10 Apr 2024 12:08
Replied by tommylight on topic Issue on boot
Issue on boot
sudo lspci -v
see if there is a 5i20 or 5120 mentioned there, usually near the bottom of a loooooong list.
10 Apr 2024 11:53
Replied by Cant do this anymore bye all on topic Issue on boot
Issue on boot
I think this file is missing:
'/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko'
what does this list?
sudo ls /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko
I think you'd get a "No such file or directory" error rather than a "no device" message. And it's hard to imagine a file going missing after changing a battery.
  • nicnucan
  • nicnucan
10 Apr 2024 10:29
Is there an update to get the NVMPG working on the EC500 with remora?
  • itsemast
  • itsemast
10 Apr 2024 10:19
Replied by itsemast on topic Remora for RK3588 Boards
Yes, maybe "remora" name should be reserved for projects that use an external MCU interfaced over SPI (or Ethernet) to LinuxCNC. Using an integrated MCU seems cool, but it's not clear how it is interfaced (shared memory maybe?) and how is firmware flashed to it. This is something that was already done in the past with  allwincnc project . Hard to say if similar approach is applicable to RK3588 with it's integrated Cortex-M0 core.
Until this is investigated, Remora can be used with RK3588 with an external MCU. It's SPI implementation is using bcm2835 library which will only work on RPi hardware. When porting Remora to UP Board, Mr.Bubbles rewrote this SPI code to use spidev (should work with RK3588 as well as any board with SPI kernel driver), however this implementation appears to have  realtime performance issues .
So finally, it leaves us with Ethernet. Will it work? Most likely, yes. Anyone already tried it? I don't think so.
  • cncsparko
  • cncsparko
10 Apr 2024 10:17
Replied by cncsparko on topic Issue on boot
Issue on boot
All fingers look clean, no issues physically.
My fault thought it was in a picture
It is a MESA 5120 Anything
10 Apr 2024 10:04 - 10 Apr 2024 10:08
Issue on boot
If there are any more slots available I'd give them a try.
Are the fingers on the Mesa card showing any sign signs of dirtiness\tarnish ?
Might be helpful if you could state the card you are using ?
Also it could be useful to download the card manual from Mesa and check that all the jumpers are in the correct place & such, something could have been dislodged. And also pay check the section of the manual that deals with the Leds.
Also the title of the thread doesn't really describe the problem, it's more an issue of the card not being detected.
A better title might have been Mesa XXXX not being detected, this would be more likely to get the attention of Pete from Mesa.
But whatever you do don't start a new thread. I've made a callout to Pete from Mesa to give advice, so hang in there mate.
  • cncsparko
  • cncsparko
10 Apr 2024 10:01
Issue on boot
Behind a password lock. Will see if I can track down someone who would have a clue to it.
Appreciate the help BTW
  • cncsparko
  • cncsparko
10 Apr 2024 09:55
Issue on boot
Sorry for double message.
Got a red light on CR9 and CR10
And amber on CR11
On the card
Will drag up mesa manual see if that has anything that can contribute, probably the operating lights but need to start somewhere
  • rodw
  • rodw's Avatar
10 Apr 2024 09:55
Replied by rodw on topic Issue on boot
Issue on boot
10 Apr 2024 09:54
Replied by Cant do this anymore bye all on topic Unable to set boot order on Raspberry PI5 with pcie NVMe on HAT.
They might have made a typo
This may work
sudo python3 -m pip install pycryptodomex
  • cncsparko
  • cncsparko
10 Apr 2024 09:52
Issue on boot
Shut it down, removed the mesa card, gave it the ole cartridge clean and tried it.
No change.
Checked all the files and everything seems to be in the locations it's looking for, again amateur hour here but highly interested as stated.
10 Apr 2024 09:15
Issue on boot
I'd try reseating the Mesa card, and giving things a bit of a clean.
This is the error
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 No such device
  • NT4Boy
  • NT4Boy
10 Apr 2024 08:35
Last try was
sudo python3 -m pip install --break-system-packages cryptodomex
error is could not find distribution.
  • cncsparko
  • cncsparko
10 Apr 2024 07:43
Issue on boot
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/user/linuxcnc/configs/OMCG'
Machine configuration file is 'OMCG.ini'
INIFILE=/home/user/linuxcnc/configs/OMCG/OMCG.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=18670
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
OMCG.hal:9: exit value: 1
OMCG.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
18670
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[78052.361444] I-pipe: Domain RTAI registered.
[78052.361457] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[78052.361463] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[78052.361535] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[78052.361541] PIPELINE layers:
[78052.361546] f8605e20 9ac15d93 RTAI 200
[78052.361552] c085cb20 0 Linux 100
[78052.387551] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[78052.387776] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[78052.387784] RTAI[sched]: hard timer type/freq = APIC/12468990(Hz); default timing: periodic; linear timed lists.
[78052.387790] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2793162000 hz.
[78052.387794] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[78052.388606] RTAI[usi]: enabled.
[78052.454124] RTAI[math]: loaded.
[78052.553392] hm2: loading Mesa HostMot2 driver version 0.15
[78052.557089] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[78052.926702] hm2: unloading
[78052.986193] RTAI[math]: unloaded.
[78053.035103] SCHED releases registered named ALIEN RTGLBH
[78053.064368] RTAI[malloc]: unloaded.
[78053.164026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[78053.167983] I-pipe: Domain RTAI unregistered.
[78053.168077] RTAI[hal]: unmounted.
  • COFHAL
  • COFHAL
10 Apr 2024 07:22
Replied by COFHAL on topic TURRET TOE100
TURRET TOE100
Category: Turning
Yes.
Displaying 26506 - 26520 out of 26754 results.
Time to create page: 0.920 seconds
