[ Vfdmod ] An easy VFD control over MODBUS RTU
- OGMaker
- Thank you received: 3
06 Aug 2024 15:24 #307101
by OGMaker
It looks lilke aekhv has pulled the project
There are are forks of it, but forking doesn't capture the wiki or the project or the releases. I'll attach the debian 3.2 release in case you still want to use it..
Replied by OGMaker on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
The following user(s) said Thank You: tommylight, pietvr
- Bureaufly
07 Aug 2024 07:14 #307151
by Bureaufly
Replied by Bureaufly on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Thanks man, sorry about the frustration.....
- jossen
08 Aug 2024 15:28 #307265
by jossen
Replied by jossen on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Someone got the Vfdmod package for RaspberryPi? (arm)
- Pickle
21 Aug 2024 12:02 #308281
by Pickle
Replied by Pickle on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
So is it possible to get hold of VFDMOD? I installed this on a previous setup and it was ideal for me. Now I just get 404 error wherever I look!
- tsaG
- Thank you received: 4
18 Oct 2024 11:33 #312494
by tsaG
Replied by tsaG on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
I managed to get VFDMod to run using the good ol' Wayback machine. A bit slow but everything available (even the installable download package mentioned above).
web.archive.org/web/20230123060705/https...ub.com/aekhv/vfdmod/
My BD600 Spindle is running (when pushing the button) and I can also issue the GCode Command to change the spindle speed but I can not change the speed using any button. Nor Do I see the speed or Spindle Load. Did anyone get VFDMod Working in QTPYVCP?
- pietvr
- Thank you received: 21
19 Jan 2025 21:45 #319413
by pietvr
Replied by pietvr on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
This might help -
github.com/thestealth131205/vfdmod
- ShemJ
16 Apr 2025 09:20 #326438
by ShemJ
Replied by ShemJ on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
I've been having issues with MB2HAL and an L510 VFD rebrand. I was hoping to try VFDMOD but unfortunately, the ARM DEB package is armhf and I am using an Rpi 5.Early days for my linuxCNC'ing, but....Is it possible to repackage for arm64 from 32bit?Also thought I'd attach the wiki here just in case.
- Thank you received: 4648
18 Apr 2025 09:26 - 18 Apr 2025 09:29 #326580
Replied by andypugh on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
For the benefit of anyone else using the L510 (or the RS-branded RS510) VFD this component seems to work:
github.com/gitcoffey/l510_vfd
after making this change
github.com/gitcoffey/l510_vfd/pull/1
Install with
Install with
sudo halcompile --userspace --install --extra-link-args="-lm -lmodbus" l510_vfd.c
Last edit: 18 Apr 2025 09:29 by andypugh.
- xenon-alien
30 Dec 2025 23:20 #340751
by xenon-alien
Replied by xenon-alien on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Hello!
Can anybody help me out with this step by step? (I'm not a Linux user)
I have my old setup, but i don't remember how to add Vfdmod to the LCNC, to see the pins and other.
I have now a Buster system with LCNC 2.9.7 and have a "not found file/directory Vfdmod" message.
All old links not works... How to compile it and from where and which file I have no clue...
- nwallace
- Thank you received: 10
30 Dec 2025 23:32 #340752
by nwallace
Replied by nwallace on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Unfortunately Vfdmod is no longer maintained and isn't really a good option for new installs. It was a bit of a pain but I switched to mb2hal. Between the documentation and a few examples I was able to figure it out with some trial and error. I suggest switching to that.
Time to create page: 0.159 seconds
