Ethercat auto configurator.
- Grotius
- Thank you received: 2349
18 Nov 2024 12:46 #314750
by Grotius
Ethercat auto configurator. was created by Grotius
Hi Guys,
This file is a program for auto configuration for ethercat devices.
It don't need a .xml config file to setup your linuxcnc ethercat environment.
It uses a sligtly modified ethercat-master source code to retrieve a digital "$ ethercat xml".
And has a bug fix for inconsistent alias nr's.
This source code an be integrated to a linuxcnc component quite easely.
Therefore may be there are volunteers to do this.
As i tested this on the following bus configuration with succes, it's not tested to config servo's etc.
If i had a ethercat servo here, i would sure test it right away.
Example output :
Example output :
Starting EtherCAT master 1.5.2 done
init example 0.
init ethercat start.
Print ethercat devices and retrieve device data vector.
No alias given, alias -
pdo entry registration:
Name:EL2124 4K. Dig. Ausgang 5V, 20mA
Slave Alias: 0
Position: 1
Vendor ID: 2
Product Code: #x084c3052
PDO Entry Index: #x7000
PDO Entry Subindex: 1
Slave Alias: 0
Position: 2
Vendor ID: 2
Slave Alias: 0
Position: 3
Vendor ID: 2
Name:EL1004 4K. Dig. Eingang 24V, 3ms
Slave Alias: 0
Position: 4
Vendor ID: 2
Product Code: #x03ec3052
PDO Entry Index: #x6000
Name:EL2794 4K. Dig. Ausgang 24V AC/DC, 2A, kurzschlussfest
Slave Alias: 0
Position: 5
Vendor ID: 2
Product Code: #x0aea3052
Name:EL2808 8K. Dig. Ausgang 24V, 0.5A
Slave Alias: 0
Position: 6
Vendor ID: 2
Product Code: #x0af83052
Name:EL3162 2K. Ana. Eingang 0-10V
Slave Alias: 0
Position: 7
Vendor ID: 2
Product Code: #x0c5a3052
PDO Entry Index: #x3101
Slave Alias: 0
Position: 7
Vendor ID: 2
PDO Entry Subindex: 2
Slave Alias: 0
Position: 7
Vendor ID: 2
PDO Entry Index: #x3102
Slave Alias: 0
Position: 7
Vendor ID: 2
Slave Alias: 0
Position: 0
Vendor ID: 0
Product Code: #x00000000
PDO Entry Index: #x0000
PDO Entry Subindex: 0
halpin names:
EL2124_1_0_0_IN_BOOL
EL2124_1_1_0_IN_BOOL
EL2124_1_2_0_IN_BOOL
EL2124_1_3_0_IN_BOOL
EL2124_2_0_0_IN_BOOL
EL2124_2_1_0_IN_BOOL
EL2124_2_2_0_IN_BOOL
EL2124_2_3_0_IN_BOOL
EL2124_3_0_0_IN_BOOL
EL2124_3_1_0_IN_BOOL
EL2124_3_2_0_IN_BOOL
EL2124_3_3_0_IN_BOOL
EL1004_4_0_0_OUT_BOOL
EL1004_4_1_0_OUT_BOOL
EL1004_4_2_0_OUT_BOOL
EL1004_4_3_0_OUT_BOOL
EL2794_5_0_0_IN_BOOL
EL2794_5_1_0_IN_BOOL
EL2794_5_2_0_IN_BOOL
EL2794_5_3_0_IN_BOOL
EL2808_6_0_0_IN_BOOL
EL2808_6_1_0_IN_BOOL
EL2808_6_2_0_IN_BOOL
EL2808_6_3_0_IN_BOOL
EL2808_6_4_0_IN_BOOL
EL2808_6_5_0_IN_BOOL
EL2808_6_6_0_IN_BOOL
EL2808_6_7_0_IN_BOOL
EL3162_7_0_0_OUT_UINT
EL3162_7_0_1_OUT_UINT
EL3162_7_1_0_OUT_UINT
EL3162_7_1_1_OUT_UINT
PDO entry registration ok.
Master ok.
domain1_pd ok.
init ethercat succes.
The following user(s) said Thank You: tommylight, besriworld, CORBETT, sharp_reaper, Rabin, 7strideR
- Thank you received: 7465
18 Nov 2024 13:03 #314751
Replied by tommylight on topic Ethercat auto configurator.
Pinned.
Thank you.
Thank you.
- CORBETT
- Thank you received: 113
18 Nov 2024 21:50 #314804
by CORBETT
Replied by CORBETT on topic Ethercat auto configurator.
Grotius,
Nice work... As always, glad to see you and the other main players still here working on things. Awesome!!!
The following user(s) said Thank You: tommylight, besriworld, Grotius
- Grotius
19 Nov 2024 14:34 #314847
by Grotius
Replied by Grotius on topic Ethercat auto configurator.
To create a program like twincat for linux i made a little example,
how we can do this.
Here is a little project that show's the ethercat configuration.
It dynamicly add's button's, labels and checkboxes.
It includes reading and writing a few value types. But can be expanded
to read & write more ethercat data types.
This works nice.
I think we can also modify the linuxcnc-ethercat source to automate the .conf process.
how we can do this.
This works nice.
The following user(s) said Thank You: tommylight, bkt, 7strideR, T-Roller
- Grotius
19 Nov 2024 21:30 #314876
by Grotius
Maybe we can add a node configurator.
This then can be used to simulate the ethercat devices, by adding controls, like buttons, etc. for interaction.
And eventually it could be used as a plc controller, when adding logic just as classicladder.
It seems beckhoff has twincat for linux, running on debian. But it is not open source.
Did they write the ethercat master for linux themselfves?
They say in linux you can run multiple instances of twincat.
- Grotius
24 Nov 2024 22:38 #315192
by Grotius
Hi guys,
Related to the previous post, where i was struggeling with a node library for too long time.
I had to make a choice what to do.
1. Just don't use the qtnodeeditor lib.
2. Don't use node structure's.
3. Try to create your own lib.
Choosed nr.3.
It took a few day's to figur out how the qt grapics widget works. And how to display qt widget in it.
Then made a solution for creating a simple setup for input, output ports and their widgets.
In the end, the result surprised me.
This is a test video, that loads a few input and output ports, and widgets attached to the port.
Then you can connect the output ports with the input ports. Data flow will stream then from output to input.
This whole idea can be used to format several big and complicated projects, like :
1. rtapi multi threading on several cpu's.
2. super imposed interpreters, running on multiple threads.
3. cnc machine interpreter to machine axis layout. Like connecting ABC, UWV axis.
4. Ethercat bus simulator on real hardware.
5. Plc
6 Classic ladder
User can just create .ui based widgets. This is easy to design. Each .ui widget then may have multiple input or output ports.
The logic is then done by the .ui class, wich conttains also the .h and .cpp files.
Let me know what you think, this is just an example :
Greetings.
Choosed nr.3.
5. Plc
6 Classic ladder
Greetings.
The following user(s) said Thank You: tommylight, onceloved, Rabin
24 Nov 2024 23:13 #315200
To much time with Blender?
I foresee a lot of happy people, thanks to you.
- Grotius
24 Nov 2024 23:24 #315202
by Grotius
Hi Tommy,
Thanks.
No blender is used so far !
What you see are original qt widgets.
Maybe. Hahah.
A lot off people are also happy with you, including me.
But most won't see the source code as we are hosted on codeberg.
This is a non profit organisation from Berlin Germany.
The source code so far:
codeberg.org/skynet/nodelib#readme
Good night all folkes.
Thanks.
Maybe. Hahah.
- Grotius
26 Nov 2024 11:33 #315288
by Grotius
Node video sofware :
Node video hardware:
youtube.com/shorts/kOSrcHN5y7o
The ethercat auto configurator app is now able to perform logical operations. Like a plc.
Made a example timer widget. That sends pulses to the ethercat output ports.
The pulse has a high- and low time.
There is a easy way to create your own logical widgets. Creating a new widget cost's about 15 minutes of your presious time.
There is a QCustomWidget example widget that shows you how to do it.
We can use all kind of widget's here.
Project source
Project source
- Grotius
26 Nov 2024 13:40 - 26 Nov 2024 13:48 #315296
by Grotius
Last edit: 26 Nov 2024 13:48 by Grotius.
The following user(s) said Thank You: tommylight, bkt, endian, T-Roller
Time to create page: 0.666 seconds
