  • andrax
  • andrax's Avatar
11 Jan 2026 13:03
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
I don't know what the problem is. It's always the left Y-axis that sporadically fails to start during homing. I always have to turn the machine off, and then it usually works. There haven't been any problems after homing so far. I can rule out wiring issues because I would get an error message.
I think that for some reason, the servo occasionally doesn't receive a start command for homing and therefore doesn't start.
The error must be somewhere in my configuration.
  • hhscott
  • hhscott
11 Jan 2026 12:38
Replied by hhscott on topic Startup Question
Startup Question
Great! Thank you
  • 5_Zylinder
  • 5_Zylinder
11 Jan 2026 12:21
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
Hello everyone, after a long break, I've started modifying my Hruco again.
A quick overview of the setup: I have a 7I97 mainboard, and I've connected a 7I74 to it to expand the ports.
I've connected a 7IAO (Port 1) and a 7I89 (Port 2) to the 7I74.
I noticed that the 7IAO also has a Xilinx Spartan-6 FPGA, but I assume it already has a basic bitfile on it that I could flash via the pins on the chip, but I don't have to if it's not necessary.
Am I correct in this assumption, or do I also need to flash my own bitfile onto the card?
Now for the second part of my question.
I wanted to create a suitable bitfile for the four cards I mentioned above.
What software would be best to use for this?
Since the FPGAs are from Xilinx, I'll probably have to use their software so the IC can understand the bit file, so Vivado, right?
I also saw something online from Efinix, but those are different ICs.
The software probably won't be compatible with them, will it?
  • MaHa
  • MaHa
11 Jan 2026 12:15
Replied by MaHa on topic Startup Question
Startup Question
yourmachine.ini  file,  in  [TRAJ]  section  POSITION_FILE = posfile.txt   stores machine positions at shutdown. If this is not set, the machine starts with all axes set to zero
  • johnbl
  • johnbl
11 Jan 2026 12:09
Replied by johnbl on topic LinuxCNC S-Curve Accelerations
Can you elaborate on what are these architectural issues?
11 Jan 2026 11:59
Replied by tommylight on topic StepperOnline A6 Servo
Category: EtherCAT
Have you ever had the problem where one of the Y-axes doesn't start moving during homing and the gantry is crooked?
That happens to me a lot. I have to restart the machine and then it works again.
That should not happen, ever, and it did not happen as i have probably over 15 machines with tandem joints, some industrial ones with over 400KG heavy gantries.
You should check the wiring first, then test the failing side drive.
Are you using the same drives mentioned here?
  • grandixximo
  • grandixximo's Avatar
11 Jan 2026 11:44
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I've checked all the reported spikes, and the issue is not the new s-curve in itself, but the trajectory planner architecture, we will have to do a much more involved refactoring, will look at Tormach work, maybe talk with Rob if that happens, and take it from there.
The current scurve is best that can be done within the limitations of the current tp architecture.
  • deckname
  • deckname
11 Jan 2026 11:30
Replied by deckname on topic QtPlasmaC + CoreXY Kinematics
Thanks for the reply
I tried corexykins, didn´t work because i use uspace?
so i went with KINEMATICS = corexy, which then caused problems with loadrt [KINS]KINEMATICS and loadrt [EMCMOT]EMCMOT...
Why are home switches necessary? I dont have the machine connected at the moment since I´m only trying to get the software to start.
Is this combination of software even the right choice?
I´m building a small portable plasma cutter while using some parts of an old 3d printer and i would really like to use corexy.
Are there other GUIs that work better with this?
  • 3404gerber
  • 3404gerber
11 Jan 2026 11:27
Edit: Launched linuxcnc on terminal, getting "bad spi payload"
(Bad SPI payload = 32393a38)
The value of the payload is strange; it's almost half value of what you are suppose to get:
#define PRU_DATA            0x64617461     // "data" SPI payload
#define PRU_READ              0x72656164  // "read" SPI payload
#define PRU_WRITE             0x77726974  // "writ" SPI payload
#define PRU_ESTOP           0x65737470  // "estp" SPI payload
I'd try with a lower SPI frequency.
  • RotarySMP
  • RotarySMP's Avatar
11 Jan 2026 11:25 - 11 Jan 2026 11:26
Retrofitting a 1986 Maho MH400E
Category: Milling Machines
The Maho is back up and running again, but I still dont really know what the FError and MinFError "should" be for such a machine.
Thanks for your help.
  • hhscott
  • hhscott
11 Jan 2026 10:49
Startup Question was created by hhscott
Startup Question
Simple question that I cannot seem to locate the answer:
No matter what offset I was using when I shutdown LinuxCNC I want my DROs to read 0 after I restart and then home. I can do this with the Touch-Off button in Axis but how do I set my INI/HAL file to clear offsets when LinuxCNC restarts?
Of is there a mdi input that would have the same outcome?
Thanks,
HH
  • andrax
  • andrax's Avatar
11 Jan 2026 10:36
Category: EtherCAT
Hi, that looks really good.
How stable is your system?
  • dschultz
  • dschultz
11 Jan 2026 01:14
Replied by dschultz on topic StepperOnline A6 Servo
Category: EtherCAT
It's been almost a year since I originally started this thread and thought it might be of interest to give a status update on my machine.It's been humming along without issue powered by the A6 400watt AC ethercat servos.It is a 4x4 size router direct driven with ballscrews on all axis (XYYZ). I highly recommend the A6 servos for simple set-ups. Mine is not a demanding setup but for the cost, in my opinion they are an unbeatable value. Thank-you to those that gave me pointers when I was making the transition from step drive to ethercat!
10 Jan 2026 23:43
Replied by tommylight on topic QtPlasmaC + CoreXY Kinematics
That will most probably require a bit more hand editing as you also need to have some of the contents of 3joint_xyz.hal, but i do not recall exactly what or how, it was a long time ago since i used this.
Did you try changing the kinematics in the in file to
KINEMATICS = corexykins
And did that produce any result?
But first, does the machine have home/limit switches on X and Y ? That is a must.
  • deckname
  • deckname
10 Jan 2026 23:32
QtPlasmaC + CoreXY Kinematics was created by deckname
Hi everyone, i´m new here.I’m having major issues getting my LinuxCNC setup to work with QtPlasmaC and CoreXY kinematics.My setup:
  • LinuxCNC 2.9.6
  • Mesa 7i96s Ethernet + 3 steppers (X, Y, Z)
  • QtPlasmaC GUI
  • CoreXY kinematics (tried corexykins and corexy_by_hal)
QtPlasmaC seems to try to access pins and signals that don’t exist with CoreXY kinematics.
I had previously tried running the machine with SCARA kinematics, but I naively thought CoreXY would be simpler.
Is a setup like this possible for a beginner or should i try a different approach?
Why are kinematics that complicated and troublesome anyways?
Thanks in advance for any help!
Displaying 8581 - 8595 out of 12662 results.
Time to create page: 0.674 seconds
