Ethercat auto configurator.
19 Jan 2025 16:10 #319380 by Felthaus
Replied by Felthaus on topic Ethercat auto configurator.
The link seen to be broken, it leads to a 404 page, but it's a cool idea.
The following user(s) said Thank You: PEAK6
17 Sep 2025 02:56 - 17 Sep 2025 02:57 #335104 by alekisan
Replied by alekisan on topic Ethercat auto configurator.
Hello!
I am attempting to compile the configurator but I'm running into an issue.
To compile it needs "ethercat_master/tool/common.h"
I went to gitlab.com/etherlab.org/ethercat but that codebase does not contain a "common.h" file in the tool directory.
Any assistance on compiling would be appreciated.
Last edit: 17 Sep 2025 02:57 by alekisan.
09 Nov 2025 18:06 #338122 by andrax
Replied by andrax on topic Ethercat auto configurator.
I have the same problem.
First, it couldn't find common.h. Then I added the file from ethercat-master source.
Now I get the error
-- Generating done
CMake Generate step failed.  Build files cannot be regenerated correctly.
Now I'm wondering, is this the right way to go, or does this project have to be used?
skynet/realtime_app - Codeberg.org
11 Dec 2025 14:42 #339977 by Dg88edm
Replied by Dg88edm on topic Ethercat auto configurator.
Hello.
All the links are broken.
So sad because I'm trying to run ethercat in my CNC and I'm having serious troubles to start them. Sometimes I have no idea if I'm making wrong things or there are problems with the repositories
Regards
08 Mar 2026 13:20 #344021 by andrax
I don't think this will be of much use to you.
There are many topics and instructions on setting up LinuxCNC EtherCAT.
First, check whether your system and CIA402 servos are compatible. Then start setting up your system using the templates. If you get stuck, start a topic in the forum.
This thread is not suitable for that.
17 Mar 2026 02:56 #344386 by whj5
Replied by whj5 on topic Ethercat auto configurator.
It shows a 404 error on Codeberg, and the videos on YouTube won't open at all.
17 Mar 2026 03:07 #344387 by whj5
I was wrong, I've found it, sorry.
Time to create page: 0.155 seconds
