  • Hakan
  • Hakan
08 Mar 2026 13:33
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
It sounds like you get gravel in the servo motors from time to time.
Or you get click sounds from the motors. It repeats itself with a few or many minutes apart.
The first thing to do is to enable syncToRefClock and enable DC mode for the servos,
this will keep the servo loop in sync with the DC.
What grandixximo is doing here is fixing an effect that despite DC and servo loop are synchronized,
the two loops have been started with an undetermined/unfortunate phase between them.
The gravel sound is there all the time and it doesn't go away until linuxcnc is restarted.
Surprisingly, yesterday Sasha Ittner popped up in the PR log and mentioned he had been working
on a complete redesign of the DC system, eliminating all these problems (don't know details)
grandixximo seems to have reviewed that work and decided to adopt Sasha's work.
grandixximo will have to say himself. And if you don't know, Sasha Ittner is the author of linuxcnc-ethercat
from many (>10) years ago.
  • andrax
  • andrax's Avatar
08 Mar 2026 13:20
Replied by andrax on topic Ethercat auto configurator.
Category: EtherCAT
I don't think this will be of much use to you.
There are many topics and instructions on setting up LinuxCNC EtherCAT.
First, check whether your system and CIA402 servos are compatible. Then start setting up your system using the templates. If you get stuck, start a topic in the forum.
This thread is not suitable for that.
  • andrax
  • andrax's Avatar
08 Mar 2026 12:58
Replied by andrax on topic Ethercat random jitter fix
Category: EtherCAT
I also need to ask about this.
How does the jitter problem manifest itself?
Can I see it in the dmesg output?
I have tried to read up on the topic on GitHub, but I still don't understand the actual problem.
It's also a translation problem.
Another question: is this patch already implemented in the current linuxcnc release, or does it have to be installed manually?
Is there any documentation on the additional commands, where and how they are called?
andrax
  • bobwolf
  • bobwolf
08 Mar 2026 12:15
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
Hi everyone, I’ve been away for a few days focusing on the hardware side of the project.
Regarding meister's tests: they are very interesting! They confirm exactly why io_decoder is specifically designed for HMI (MPG, buttons, and operator panels) rather than real-time axis control.
While a 100-200ms jitter is critical for stepper motor timing, it is virtually imperceptible for an operator pressing a 'Coolant' button or turning a feed-override knob. By moving the logic to a dedicated user-space thread in v1.1.0, we ensure that even these USB latencies never interfere with the core LinuxCNC Real-Time performance.
Small update: I’ve just ordered a very limited run of 5 'Ready-to-Use' hardware kits (Core + IN/OUT expansions) for those who want a plug-and-play experience without the hassle of SMD soldering. I'll have them in my hands soon for final testing.
If anyone is interested in being one of the first 5 'beta-testers' for the official hardware, stay tuned!
  • T_D
  • T_D
08 Mar 2026 11:17
Replied by T_D on topic Probleme mit NativeCam
Category: NativeCAM
Linuxcnc wont start , how do i CPU that right ? I have no Internet connection in my Workshop thats why i have to download the file and Transfer it with a USB Stick , and when i made this an error accured
  • rodw
  • rodw's Avatar
08 Mar 2026 10:27
Replied by rodw on topic update running in place linuxcnc
its so automatic I can't remember  source dir I think.
  • rodw
  • rodw's Avatar
08 Mar 2026 10:19
Replied by rodw on topic XHC WHB04B development?
I think there is an oversight in the homing model. I can't see why joint axes can't move in unison before they are homed. If my first machine didn't have a gantry, maybe I'd have a different view. I've often wondered why this treats each side or a gantry as seperate axes when they are always joined at the hip!
  • Muecke
  • Muecke's Avatar
08 Mar 2026 10:02
Replied by Muecke on topic Forum Fehler, ... :-(
Category: Deutsch
Ich kann auch kein neues Thema eröffnen.
Um eine detaillierte Fehlermeldung zu erhalten, muss der Debug-Modus des Forums aktiviert werden. Dann gibt das Forum eine klare Fehlermeldung aus.
@ tommylight:  www.kunena.org/forum/36-German/169090-in...timmte-themen#234690
Gruß Mücke
  • Hakan
  • Hakan
08 Mar 2026 09:55
Replied by Hakan on topic XHC WHB04B development?
There are always situations with tool and work piece geometries
and unfortunate stop situations where one need to stick the nose (eyes) close up
to guide the tool out of the situation before it's free for homing.
I guess the best is to leave it up to the user if he wants to jog before homing.
  • papagno-source
  • papagno-source
08 Mar 2026 09:48
Replied by papagno-source on topic update running in place linuxcnc
Hi Thank for reply.
The git pull command start with terminal in SRC directory on base directoiry ?
  • rodw
  • rodw's Avatar
08 Mar 2026 09:36
git pull
make
sudo make setuid
That's it so simple!
  • papagno-source
  • papagno-source
08 Mar 2026 08:59
update running in place linuxcnc was created by papagno-source
Good morning. I compiled LinuxCNC master version 2.10.0 running in place, downloading it from Git, about a month ago. How can I update the source code to the current version and then recompile it with the latest bug fixes?
  • Giovanni
  • Giovanni
08 Mar 2026 08:49
Replied by Giovanni on topic Probleme mit NativeCam
Category: NativeCAM
What kind of error?
  • rodw
  • rodw's Avatar
08 Mar 2026 08:17
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
I was thinking of building a new image for the Raspberry Pi 5. It will feature 2.10 to get scurve planner and be on Trixie and use the 6.12.74 RT kernel
Is there any reason not to use our current installer framework?
Is there anything that desperately needs changing?
It just seems to be still the best way forward and I have the template to start with.
  • rodw
  • rodw's Avatar
08 Mar 2026 08:08
Get a real machine, rodw :)
In a milling machine and lathe, there are many situations where you may need to jog before homing.
To get the tool out of the way before homing for example.
I had a mill and am building another. I thought HOME_SEQUENCE was designed to get the tool out of the road
Displaying 6016 - 6030 out of 12547 results.
Time to create page: 1.175 seconds
