital instead of analog control.
and now its time to annoy the probe_basic guys cause I am trying migrate to linux 2.9.3 to use steppers with index for homing
  • anfänger
  • anfänger's Avatar
08 Aug 2024 18:02 - 08 Aug 2024 19:35
Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
Hi I installed the development system with 2.9.3 and the deb files like in the tutorial described.
kcjengr.github.io/probe_basic/development_quick_start_apt.html
Then I tried to open my config I used with probe_basic under 2.8.2. Fixed the python3 issues with my own Hal components.
now it ts trying to start an I am expecting to fail due to missing Hal pins from qtpyvcp,  cause I heavyly modified the ui file to match my machine.
but I get this error:
[qtpyvcp.app.launcher][CRITICAL]  Unhandled exception in probe_basic line 8 (launcher.py:37)
  File "/usr/bin/probe_basic", line 8, in <module>
    sys.exit(main())
  File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
    qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
  File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
    run(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
    launch_application(opts, config)
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
    loadWindows(config['windows'])
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 228, in loadWindows
    window = _initialize_object_from_dict(window_dict)
  File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 208, in _initialize_object_from_dict
    return obj(*args, **kwargs)
  File "/home/wully/linuxcnc/configs/wully/custom_probebasic.py", line 15, in __init__
    super(CustomProbeBasic, self).__init__(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 35, in __init__
    super(ProbeBasic, self).__init__(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 47, in __init__
    self.loadUi(ui_file)
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 106, in loadUi
    uic.loadUi(ui_file, self)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 241, in loadUi
    return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
    return self.parse(filename, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
    actor(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
    self.traverseWidgetTree(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
    handler(self, child)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
    self.stack.push(self.setupObject(widget_class, parent, elem))
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
    obj = self.factory.createQObject(clsname, name, args, is_attribute)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 118, in createQObject
    return self._cpolicy.instantiate(factory, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 137, in instantiate
    return clsObject(*ctor_args)
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 179, in __init__
    self.default_view = view_options[view_default_setting]
I guess try coming from my custom_config.yml
ad related files.
# example of a machine specific settings
windows:
  mainwindow:
    provider: custom_probebasic:CustomProbeBasic
#windows:
#  mainwindow:
#    kwargs:
#      confirm_exit: false
settings:
  # VTK backplot view settings
  backplot.show-grid:
    default_value: false
  backplot.show-program-bounds:
  backplot.show-program-labels:
  backplot.show-program-ticks:
  backplot.show-machine-bounds:
  backplot.show-machine-labels:
  backplot.show-machine-ticks:
  backplot.perspective-view:
  backplot.view:
    default_value: P
    options: ["X: Front View", "XZ: Lathe View", "XZ2: Lathe View", "Y: Front View", "Z: Top View", "Z2: Bottom View", "P: Isometric"]
  backplot.multitool-colors:
    default_value: True
and when I emote the custom widget (its for setup sheets)
I come to the point where it fails due to missing pins.
copying my ui file over the one in the deb package let it fail again.
sys.exit(main())
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
ModuleNotFoundError: No module named 'qtpyvcp_conversational_gcode'
I guesss there were some changes which make it fail.
I'll made all ma chalets just to one tab I added.
So I did edit this section in the ui file. and still run into errors.
    sys.exit(main())
    actor(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 116, in createQObject
    raise NoSuchWidgetError(classname)
PyQt5.uic.exceptions.NoSuchWidgetError: Unknown Qt widget: HalLCDNumber
I am afraid I need to redo all ma work. maybe its faster since I've done it before
will there be a better option in the future keep custom tabs?
for more complex machines this might help a lot.
Thanks Patrick[/code]
  • Lpkkk
  • Lpkkk
08 Aug 2024 17:30
I will try your settings. So far the best settings I could find were :
DEADBAND = -0.0002
FF1_GAIN = 1
P_GAIN = 1
I put negative deadband because it seems to work better than positive. I've tried many di settings in last few days. A lot of testing.
  • anfänger
  • anfänger's Avatar
08 Aug 2024 17:04 - 08 Sep 2024 15:23
Replied by anfänger on topic Mesa Analog Vs Step Dir
Category: Driver Boards
thanks again.
Update is running...
And home with index is working!
many thanks!
  • Moutomation
  • Moutomation
08 Aug 2024 17:03 - 08 Aug 2024 17:09
Replied by Moutomation on topic classic ladder input and output added
Category: ClassicLadder
I appreciate your contribution to this forum and to us. Thank you very much,
  • meister
  • meister
08 Aug 2024 16:25
sooo, small WARNING, I have now tidied up the boards and configs.
renamed a lot of things and removed all my test files.
if you are missing something, please let me know, i still have everything :)
i will shortly merge the dev branch into the main and then also remove the riogui repository (everything is in the riocore)
  • jossen
  • jossen
08 Aug 2024 15:28
[ Vfdmod ] An easy VFD control over MODBUS RTU
Category: HAL
Someone got the Vfdmod package for RaspberryPi? (arm)
  • PCW
  • PCW's Avatar
08 Aug 2024 13:43
Replied by PCW on topic Mesa Analog Vs Step Dir
Stepgen index requires 2.9 or later
Displaying 24271 - 24285 out of 24501 results.
Time to create page: 0.493 seconds
