  • OT-CNC
  • OT-CNC
26 Jul 2024 02:11
Replied by OT-CNC on topic 7i77 encoder split to amp and servo
Category: Driver Boards
I ended up using the encoder y board from mesa which seems to be working fine with the addition of having swapped the servo drive to an isolated version.
  • OT-CNC
  • OT-CNC
26 Jul 2024 01:58
Replied by OT-CNC on topic 7i77 isol
7i77 isol
I wanted to report back that the solution here was to switch to an isolated version of the amc servo drive.
In addition I have added chockes/toroids as suggested.
  • vre
  • vre
26 Jul 2024 01:13
how to make my own custom page for qtdragon_hd?
Category: Qtvcp
How can add a latch button with led like the flood on/off and mist on/off from qtdesigner?
26 Jul 2024 01:07
difference between machine coordinate systems and CAD software
Category: AXIS
Your fist picture = you are looking at the part from behind, any particular reason for it?
Moving table and moving head are two different types of machines, despite being the same functionally, but very different when looking at them and using them, i have a feeling you are mixing these.
  • onceloved
  • onceloved's Avatar
26 Jul 2024 00:41
xyzab to xyzac was created by onceloved
xyzab to xyzac
Category: QtPyVCP
How to convert the B axis to the C axis? Including pictures. The default is XYZAB. I need XYZAC.
  • my1987toyota
  • my1987toyota's Avatar
26 Jul 2024 00:35
Replied by my1987toyota on topic Mostly 3D Printed CNC Foam cutter
Category: CNC Machines
 spend half hour looking for something you found a few days earlier with the same exact name, nothing, zero, zilch,! All those have become like PMS with mood swings! :)
couldn't help but laugh at that one
  • rodw
  • rodw's Avatar
26 Jul 2024 00:22
Possibility of a Retrofit on Alcor 220CNC
Mesa Cards have seperte MPG inputs (5 v signal) Often  only 2 but I'm sure different firmware can add a third at the expense of some inputds
Ref: linuxcnc.org/docs/stable/html/examples/mpg.html
(Example is Single MPG  with multiple axis select but easy to make it for a single axis.)
Displaying 24946 - 24952 out of 24952 results.
Time to create page: 0.390 seconds
