  • papagno-source
  • papagno-source
14 Apr 2026 08:26
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
Yes excuse the correct question Is :
So in my case, the only way to get it to work is:
refClockSyncCycles=1, without syncToRefClock
or
refClockSyncCycles=-1, with syncToRefClock=false
So I'm not using DC mode?
  • grandixximo
  • grandixximo's Avatar
14 Apr 2026 08:18
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
refClockSyncCycles=-1, without syncToRefClock=false
Are you sure this works? I think you stated differently before.
  • papagno-source
  • papagno-source
14 Apr 2026 07:33
Category: EtherCAT
I tried writing in the XML file:
refClockSyncCycles=5, without syncToRefClock, and the machine makes noise.
I also tried:
refClockSyncCycles=1000, without syncToRefClock, and the machine makes noise.
or
  • grandixximo
14 Apr 2026 07:19
Category: EtherCAT
DC has one start time, that's set on start usually by the first Ethernet DC capable device, from there you have two choices, either the slaves follow the time that the master declares every x cycles with refClockSyncCycles=x
Or everyone follows what the first slaves says the time is, master included. To do that master nudges its own cycle time to match what the first slaves report, the problem with your setup I think, is what the first master is reporting, so this system seems to not work correctly.
This mode is also DC and is set with
Or
syncToRefClock="true"
  • grandixximo
14 Apr 2026 07:02 - 14 Apr 2026 07:08
Category: EtherCAT
refClockSyncCycles=-1 and syncToRefClock="false"
Is identical to
What synctorefclock false clock does is make -1 become positive, if it was -5 it would be 5
refClockSyncCycles=-1 DC is enabled but master follows the reference slave, master will change its own time
This is identical to syncToRefClock true
About having only one Ethernet, USB to Ethernet adapter could work to give it internet, but I won't insist, but if possible I'd really love to test for myself, as some things get lost in communication
  • papagno-source
  • papagno-source
14 Apr 2026 06:57
Category: EtherCAT
Hello everyone. The machine has only one Ethernet port, dedicated to EtherCAT.
I wanted clarification regarding Hakan's statement:
If any of the slaves have an assignActivate bit 8 set (DC sync), switch on loop synchronization.
The drive's XML file contains these entries:
<OpMpde>
<Name>DC</Name>
<Desc>Dc-Synchron</Desc>
<AssignActive>#300</AssignActive>
<CycletimeSync0 Factor="1">0</CycleTimeSync0>
<ShiftTimeSync0Z0>/ShiftTimeSync0>
<OpModie>
Does this entry mean bit 8? Does the manufacturer declare that the drive supports DC?
So, to conclude.
If I write in the XML file:
refClockSyncCycles=-1 and syncToRefClock="false", DC is enabled, so the slaves synchronize with the master managed by LinuxCNC.
If I write only:
refClockSyncCycles=1 in the XML file, DC is enabled, so the slaves synchronize with the master managed by LinuxCNC.
But I can choose the synchronization frequency from 1-5-1000.
If I write only:
refClockSyncCycles=-1 in the XML file, DC is not enabled, but free mode is enabled, and the drives do not synchronize with the LinuxCNC master.
Correct?
I imagine that the best feature for a CNC machine is DC mode, or am I wrong?
I verified that the lcec.0.dc-phased pin is always false.
  • grandixximo
14 Apr 2026 05:17 - 14 Apr 2026 05:19
Category: EtherCAT
The option was buggy when introduced, and even now that it works, you can see how confusing it gets about what is actually happening when you have two options to do the same thing, I'll force the XML to be properly written with errors if they don't make sense, that seems the only way forward.
Concretely:
syncToRefClock=true + negative refClockSyncCycles = M2R, fine
syncToRefClock=false + positive refClockSyncCycles = R2M, fine
only one set, other at default = take the one that's set, fine
syncToRefClock=true + positive refClockSyncCycles = refuse to start with a clear error message
syncToRefClock=false + negative refClockSyncCycles = refuse to start with a clear error message
this is also what I proposed in github, I did implement but I had to roll it back, I will probably introduce it again, this is the only clear path if we want to keep both without confusion.
The last example was what caused the confusion with papagno-source
  • Hakan
  • Hakan
14 Apr 2026 04:37
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
Recommendation: Use `refClockSyncCycles=1 or -1
Synctorefclock is just confusing.
It was a mistake from the beginning to let a negative value of refClockSyncCycles activate the pll synchronization method. It wasn't documented, is obscure and not logical. It was a too important option to be hidden in a "-" sign. Therefore the syncToRefClock option was introduced to mark that this is the synchronization option. In discussion with Scott, the "-" option was kept in the linuxcnc spirit of backwards compatibility. The intention and hope was that the usage of "-" should fade away over time. Don't go the "-" route, use syncToRefClock instead.
There is some evolution I guess. refClockSyncCycles was an attempt to synchronize slaves but that doesn't work. Then came the pll method and instead of adding its own option they let the "-" mean to activate the pll code. That was a mistake.
What should have been done was to get rid of refClockSyncCycles option altogether and have an option to either synchronize with the slaves or not. syncToRefClock was meant to be that. One can always argue about the naming, maybe it should be called dcSyncSlaves="true/false" instead?
There are really only two options. Synchronize linuxcnc's loop with the slaves' loops, or not. The first is done and required when using DC sync. For free run or SM synchronization methods a synchronized time is not needed since the slaves don't use it. Slaves don't need to be DC capable, it's optional.
One can extend this and automatically deduce the need for time synchronization.
Otherwise don't touch the times.
  • spacemanspiffee
  • spacemanspiffee's Avatar
14 Apr 2026 03:49
Replied by spacemanspiffee on topic Probe Basic and XHC-WHB04B-6 jogging issue
Category: QtPyVCP
Update on my situation.
I was able to solve my jog pendant issues.
There were two changes I made:
1. halui signals:
Probe Basic
# ---HALUI signals---
net axis-select-x halui.axis.x.select
# net jog-x-pos halui.axis.x.plus
# net jog-x-neg halui.axis.x.minus
# net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
# net jog-y-pos halui.axis.y.plus
# net jog-y-neg halui.axis.y.minus
# net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
# net jog-z-pos halui.axis.z.plus
# net jog-z-neg halui.axis.z.minus
# net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
# net jog-selected-pos halui.axis.selected.plus
# net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
# net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdiAxis# ---HALUI signals---
#net axis-select-x halui.axis.x.select
#net x-is-homed halui.joint.0.is-homed
#net axis-select-y halui.axis.y.select
#net y-is-homed halui.joint.1.is-homed
#net axis-select-z halui.axis.z.select
#net z-is-homed halui.joint.2.is-homed
#net spindle-manual-cw halui.spindle.0.forward
#net spindle-manual-ccw halui.spindle.0.reverse
#net spindle-manual-stop halui.spindle.0.stop
#net machine-is-on halui.machine.is-on
#net MDI-mode halui.mode.is-mdi
For some reason I had ended up with the exact opposite lines commented between the new probe basic and the old axis configs (probably had used a toggle comment command in vs code accidentally). I swapped the commenting in the probe basic hal file to match the old axis file.
2. pendant.hal and pin conflicts
I had some pin conflicts between pendant.hal and the postgui hal that probe basic uses. I had originally changed them in the pendant.hal file to preserve probe basic postgui hal file. Now, I am using the pendant.hal file that worked with the old axis config and I modified the conflicting pins in the post gui hal file from probe basic.
Between those two changes, the pendant is now functioning just how it was on the old axis configuration.
So now I have a functioning pendant and a functioning ATC using probe basic as the UI.
Next to get my ATC rack made and get my probe working.
  • bedouno
  • bedouno
14 Apr 2026 02:25
Replied by bedouno on topic HAL component for tangential knife
Category: HAL
thank you sir , it is honor to be your student , but i hope to guide me to improve my skills in real-time c programming and the linuxcnc kernal , i am really surprised about it , i feel like in the temple itself
  • grandixximo
14 Apr 2026 01:49 - 14 Apr 2026 01:51
Category: EtherCAT
I've added some debug pins in my repo
lcec.0.dc-time-valid
lcec.0.dc-time-mod
lcec.0.dc-time-delta
please use halscope to read the values you get, if you are on master you can save the scope log, and you can use the attach button, in the reply editor, to attach the file, or a picture of the scope.
would it be possible to get remote access to the machine via teamviewer host?
download.teamviewer.com/download/linux/t...iewer-host_amd64.deb
I'd really like to experiment with the hardware, really interested in checking why my PLL is not working for you, if it is a case of bad I/O or something else, possibly something wrong with some of my code assumptions.
can you email me if you don't want to post here the teamviewer access
luca at aitalmac.com
Is my personal email, thanks
  • Lcvette
  • Lcvette's Avatar
14 Apr 2026 01:21
Replied by Lcvette on topic Probe Basic and XHC-WHB04B-6 jogging issue
Category: QtPyVCP
You may have a timer issue, I know others had conflict with the timer and hbo4 pregnant, I would investigate that.
Aside from that I'm not sure what would cause that except maybe a setting for the pregnant specific that may require a change?
Hopefully someone else can come in with knowledge on it. My wired jog pendant uses velocity mode when the speed is to fast for motion and the pulses begin to stack up, this stupid a runaway axis condition.
  • Lcvette
  • Lcvette's Avatar
14 Apr 2026 01:13
30 Second timeout before opening and E-Stop button not clicking...
Category: QtPyVCP
You can set the overrides so you can go both ways while running, the settings are in the ini file, check the Sims for reference.
  • grandixximo
14 Apr 2026 00:20 - 14 Apr 2026 03:14
Category: EtherCAT
Both work. They are two different sync strategies, neither inherently better. It depends on which your drives like.
The two attributes are redundant and confusing. Negative `refClockSyncCycles` without `syncToRefClock` is the same as `syncToRefClock="true"`. The `syncToRefClock` attribute just explicitly overrides the sign convention. The code always takes `abs()` of cycles, so the sign is purely a mode flag.
With `syncToRefClock="true"` (or negative `refClockSyncCycles`), PLL runs every cycle regardless. The count value doesn't matter, only the sign. So `-1`, `-5`, `-100` all behave identically.
With `syncToRefClock="false"` (or positive `refClockSyncCycles`), the count does matter. It controls how often `ecrt_master_sync_reference_clock()` runs, every N cycles. `1` means every cycle, `1000` means once per second at 1kHz. Lower values mean faster convergence and more bus traffic. Watch `pll_err` and `dc_phased` pins to see when it locks. If it locks fast and stays stable, the value is fine. Examples in the repo use 1, 5, or 1000.
My take: positive cycles with `syncToRefClock="false"` is slightly cleaner, because the PLL stops once locked and less continuous computation happens, provided your drives tolerate the master as clock source. Yours do.
  • spumco
  • spumco
13 Apr 2026 21:50
Replied by spumco on topic Lathe C axis homing
Lathe C axis homing
 In that setup it should be the same as X/Z axis but it's still acting drunk.
How is the servo connected to the spindle?  My biggest problem a couple years ago when I started fiddling was that my spindle servo was WAY undersized for use as a direct-drive positioning motor.
I had a "2.2kw" BLDC servo connected through a 1.5:1 belt drive.  Soon as I put a chuck on the 5C spindle the inertia ratio was so unfavorable the servo couldn't really handle precise positioning.
I now have a comparatively monsterous 3.7kw (actual rating, not inflated) motor connected to the same spindle through a 2.5:1 belt.  Night and day difference.  That motor can horse the spindle around like it's barely there.
Maybe you have a significant inertia mismatch?  Don't want to throw you a red herring, but something to think about.
Displaying 4576 - 4590 out of 12541 results.
Time to create page: 0.275 seconds
