  • aaron
  • aaron
08 Jul 2026 20:47
Trixy Install problems was created by aaron
I have downloaded and flashed Debian Trixy Linuxcnc from the download page twice now. And every time I try to install, it gets stuck at configuring the sources. I do not think it is a network problem because when I run the live instance, I can browse the internet. Please can someone offer a solution, or tell me where I can download the Bookworm version, which I know works.
Aaron
  • RLA
  • RLA
08 Jul 2026 20:31
Replied by RLA on topic Homing switch setup in hal
if I go to V- instead of power supply ground IN2 lights...is that ok? or does it indicate a different problem?
  • RLA
  • RLA
08 Jul 2026 20:03
I forgot about that.....no
  • PCW
  • PCW's Avatar
08 Jul 2026 19:51
Replied by PCW on topic Homing switch setup in hal
Does the yellow LED near IN2 operate as expected?
  • RLA
  • RLA
08 Jul 2026 19:14
Hi...I used pin that is labeled iN2....and put in Hal as GPIO 002....when I tried to test in Halshow nothing happened....i checked wiring seems ok....I did not know if i am missing something in Hal...I only put  info  in the x axis section...
# ---# external input signals...under this part it is blank..
setup home / limit switch signals---
net x-home-sw <=  hm2_7i96s.0.gpio.002.in_not
net x-home-sw <= joint.0.home-sw-in
Thanks for reply!!
  • PCW
  • PCW's Avatar
08 Jul 2026 18:53
TB3 pin Pin 2 would be GPIO 01 (but actually you should be using INM pins, not GPIO)
Pncconf setup would be something like:
(invert it using NC switches)
You should also use halshow to verify home switch operation before attemting to home
  • Etced
  • Etced
08 Jul 2026 18:13
Replied by Etced on topic can not jog axis in Gmoccapy
Category: Gmoccapy
Ok, that makes sense, I deleted the step config file. Currently I can jog XYZ in the pnc config "test this axis" .
Gmoccapy  jog does not work but shows movement on screen.
  • tuxcnc
  • tuxcnc
08 Jul 2026 18:07
Replied by tuxcnc on topic Test system setup
Test system setup
Had to drop back to V2.7 to get a reasonable jitter number on my old Athlon X2 CPU. (20,000)
Very bad idea...
Wheezy with RTAI has low jitter on some motherboards, but today this is time waste only.
This is 32bit Linux, Python 2.7, no realtime ethernet, and old LinuxCNC not compatible with modern, even at configs level, so you get many useless experiences...
Yesterday I installed Debian13.5 with LinuxCNC 2.10 on my Lenovo M725s SFF Ryzen 3 8GB 128GB M.2 NVMe (not newest but still modern), jitter is 20,000 and all works well.
This model has LPT connector at motherboard, but you can buy cheap second hand PCIex to LPT card.
In my opinion, LPT is obsolete, but if exist, you can serve some auxilary signals by this.
There are cheap 7i92 clones on Aliexpress.
I have model similar to original MESA, and chinese version with I/O drivers, both works well.
In my opinion, the future is ethercat and modbus.
This is more cost and more dificult, but works like in dreams...
08 Jul 2026 17:45
Replied by tommylight on topic can not jog axis in Gmoccapy
Category: Gmoccapy
This is confusing, why stepconfig?
Stepconfig is for parallel port setups, only.
  • RLA
  • RLA
08 Jul 2026 17:39
Homing switch setup in hal was created by RLA
Hi...I have a mechanical home switch wired as seen from others but does not seem to be functioning...I am not sure I have hal right for x home switch...I have pin # 2  from mesa 7196s going to nc on switch...Input common to 24v ground on  power supply  and switch common to 24v power supply v+...I am not very good with electric so any help would be greatly appreciated..
Thanks,
Rick
  • Etced
  • Etced
08 Jul 2026 17:28
Category: Gmoccapy
Any suggestions would be appreciated.
  • rhscdn
  • rhscdn
08 Jul 2026 17:13
Replied by rhscdn on topic Test system setup
Test system setup
I had the same issue with shipping/duty. I purchased a 7i96s and I don’t regret it.
  • pb12
  • pb12
08 Jul 2026 17:00
Replied by pb12 on topic Test system setup
Test system setup
Just an FYI, Mesa cards make network jitter much less of an issue.
Yep...... and as I want to understand and experiment with cnc a Mesa card (or Ethercat device) would be the way to go. I was definitely considering a Mesa card (7i96)
I do have another more capable PC. Would need an ethernet card for Mesa. Or parallel port card. Or ethernet card + Mesa for my old Athlon X2 (2 core) hardware
Freight is the killer USD80 just to get a Mesa card to my country.
Many decisions ..............
Phil
08 Jul 2026 15:50
Replied by tommylight on topic Do NOT update working machines!!!
I would really appreciate if someone else would write something about this, and i will gladly delete this.
Anyone?
  • tuxcnc
  • tuxcnc
08 Jul 2026 15:28
Replied by tuxcnc on topic Do NOT update working machines!!!
I agree there is potentialy risk in upgrade an working machine.
I like have newest system with newest abilities, so I upgrade/install system very often.
Sometimes there is no problems, sometimes system or Linuxcnc became useless...
My last bad experience is MESA "error finishing read" error after upgrade kernel (some versions of 6.12 kernel works well, some not).
The best solution is full backup and two or few disks with many partitions.
The Debian 13 with LinuxCNC installed only for control the machine (xfce4, no CAD/CAM etc.) fits in 8 GB disk space.
It is only a few minutes for copy whole of that partition with dd...
In other side, I know the man who has above twenty (!!!) commercial (!!!) installations of Wheezy on very old commputers with LPT ports.
If you don't know what it means, I explain : 32bit systems with RTAI kernel (no realtime ethernet) with hardware in end of their life...
Any updates of this museum are imposible, and any old configs will not work with modern LinuxCNC...
Displaying 2611 - 2625 out of 12539 results.
Time to create page: 0.898 seconds
