  • tuxcnc
  • tuxcnc
16 Sep 2026 14:58
loading debian 10 on a very old compaq Presario dual boot
Category: Installing LinuxCNC
It's hard to help you when we don't know what you're doing, how you're doing it and why you're doing it.
It happens that the installer has a problem using a partition formatted in a different operating system or with specific programs. Then the actual solution is to tell him to format the partition in his own way.
The rest of your post has no sense and difficult to respond to.
  • 858PSJ
  • 858PSJ
16 Sep 2026 13:10
Had  three problems loading the Debian 10 iso (from a dvd I made)
1. the download script would not get past the step where it partitioned the disk until I used the menu option to format partition #3.
(I even waited whilst the script wrote 90 GB of zeroes on that drive, before discovering the format fix)
2. The UUIDS in the grub .cfg file were changed (somehow) to where they were incorrct for my other linux kernel, although the UUIDS for debian were correct.  the /etc/fstab file for my other OS was adjusted to where the UUID entry were removed from that file, /etc/fstab for debian were correct and included swap)
3. Debian would crash on booting until I removed the boot=plainroot option from the debian vmlinux line in grub.cfg. (I also removed the quiet option)
  • JT
  • JT's Avatar
16 Sep 2026 12:06 - 16 Sep 2026 12:08
Replied by JT on topic Probe panel for Axis GUI
Category: AXIS
The function debounce is in 2.7
Can't find module 'dbounce' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
while executing
"hal loadrt dbounce names=dbounce_probe"
JT
  • JT
  • JT's Avatar
16 Sep 2026 12:05
Flex GUI 2.1.0 OpenGL 3.3 was created by JT
Category: Flex GUI
Thanks to one of the guys on the IRC Flex GUI now supports OpenGL 3.3 and works with Master aka 2.10
JT
  • andrax
  • andrax's Avatar
16 Sep 2026 07:30
Replied by andrax on topic EtherCAT Master Beckhoff slave not found
Category: Basic Configuration
Alle Hall Pins müssen einen eineindeutigen Namen haben.
Am besten benennst du die Pins nach der jeweiligen Achse, das macht die die spätere Zuordnung einfacher.
halPin="out-controlword" >>> halPin="X-out-controlword"
halPin="out-controlword" >>> halPin="Y-out-controlword"
halPin="out-controlword" >>> halPin="Z-out-controlword"
  • CNC_Tux
  • CNC_Tux
16 Sep 2026 07:14
Replied by CNC_Tux on topic XHC-WHB04b-6 freeze in issue fixed !!
Hello Linuxcnc Friends,
i abused the WHB04b-6 with a bad behavior and i found some smal bugs again.
Here are now the final and stable version of the drivers for Linuxcnc 2.9.10 and the hal.cc for the guys they want compile by himself to use in other versions
Best Regards
Reinhard
File Name: hal.zip
File Size:8 KB
File Name: xhc-hb04.zip
File Size:55 KB
File Name: xhc-whb04b-6.zip
File Size:547 KB
  • aDm1N
  • aDm1N's Avatar
16 Sep 2026 06:31
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
A lot has changed in LatheEasyStep over the past few weeks. Much of the work has focused on further improving the existing machining functions and making the generated toolpaths more reliable.In particular, internal machining has been significantly revised. Internal contours can now be processed regardless of the Z direction in which the contour was originally defined. Roughing and finishing have been corrected accordingly, and the approach and retract movements for internal machining have also been revised.There have also been several improvements to contour machining. G1/G2/G3 geometry is now preserved more consistently, so arcs are no longer unnecessarily converted into straight-line segments. Relief grooves have also been further improved, including the automatic positioning of DIN 76 thread reliefs at the actual end of the thread.The handling of tool changes, retracts and safety movements has been revised in several areas. The same applies to switching between G96 and G97, as well as various plausibility checks intended to detect invalid or unreasonable inputs before G-code is generated.The preview has also received further work. The side view, front view and cross-sectional view have been revised, and the representation of the different machining operations has been made more consistent.Another improvement that is clearly noticeable in everyday use is the panel startup time. At one point, startup took more than 20 seconds. The initialization process has since been revised, and tasks that are not immediately required are now performed only when needed. As a result, the panel now starts significantly faster.The user interface and language system have also been further revised. In addition to German and English, Spanish is now fully available. All visible text is managed through external language files, allowing additional languages to be added without modifying the program code.The current development branch is now 0.8.0-dev. For the 0.8.0 release, only a few targeted acceptance checks remain, including facing with a radius and final checks for internal machining and the DIN 76 thread relief.After that, 0.8.0 is intended to provide a defined state of the existing machining functions before development continues towards 0.9.0.
  • tietouwa
  • tietouwa's Avatar
16 Sep 2026 02:27
J1900 L2 sibling: pin Qt HMI to CPUs 0-1, keep the 1 ms EtherCAT thread on CPU3
Category: EtherCAT
Not a LinuxCNC install. Same class of box as the earlier J1900 eglfs vs Xorg thread.Posting because the useful knob was not another kernel cmdline flag.
Intel Celeron J1900 has 2 MiB L2 as two 1 MiB slices:
CPUs 0-1 share one L2
CPUs 2-3 share the other L2
We already isolated the EtherCAT loop on CPU3 (SCHED_FIFO 80, 1 kHz).
That is not enough if the fullscreen Qt/eglfs HMI is still allowed on CPU2.
The UI then sits on the L2 sibling of the RT core and contends for the same 1 MiB.
Change (HMI only, not a whole-system cgroup):
before: Qt main / touch / QML / render / GPU worker allowed on CPUs 0-2
after: those threads allowed on CPUs 0-1 only
RT thread stayed on CPU3 both times
Same binary, same recipe, same 1 ms period, 20 automatic press cycles each side.
Jitter = wake-to-wake CLOCK_MONOTONIC minus 1 ms, integer microseconds.
0 us means |error| < 1 us. This is period error, not latency-test / cyclictest.
All numbers below are the full captures (approach + press + retract), not a PID subset.
Absolute jitter, nearest-rank, all samples
UI on 0-2 (20 runs) UI on 0-1 (20 runs)
n 119159 119254
P50 0 us 0 us
P95 6 us 1 us
P99 13 us 1 us
P99.9 21 us 2 us
signed min/max -42 / +46 us -13 / +14 us
|j| >= 10 us 2983 8
|j| >= 20 us 198 0
|j| >= 30 us 22 0
|j|
Per-run P50 / P95 / P99 / P99.9 (|jitter|, us)
# UI 0-2 UI 0-1
1 1 / 9 / 14 / 23 0 / 1 / 1 / 2
2 0 / 2 / 9 / 19 0 / 1 / 1 / 2
3 0 / 5 / 12 / 21 0 / 1 / 1 / 2
4 0 / 6 / 15 / 20 0 / 1 / 1 / 2
5 0 / 7 / 15 / 20 0 / 1 / 1 / 2
6 0 / 1 / 1 / 2 0 / 1 / 1 / 2
7 0 / 6 / 14 / 20 0 / 1 / 1 / 2
8 0 / 7 / 15 / 20 0 / 1 / 1 / 2
9 0 / 4 / 13 / 19 0 / 1 / 1 / 2
10 0 / 6 / 16 / 26 0 / 1 / 1 / 2
11 0 / 3 / 11 / 22 0 / 1 / 1 / 3
12 1 / 9 / 15 / 23 0 / 1 / 1 / 2
13 1 / 9 / 14 / 26 0 / 1 / 1 / 2
14 1 / 9 / 15 / 32 0 / 1 / 1 / 2
15 0 / 8 / 14 / 19 0 / 1 / 1 / 2
16 1 / 9 / 14 / 26 0 / 1 / 1 / 2
17 0 / 1 / 6 / 13 0 / 1 / 1 / 2
18 0 / 6 / 13 / 19 0 / 1 / 1 / 2
19 0 / 1 / 5 / 15 0 / 1 / 1 / 2
20 0 / 1 / 1 / 2 0 / 1 / 1 / 2
After the pin, every run has P99 = 1 us. 15/20 runs have max |j|
The 8 remaining >=10 us samples are two ticks each in runs 1, 8, 15, 16.
Point of the numbers
- P50 was already 0 us. The HMI was not ruining the median.
- The L2 sibling shows up in the tail: P95 6->1, P99 13->1, P99.9 21->2.
- Moving i915 IRQ off CPU2 was not sufficient by itself. User-space Qt
render can still land on CPU2 and thrash the RT core's L2.
- Do not set a cgroup AllowedCPUs=0-1 on the whole process: the FIFO
thread must still be able to bind to CPU3.
- Do not park every system thread on 0-1. This was only the HMI/render path.
Box (for context, not the variable under test)
- Debian 13 PREEMPT_RT 6.12, Qt eglfs_kms, no X
- IgH EtherCAT, 1 kHz, Lost frames = 0
- isolcpus / rcu_nocbs on CPU3, i915 IRQ on CPU0
Happy to hear if anyone running a GL HMI on Bay Trail saw the same
CPU2/CPU3 L2 pairing.
  • ncf250sd
  • ncf250sd
16 Sep 2026 01:06
Probe basic error was created by ncf250sd
Probe basic error
Category: QtPyVCP
I just updated to the latest probe basic (Probe Basic APT Stable Install Bookworm 12).  I do not use an ATC.  Everything is working as it was before the update except I get this error (Error Named parameter #<number_of_pockets> not defined ) when trying to load a tool utilizing the Tool Change Panel (load tool).If I load a tool from the main screen it works fine.  I can even use the Tool change panel to unload the tool.  I have looked through my ini file and cannot see anything out of place.  Any suggestions on where to start looking would be appreciated.
  • rhscdn
  • rhscdn
16 Sep 2026 00:22
Replied by rhscdn on topic XHC-WHB04b-6 freeze in issue fixed !!
I've encountered this bug many times. Thanks for posting.
  • rodw
  • rodw's Avatar
15 Sep 2026 20:48
Replied by rodw on topic XHC-WHB04b-6 freeze in issue fixed !!
A better solution should be to submit your changes to LinuxCNC as a PR.
  • rodw
  • rodw's Avatar
15 Sep 2026 20:37
2.9.4 uspace: interpreter stops reading ahead mid-session severe stuttering
I would upgrade to 2.9.10 and see if it persists.
If it does, learn how to do a run in place install of master branch 2.10pre and try there.
Then, post as an issue on GitHub where it will be reviewed but the devs.
  • PCW
  • PCW's Avatar
15 Sep 2026 19:12 - 15 Sep 2026 19:30
Mesa 7i96s to Gecko G540 with simple 3 axis Router
If the G540 is connected to the 7I96S parallel expansion connector, you should use
7i96s_g540d.bin firmware, that configures the 7I96S's P2 expansion connector the G540
pinout, Then basic setup can be done with pncconf. No need for AI, that just a time sink here.
  • PCW
  • PCW's Avatar
15 Sep 2026 18:58
Replied by PCW on topic 7i98 and 5abobx3 firmware
Category: PnCConf Wizard
You're welcome.
Once you are setup, it relatively easy to make a new configuration in a few minutes.
Displaying 856 - 870 out of 11520 results.
Time to create page: 0.741 seconds
