  • ianlowe
  • ianlowe
23 Sep 2026 20:29
Spindle temperature control was created by ianlowe
Category: Driver Boards
I have a Jianken 3.2kw spindle that has a NTC 103F3950 (10 kΩ, B=3950) thermistor and a Thermal fuse / PTC-type cutoff.
My controllers are Mesa 7i76e + 7i78 + 7i89.
How do I make use of these and connect them to my controllers.
  • tuxcnc
  • tuxcnc
23 Sep 2026 19:33
7i97T - Custom bitfile request (High-speed 200MHz Encoder for Linear Motors)
[code][code]my high-resolution optical scales (...) are dropping pulses during high acceleration
[/code][/code]
Acceleration has nothing to do with it.
Only maximum speed matters.
From the resolution and speed you will calculate the pulse frequency.
  • Gotrune
  • Gotrune
23 Sep 2026 19:16
Hi PCW,
Thank you so much for the incredibly fast reply!
I will add setp hm2_7i97.0.encoder.muxed-sample-frequency 20000000 to my HAL file right away and test the machine.
Just to make sure I fully understand the limits of the hardware: what are the acceptable or maximum values for this parameter with the standard 7i97T bitfile? For example, does it need to be a specific integer divisor of the base clock? Also, at what frequency would I typically need to start adjusting the muxed-skew parameter you mentioned?
Thanks again for your time and excellent support!
  • PCW
  • PCW's Avatar
23 Sep 2026 18:29
I would try setting:
to say 20 MHz
(you can probably go higher by futzing with the muxed- skew parameter)
  • Gotrune
  • Gotrune
23 Sep 2026 18:03
Hi PCW,
I am currently retrofitting a machine with a Mesa 7i97T and JAT Ecovario drives controlling permanent magnet linear motors.
My problem is that my high-resolution optical scales (1µm/step which are passed-through directly from the drives, with no hardware division possible) are dropping pulses during high acceleration, even with "filter 0" set in my HAL file. The minimum edge separation of the raw encoder signals is too tight and violates the standard MuxedQCount clock limit.
Could you please compile a custom bitfile for the 7i97T where the encoder counting module clock is bumped to 200MHz (or the maximum possible frequency for this FPGA) to handle these extremely fast edges?
I only need the standard 7i97T I/O pinout, just with the fastest possible encoder sampling.
Thank you in advance!
  • geebee
  • geebee
23 Sep 2026 17:53
Replied by geebee on topic 7i95t firmware flash
mesaboard is on 2. enp8s0 (see alsö static inet/inet6 addresses) It does show no carrier when unplugged.
eno1 (internet) has automatic connection method.
wlan has been turned off in order not to get confused.
I changed lan cables and now it behaves as it should mesact/machine finds the board and readhmid provides the information as expected.(mesact and terminal)
I wasnt aware of that since I did have acces to the internet anyhow(???).
so thank you very much for the moment This particular problem is solved.
Have nice days
geebee
  • viesturs.lacis
  • viesturs.lacis
23 Sep 2026 17:19 - 23 Sep 2026 18:18
Replied by viesturs.lacis on topic lcec_conf exited without becoming ready
Category: EtherCAT
please find attached 3 screenshots - left side are all the pins for cia402 component (they did all fit in screen) and right side is list of lcec pins in terminal. do you have any idea, which of these is "enable" pin? lcec.0.state-preop, lcec.0.state-safeop and lcec.0.state-op seem suspicious to me but then I do not understand why would 3 pins be needed. I would appreciate some hints on which pins should I try for enabling the drive and which would be most suitable candidate for making the motor spin. cia402.0.velocity-cmd would seem like most obvious candidate but is there anything else to add (so far in my experience it would have been 2 pins - one sets velocity, the other would be a bit output for "run/stop")
BTW cia402.0.controlword has value 4, which seem to match instructions in manual to set the parameter 50.04 to 4 (which means that reference is speed). does that help in any way? and since the manual says this:"Ensure the drive profile parameter 51.02 is set to CiA402 (0)" I would like to think that it's all good regarding the suspicion about needing different mode rather than cia402.
could you please share some link where I could see some cia402 templates that you mentioned?
  • geebee
  • geebee
23 Sep 2026 16:11
I just try to set the card to work.
For the beginning, I want it to get a single stepper motor to turn with nothing else connected to it. For this, I need to configure some hal and ini files. I can use mesact but not pncconf for this.Later, I will analyze and try to understand these first files according to linuxcnc docs. What i intend to do is retrofitting a lathe to cnc (two, maybe three axes) , an additional axe for an attached lathe and on for a dividing head and some encoders /DRO This is all I might need in the (far) future.
Right now, I would just be happy to get linuxcnc, mesact ,board and stepper (driver) "Talk to one another".
cheers
geebee
  • PCW
  • PCW's Avatar
23 Sep 2026 16:05
Replied by PCW on topic 7i95t firmware flash
OK so the next question is which Ethernet interface is the 7I95T connected to?
(enp8s0 or eno1)
(quick way to check is unplug the 7I95T RJ45 cable and see which interface shows "NO-CARRIER"
  • geebee
  • geebee
23 Sep 2026 15:54
copy from terminal :
eebee@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 9c:53:22:48:4a:55 brd ff:ff:ff:ff:ff:ff
altname enx9c5322484a55
inet 10.10.10.1/24 brd 10.10.10.255 scope global noprefixroute enp8s0
inet6 2003:ca:745:4b0:8af0:56c3:81dc:59d1/64 scope global dynamic noprefixroute
valid_lft 172796sec preferred_lft 86396sec
inet6 fe80::1f98:abff:6d07:69fe/64 scope link noprefixroute
3: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 50:46:5d:6f:50:7c brd ff:ff:ff:ff:ff:ff
altname enp0s25
altname enx50465d6f507c
4: wlp7s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 6a:9d:f2:44:dc:7d brd ff:ff:ff:ff:ff:ff permaddr 64:70:02:18:5d:b8
altname wlx647002185db8
geebee@debian:~$
23 Sep 2026 15:33
Replied by tommylight on topic 7i95t firmware flash
Sorry, i forgot to ask, why would you flash the 7i95T ?
23 Sep 2026 15:31
Replied by tommylight on topic Flex GUI 2.1.0 OpenGL 3.3
Category: Flex GUI
IMHO GUI's should not be included in the main repo except for Axis so as to not drag in a huge amount of dependencies for nothing.
If anyone asked me to decide what way to go, i would be very hard pressed to decide as i see benefits on both sides.
Should i elaborate?
  • muddiver
  • muddiver
23 Sep 2026 15:21 - 23 Sep 2026 15:37
Kommunikation mit Mesa 7i92 sehr instabil, Woran kann es liegen?
Category: Deutsch
Hi FOrum!
i have a Foxconn A74 Mainboard with 4GB DDR3_Ram, AMD Athlon X2 250 3Ghz.
I tried to upgrade to a graphicscard, i bought an Asus Radeon R7 240 with 2GB of DDR3 Vram.
Now my problems.. The latency overall is the same as with the onboardgraphics, bit i have massive spikes, up to 600000..
I tried:
1.  Grub "radeon.dpm=0"
no luck, LinuxCNC greets me with a Readerror.
2. Grub "radeon.si_support=0 amdgpu.si_support=1 amdgpu.dpm=0"
no luck, LinuxCNC greets me with a Readerror. I checked which driver is used, it was amdgpu, but no luck.
As far as i can tell, the version without any kerneltweaks worked the best for me.
I have 1 Core isolated for LinuxCNC, nothing fancy in grub customized.
Is there anything i can try to get the graphicscard to work properly?
Thank in advance, greets, TOm
  • hermann1976
  • hermann1976's Avatar
23 Sep 2026 15:20
Replied by hermann1976 on topic NativeCAM auf Linuxcnc 2.9
Category: Deutsch
Ich freue mich auch sehr darüber das NativCAM eine aktuelle Überarbeitung bekommt und bin allen dankbar die daran arbeiten.
Ich bin jemand der auf einer CNC umgebauten Langlochbohrmaschine Kleinigkeiten bearbeitet. Das was halt so in einer Tischlerei anfällt...
Hierzu ist NativCAM ein top Programm dafür.
So ähnlich wie WoodWop für eine Homag Maschine. Hier wird auch vieles an der Maschine programmiert.
Ich bin mir sicher, das dieses Programm künftig noch viele Möglichkeiten bietet. Ich werde mir mal die neue Version installieren und mich damit intensiver beschäftigen. Die derzeit installierte Version läuft leider etwas labil.
Danke an alle die diese Software am leben erhalten....
Displaying 721 - 735 out of 11520 results.
Time to create page: 0.203 seconds
