  • spumco
  • spumco
07 May 2026 17:51
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
I got completely turned around looking at those pics the first time.  I thought the surface you were resting the belt on was actually the pulley teeth in mesh with the belt.
Duh.
  • Dudelbert
  • Dudelbert
07 May 2026 16:30
Category: Turning
The dark line in the middle of the tooth is just the last bit that still has the original surface, with a bit of dirt that makes it darker. On both sides, it is mostly obliterated. I assume that is what you mean by “tit.”
And I think the gap between the teeth is also to reduce the smallest possible bending angle, in addition to the reasons you listed.
  • spumco
  • spumco
07 May 2026 16:13 - 07 May 2026 16:15
Category: Turning
Is that supposed to be a T5 belt profile?  I've never seen a timing pulley with a 'tit' on the tooth crest.
Is the tit on the pulley teeth from wear, or is it some substance that got in the belt tooth valley groove and stuck to the teeth? And that's what you're cleaning?
To clarify, here's a T5 belt profile from Misumi.  I think the groove is there to help air escape at higher speeds (noise reduction).
  • Muecke
  • Muecke's Avatar
07 May 2026 15:50
Erste Schritte mit A6-EC Servo: 24 V für Bremse, Bremswiderstand und RJ45-Kabel?
Category: Deutsch
Bei Amazon hätte ich nicht geschaut  .
Motor, gefunden bei amazon. (Bei Stepperonline sind sie gerade nicht lieferbar.)
Encoderkabel mit Batteriekasten, bei stepperonline, sonst nicht gefunden.
Netzfilter FN2090-8-6, bei ehbshop.de
Das mit dem Relais bereitet mir noch Probleme. Ich weiß nicht, welches ich genau benötige.
  • Dudelbert
  • Dudelbert
07 May 2026 15:30 - 07 May 2026 15:31
Category: Turning
I finally found the problem with the threading. Should have found it much earlier.It’s the belt.
It gets chewed up. Opening the side panel, I found belt-colored dust, but the belt still locked fine, at least from the side. Looking closer showed that the teeth are broken up from the middle outward (see picture).
I found one tooth gap with some hard thing in it, so I assume that my initial cleaning when installing the belt was not very thorough and I overlooked that.
After cleaning that out and reinstalling the already damaged belt, I could thread fine. But I think this will not last long, so I ordered new belts and will install them after VERY thoroughly cleaning both pulleys.
It’s really typical for me that the solution to a month of problems is: “You should have cleaned the thing better.”
  • andrax
  • andrax's Avatar
07 May 2026 15:09
Category: Deutsch
Wenn du bei Amazon bestellst, geht's schnell aber kein STO.
Wenn du direkt bei Stepperonline bestellst, freu dich auf den Zoll.
  • COFHAL
  • COFHAL
07 May 2026 14:53
Replied by COFHAL on topic Qtvcp GUI and hal pins
Category: Qtvcp
I did that; I installed the latest version of LNC from buildbot2.highlab.com/debian/bookworm master, and the problems persist. To execute a command with an external button, MDI must first be selected, which doesn't happen with the buttons on the screen. Regarding running O Word, both with external buttons and those on the screen, it now appears that the O Word file path cannot be found, and the error "Error Oword XXXX.ngc path not found" and "File not open" appear. And when executed manually from MDI, the error is "File not open."
  • Muecke
  • Muecke's Avatar
07 May 2026 14:50
Category: Deutsch
Das ist ja genial! Direkt für alle Treiber den richtigen Filter. Ich habe es direkt ausgedruckt und an die Wand gepinnt. :-) DANKE dafür!  Ok, das mit der Bremse habe ich soweit verstanden, bzw. den Generator. Du sprichst immer von Lasten wie Fahrstühlen, die sind ja echt schwer und haben ordentlich Masse. Ich plane erst einmal damit zu spielen, das Teil überhaupt zum Laufen zu bekommen, und dann einzelne Achsen aus meiner Musteranlage (nahezu lastfrei) anzutreiben, um zu sehen, welche Kraft in den Linearführungen etc. entsteht. Das wird ein spannendes Projekt. Nur sind die Teile wahrscheinlich nicht alle rechtzeitig zu meinem Urlaub da.
  • Lcvette
  • Lcvette's Avatar
07 May 2026 13:27
Replied by Lcvette on topic Probe Basic facing no tool selected
Category: QtPyVCP
yes, that will be the stable release when there is a stable release, but currently we are not promoting one because develop version is still early testing. bear in mind that even the develop version is currently still a development version and will have a very turbulent update schedule as we find bugs and correct them from the pyside6 porting.
Chris
  • HansU
  • HansU's Avatar
07 May 2026 12:59
Can't read gcode text in dark mode when editing.
Category: Gmoccapy
Have you tried the command line?
sudo apt update
sudo apt install linuxcnc-uspace
  • besriworld
  • besriworld
07 May 2026 11:03 - 07 May 2026 11:07
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
After sudo apt update I started getting errors in real time (the old song in a new voice :) ) I tried many things and finally this helped: sudo apt install iproute2
sudo tc qdisc replace dev enol root pfifo_fast
  • rodw
  • rodw's Avatar
07 May 2026 09:56
Replied by rodw on topic Brilliant Bambu Lab
Brilliant Bambu Lab
One case here in Australia, a  small winemaker  who sold wine under his own name Robert Chardon got a cease and desist letter from Moet et Chandon the Franch champagne brand thanks to one of those Lawyers. Robert probably sold 10 tonne of grapes a year if he was lucky when economies of scale says a winery needs to produce 1000 tonnes. He had to change his brand!
I've sold the business now but I sent a cease and desist to a large company infringing my trademark selling a counterfeit version of my product via Google ads which was an unwanted legal expense! If you have a trademark you have to defend it.
But the worst I heard was an Aussie one man band found Microsoft was using his patented software protection system (Probably on Windows) and his heart sank knowing he had no choice but to tell them to stop. By this time he was living in the USA and IBM helped him and he won the case. Not sure about the appeal though!
  • my1987toyota
  • my1987toyota's Avatar
07 May 2026 09:41
Replied by my1987toyota on topic Brilliant Bambu Lab
Brilliant Bambu Lab
    The irony of a lawyer pushing that, is the more they irritate the customer and potential customer base, the
less likely people will be to purchase there products. Especially when it is heavily based off of open source
I.P. It's like a snake eating it's own tail.
  • HansU
  • HansU's Avatar
07 May 2026 09:33
Replied by HansU on topic Launching gladevcp panel with gmoccapy
Category: Gmoccapy
Several errors.
1. A typo. You wrote "EMBED_TAB_HAME = CROSSHAIR" instead of "EMBED_TAB_NAME = CROSSHAIR". Unfortunately you don't get an error because the interpreter just thinks "this value is not for me".
2. you need to define where the VCP should be shown like Aciera mentioned, e.g.
Then you get a meaningful error message
gtk-builder-error-quark: crosshair-panel.ui:12:34 Invalid property: HAL_Table.n-rows (11)
This points out that you used an old glade editor. Saving it with a up-to-date Glade 3 editor (3.40 e.g.) removes this and other obsolete properties.
Then the VCP is displayed:
Further you have a handler "on-changed" defined in your glade (ui) file, but no python file where this handler is defined
AttributeError: Handler on-changed not found
  • zu4lu
  • zu4lu
07 May 2026 07:57
Replied by zu4lu on topic Probe Basic facing no tool selected
Category: QtPyVCP
Problem solved, i reinstalled Probe Basic with the right source, and it is working as expected now. Had trixie instead trixie-dev. Although it installed a version with the wrong source. Sorry for inconvenience. Thank you for your great probe basic und your help.
Michael
Displaying 3871 - 3885 out of 12541 results.
Time to create page: 0.482 seconds
