Ethercat auto configurator.
- Salame
05 Dec 2024 18:56 #316036
by Salame
Replied by Salame on topic Ethercat auto configurator.
Hi, I couldn't find a way to DM you, for personal info and driver and motor specs etc..
- Grotius
- Thank you received: 2349
05 Dec 2024 20:33 #316043
by Grotius
Replied by Grotius on topic Ethercat auto configurator.
Hi Salame,
My contact This email address is being protected from spambots. You need JavaScript enabled to view it.
The mail is also visible here : codeberg.org/skynet
Thanks a lot for your proposal so far !!
It's in good hands, as it is used for development for our open source community.
- fake_name
07 Dec 2024 03:52 - 07 Dec 2024 03:54 #316154
by fake_name
That lets me localize things a bit, but could you possibly be a bit more explicit about dependencies? The version of qt6 packaged on debian 12 (current linuxcnc) seems to be too new, and it will not build:
Replied by fake_name on topic Ethercat auto configurator.
@Fakename
The links are broken indeed, the source has moved to :
codeberg.org/skynet/realtime_app/src/bra...dor/ethercat_twincat
It is part of a bigger project that used opencascade.
cnc@servobox:~/realtime_app/src/vendor/ethercat_twincat/build$ cmake ..
-- The CXX compiler identification is GNU 12.2.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Performing Test HAVE_STDATOMIC
-- Performing Test HAVE_STDATOMIC - Success
-- Found WrapAtomic: TRUE
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
-- Found WrapOpenGL: TRUE
-- Found XKB: /usr/lib/x86_64-linux-gnu/libxkbcommon.so (found suitable version "1.5.0", minimum required is "0.5.0")
-- Found WrapVulkanHeaders: /usr/include
-- Configuring done
-- Generating done
-- Build files have been written to: /home/cnc/realtime_app/src/vendor/ethercat_twincat/build
cnc@servobox:~/realtime_app/src/vendor/ethercat_twincat/build$ make -j4
[ 5%] Automatic MOC and UIC for target ethercat_twincat
[ 5%] Built target ethercat_twincat_autogen
[ 20%] Building CXX object CMakeFiles/ethercat_twincat.dir/main.cpp.o
[ 20%] Building CXX object CMakeFiles/ethercat_twincat.dir/ethercat_twincat_autogen/mocs_compilation.cpp.o
[ 20%] Building CXX object CMakeFiles/ethercat_twincat.dir/mainwindow.cpp.o
[ 25%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/ethercat_master/tool/Command.cpp.o
[ 30%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/ethercat_master/tool/CommandXml.cpp.o
[ 35%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/ethercat_master/tool/MasterDevice.cpp.o
[ 40%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/ethercat_master/tool/NumberListParser.cpp.o
[ 45%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/graphics_view.cpp.o
[ 50%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/form_node_port.cpp.o
[ 55%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/form_node_base.cpp.o
[ 60%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/form_node_port_out.cpp.o
[ 65%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/form_node_port_in.cpp.o
[ 70%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/graphics_node.cpp.o
[ 75%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/graphics_curve.cpp.o
[ 80%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/qcustomwidget.cpp.o
[ 85%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/qcustomtimerwidget.cpp.o
[ 90%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/qcustomscopewidget.cpp.o
[ 95%] Building CXX object CMakeFiles/ethercat_twincat.dir/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp.o
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp: In member function ‘Qt::Alignment QCPLayoutInset::insetAlignment(int) const’:
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:3121:12: error: invalid conversion from ‘int’ to ‘Qt::AlignmentFlag’ [-fpermissive]
3121 | return 0;
| int
In file included from /usr/include/x86_64-linux-gnu/qt6/QtCore/qglobal.h:1401,
from /usr/include/x86_64-linux-gnu/qt6/QtCore/qnamespace.h:8,
from /usr/include/x86_64-linux-gnu/qt6/QtCore/qobjectdefs.h:12,
from /usr/include/x86_64-linux-gnu/qt6/QtCore/qobject.h:10,
from /usr/include/x86_64-linux-gnu/qt6/QtCore/QObject:1,
from /home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.h:29,
from /home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:26:
/usr/include/x86_64-linux-gnu/qt6/QtCore/qflags.h:74:45: note: initializing argument 1 of ‘constexpr QFlags<T>::QFlags(Enum) [with Enum = Qt::AlignmentFlag]’
74 | constexpr inline Q_IMPLICIT QFlags(Enum flags) noexcept : i(Int(flags)) {}
In file included from /usr/include/x86_64-linux-gnu/qt6/QtCore/qglobal.h:1407:
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp: In destructor ‘virtual QCPItemAnchor::~QCPItemAnchor()’:
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:7461:47: error: ‘class QSet<QCPItemPosition*>’ has no member named ‘toList’
7461 | foreach (QCPItemPosition *child, mChildrenX.toList())
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:7466:47: error: ‘class QSet<QCPItemPosition*>’ has no member named ‘toList’
7466 | foreach (QCPItemPosition *child, mChildrenY.toList())
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp: In destructor ‘virtual QCPItemPosition::~QCPItemPosition()’:
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:7639:47: error: ‘class QSet<QCPItemPosition*>’ has no member named ‘toList’
7639 | foreach (QCPItemPosition *child, mChildrenX.toList())
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:7644:47: error: ‘class QSet<QCPItemPosition*>’ has no member named ‘toList’
7644 | foreach (QCPItemPosition *child, mChildrenY.toList())
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp: In member function ‘void QCustomPlot::replot(RefreshPriority)’:
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:10372:37: error: ‘HighQualityAntialiasing’ is not a member of ‘QPainter’
10372 | painter.setRenderHint(QPainter::HighQualityAntialiasing); // to make Antialiasing look good if using the OpenGL graphicssystem
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp: In member function ‘virtual void QCustomPlot::wheelEvent(QWheelEvent*)’:
/home/cnc/realtime_app/src/vendor/nodelib/qcustomplot.cpp:10855:53: error: ‘class QWheelEvent’ has no member named ‘pos’
10855 | if (QCPLayoutElement *el = layoutElementAt(event->pos()))
Last edit: 07 Dec 2024 03:54 by fake_name. Reason: WTF did the forum wysiwyg editor do
- fake_name
07 Dec 2024 03:59 - 07 Dec 2024 04:11 #316155
by fake_name
FWIW, I rolled back to qt5 and it builds.
I can get the binary in the referred directory () to build and run, but it doesn't seem to correctly identify my hardware, and I don't really understand what to do next. It seems to identify my servo driver (a Lichuan LC10-E) as a EK1100.
seems to show the correct process data objects, so I'm not sure what's going on.
If there's anything I can do to help (you want shell access? I should be able to figure something out) I'd be happy do contribute.
I also have a number of Lichuan ethercat stepper servo drivers, and a ethercat IO thingie (one of these: www.forum.linuxcnc.org/ethercat/52997-et...at-catio-module-help).
ethercat_twincatethercat pdosIf there's anything I can do to help (you want shell access? I should be able to figure something out) I'd be happy do contribute.
Last edit: 07 Dec 2024 04:11 by fake_name.
- Grotius
07 Dec 2024 11:42 #316175
by Grotius
Hi Fakename,
The executable "ethercat_twincat" start up with a default none name "EK1100".
See the mainwindow : node_ethercat = new graphics_node("EK1100",ports);
A better name should be something like : "Ethercat".
This is nice. That means the digital xml config is parsed succesfully.
Maybe this is not the best way to start figuring out things for you.
Best for you is maybe a minimal example where ethercat is showing your pdo config in gui, without
the usage of node's etc.
Then set some test values, to try to run the motors?
- Rkatts
10 Dec 2024 22:32 #316434
by Rkatts
And while I'm at it, what method do you use to build from source? I'm new to this. I'm just trying to disable EoE.
Replied by Rkatts on topic Ethercat auto configurator.
Sorry for the basic questions. Where do you enter that command? Do you put it in a file during the build process?hi,
if you are building ethercat-master from source... there is possibility to disable eoe on master during ./configure script for example./configure --sysconfdir=/etc/ --disable-8139too --enable-userlib --disable-generic --disable-eoe --enable-e1000e but I am fighting with them right now to install non generic driver because in responsitories is only generic possible ..
- onceloved
- Thank you received: 59
12 Dec 2024 10:38 #316506
by onceloved
Replied by onceloved on topic Ethercat auto configurator.
You can use the tool to export the drive sii file, then modify it to disable eoe and then flash it back
- endian
- Thank you received: 133
15 Dec 2024 13:45 #316706
by endian
Replied by endian on topic Ethercat auto configurator.
Yes it is possible did it in the many ways... but only working way for me was that to switch off the EoE master directly on the master...
I did it during ethercat installation ... install everything like a rodw has in his thread and then turn off ethercat master service ... and finally reinstall just ethercat master with right driver what is directly supported my hardware to supress the latency and then disable feature --eoe ...
I can did a terminal command manual if somebody needs them
- Tntmold
07 Jan 2025 22:17 #318357
by Tntmold
Replied by Tntmold on topic Ethercat auto configurator.
as a new linux user, can someone give tips on how to install/try this twincat utility?
- blazini36
- Thank you received: 167
08 Jan 2025 09:29 #318386
by blazini36
Replied by blazini36 on topic Ethercat auto configurator.
Now that's cool
Time to create page: 0.586 seconds
