  • cdamm11
  • cdamm11
13 Dec 2025 16:27
Replied by cdamm11 on topic 6i25 and 7i77 config
Category: Driver Boards
Yes the PC is in metal housing and right now it is outside the control cabinet. I am confident this is not a EMC issue.
i have bought a much older pc which i will test tommorow.
thanks so far.
  • PCW
  • PCW's Avatar
13 Dec 2025 16:15 - 14 Dec 2025 04:08
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
is
hm2_7i80.0.pwmgen.00.enable <== j6-amp-enable
true when you expect PWM output?
Your firmware has PWMGEN 0 enabling all 7I54 PWMgens
If this is not desirable you leave the enables as GPIO
bits.
  • Ismacr63
  • Ismacr63
13 Dec 2025 16:05 - 13 Dec 2025 19:45
Replied by Ismacr63 on topic VFD configuration help
Category: Turning
Thanks for your reply. That works fine, except I can't use the three-position switch for forward and reverse.
I've also noticed that when I press the stop button, I have to hold it down until the motor stops completely. If I release it before the motor stops, it doesn't stop and the RPMs increase again.
I'll keep this VFD (A2 8015) for a belt sander I'm building.
I bought another VFD, a Suswe SU600, for the lathe, and I'd like to do the same as with the other one: add a three-position switch for forward and reverse, and a start/stop button.
  • NWE
  • NWE's Avatar
13 Dec 2025 15:22
Replied by NWE on topic 6i25 and 7i77 config
Does the pc have a metal housing (shielded), with the 6i25 inside? Or is it a motherboard mounted in a cabinet that also contains a VFD, relays, etc? If so, your motherboard will likely need additional shielding.
13 Dec 2025 15:18
Replied by tommylight on topic 6i25 and 7i77 config
Find or borrow a used PC.
  • cdamm11
  • cdamm11
13 Dec 2025 15:08
the pc only reboots when i try to run my configuration. i can run Sample configurations like "axis". But when i try to run the config i created using pncconf wizard the pc just reboots. i also does this if i try to Open Loop test or test / tune axis.
  • unknown
  • unknown
13 Dec 2025 14:40
Replied by unknown on topic Linuxcnc Rpi4/5 Images
Category: Installing LinuxCNC
langdons as these are release candidates I would prefer if these are only available from the links on my github page. If you have any images with rcX in the file name on your server could you please kindly remove them.
13 Dec 2025 14:40
No, not really, you will need another PC at least.
Lets clear something up first, does the PC reboot when turning ON the Mesa cards, or, when running LinuxCNC ?
13 Dec 2025 14:37
Replied by tommylight on topic Clearpath HLFB amp.joint.delay
Category: HAL
@Spumco,
Thank you for reminding me, now i know why i can not recall what was going on as i am used to ignoring everything having to do with clearpath since back when they were selling stepper motors and labeling them as "revolutionary servo motors" for a lot more $, and i think they still do, but now with encoder feedback.
  • spumco
  • spumco
13 Dec 2025 14:26
Replied by spumco on topic Clearpath HLFB amp.joint.delay
Category: HAL
Thank You for that looks like the .hal file is correct now I am assuming I dont have correct settings in the motors thought it would fault if power/loss of com .
or am I missing a config for that?
This is why I suggested the FIRST thing was to verify/edit the motor programming using the Clearpath software.
You cannot successfully edit/adjust HAL unless you know exactly what the motor(s) HLFB output is doing under various conditions.
Power up the motors - no need to enable in LCNC - connect a Windows computer to the motors and open the Clearpath software.  Verify that all motors' HLFB output is set to 'Servo On.'
Check your LCNC input pins are working correctly.  You can enable/disable the motors using the Clearpath software (overriding LCNC's output).
While you enable/disable the motors via Clearpath software, two things should happen:
  • The Clearpath software display should show 'servo on' in the output monitor
  • LCNC halshow input pins should be high/yellow when enable is true, and low/dark when the motor is not enabled
@tommylight - Clearpath motors have no separate drives.  The motors are supplied with DC power and all programming/control stuff is mounted internally in the motor itself.  They have three inputs (enable + A + B), and a single output (HLFB) that can be programmed to do different things.
  • vibram
  • vibram
13 Dec 2025 13:54
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
some little progress made, I managed to flash the EEPROM, the name of the device changed and I don't see the input/output anymore.
However, I m not able to pass the INIT step
  • vibram
  • vibram
13 Dec 2025 12:53 - 13 Dec 2025 13:06
  • cdamm11
  • cdamm11
13 Dec 2025 12:38
Hi Tommy!
The PC only has 1 PCIE X16 so that is problematic :(
I can see this in terminal:
mesaflash --device --5i25
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn5 (Out)
14 18 IOPort SSerial 0 TXData5 (Out)
2 19 IOPort SSerial 0 RXData5 (In)
15 20 IOPort SSerial 0 TXData4 (Out)
3 21 IOPort SSerial 0 RXData4 (In)
16 22 IOPort SSerial 0 TXData3 (Out)
4 23 IOPort SSerial 0 RXData3 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
is there anything else i can test in software / firmware / drivers?
13 Dec 2025 12:04
When i load the program my pc just reboots.
That is most certainly a PC issue, not Mesa/LinuxCNC issue, so the first thing to try is insert the 6i25 into another PCI-E slot, even the long 16X one will work, and so will 8X and 4X ones.
  • Hakan
  • Hakan
13 Dec 2025 11:52
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
I guess it is not obvious what to do, and one needs a drive with EoE to test with as well.
I looked around a bit and it's not so common with EoE in the drive especially the cheap ones
don't have it.
I did find an opening though, it's in the SOEM and SOES ethercat master and slave libraries I use for embedded things.
They actually support EoE both master and slave.
I have a bit extra time now when I'm waiting for the hip to grow out again and will read up on that and try to understand the steps.
Then it should be possible to adopt this to IgH and lcec. Maybe.
Displaying 9721 - 9735 out of 12686 results.
Time to create page: 0.377 seconds
