  • andypugh
  • andypugh's Avatar
10 Jul 2025 08:59
Step By Step Help Needed . EL8 Leadshine to PI 5
Category: EtherCAT
I know someone else with this config, and he has written a walkthrough. I will ask him to post it.
  • meister
  • meister
10 Jul 2025 08:56
Replied by meister on topic Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
oh well, rio also supports e.g. ROS and MQTT without LinuxCNC, so the ARM core can also be very helpful.
And it may even be possible to run LinuxCNC directly there without a GUI.
i can't say much about the conditions, the board i have looks quite good. And even if you always have to buy 2, it's still cheaper than a new single Zynq chip :)
  • unknown
  • unknown
10 Jul 2025 08:40
Replied by unknown on topic Xilinx Zynq 7010 fpga crypto windfall boards
Ah yes I know that feeling. One has to do what one has to do.
I was a bit put off by the description of the conditions of the boards, I think on one of the github pages it was recommended to buy a couple of boards as they can be, as we say in Australianish, "a bit how ya goin".
Bit off topic but might be worth a few giggles.
www.backpackerdeals.com/blog/australian-...Mleeq5GDyucVmjtLBeS-
  • unknown
  • unknown
10 Jul 2025 08:35
Replied by unknown on topic Linux vs Windows value
I think that it will be the computer suppliers that will dictate the Desktop uptake. The average Joe will want Windows, the Mac users are dedicated to Apple, or whatever Apple throws at them.
People will just want a turnkey solution, or if they build their own PC what they are comfortable with.
I would posit a guess that the uptake in people connecting to the internet via phones or tablets is on the increase..........it would appear the easiest route to rot your brain with social media.
Apparently the latest trend on TikTok is their AI becoming sentient and having a soul. So I really don't have a lot of hope. I'm pretty sure it would the same group that use mediums, astrology, talk to spirits and jump on the "Latest Thing".
I'm so happy to be a grumpy old man in this day & age.
  • meister
  • meister
10 Jul 2025 08:34
rio's goal is that it runs on all FPGAs.
since the znyq already has an arm core and is connected to ethernet, you should be able to use it.
at the moment i wouldn't advise anyone to use the board for RIO, the TangNano9k is much better suited.
But somehow it is a challenge for me to get everything running on the board and once everything is working it will certainly have some extended possibilities.
  • unknown
  • unknown
10 Jul 2025 08:25
Sorry to hear of the board bricking.
I thought the whole thing of the RIO project was to get away from any softcores or it may seem now hardware cores. Or is my lack of FPGA experience showing through once again ;)
  • unknown
  • unknown
10 Jul 2025 08:22
Replied by unknown on topic Noise issue related to mesa board 7I76E
Not a lot of info to go on.
If your PC uses a realtek NIC I would search the forums for what to do. That would be a good starting point.
Next thing would be to ensure no "noisy" wires are crossing signal wires.
Next thing would be to ensure that the PSU that are powering the Mesa baord are giving a clean voltage. A good quality PSU, such as Meanwell or Weidmuller are good choices. Ensure the servo drivers are wired according to the manuals, don't skip the recommendations fro any filtering, not a cheap exercise, but well worth worth it.
Keep power wiring away from signal wiring. Don't expect a "rat's nest" to operate trouble free.
Don't wire every at once, wire one section at a time and test, trouble shoot and fix as you go. If something stops performing as it should it makes trouble shooting easier as you can start at the last addition you made.
Where ever possible terminate the ends of bare wires with "bootlace ferrules" makes inserting wiring into screw connectors easier and prevents start strands of wires floating in the breeze.
If you have implemented all these measures and have "noise" issues you will need to provide far more information. PCW may chime in and ask for you to do some "ping tests" and such, as this is his domain I shall leave it to him to guide you through that part.
  • meister
  • meister
10 Jul 2025 08:17
if i'm already putting so much time into the zynq parts, then it should be worth it :)
I've also ordered an Antminer s9 board, which has more IOs
  • Hakan
  • Hakan
10 Jul 2025 08:14
Replied by Hakan on topic Weird rotary axis movement
If I remember right, linuxcnc doesn't do synchronized motion on rotary axis.
Maybe wrong term but feeds,speeds and acceleration is determined by x,y,z only and the rotary axis will do the best it can. When it can't keep up this in the figure happens.
One usually uses the inverse time feed specification G93, and calculate the time needed for the movement in the CAM post-processor.
There are converters on "the web" that can translate G code to G93.
  • unknown
  • unknown
10 Jul 2025 08:08
Replied by unknown on topic Fried my LinuxCNC Setup
The only option would be to buy a cnc lathe, which is not a budget option.
Every other option is going to require you to do some wiring.
Even something such as this, github.com/clough42/electronic-leadscrew, will require you to do some wiring. And this is only a solution to screw cutting and doesn't have any cnc capabilities, tho it doesn't connect to a computer.
Once a again another Electronic Lead Screw, www.rocketronics.de/en/els/ no connection to a PC,no cnc capabilities but does other some extra features. Is still a user install, so there is wiring involved, but no connection to a PC. not really a budget solution.
First mistake was using a buck conveter, 2nd I would seem to be not checking the operation of the buck converter prior to connecting everything up. 3rd mistake would have been to triple checking everything.
Simple solution would have been to power the breakout board from a known and working 5v supply or whatever voltage the BoB required.
  • Daroum
  • Daroum
10 Jul 2025 07:22
Hello everyone,
I am using mesa board 7I76E to control 5 axis cnc with servo motors
I installed the linuxcnc on a laptop when i run linuxcnc with the mesa board on the laptop everything works well i got some wired interference like loosing Ethernet communication with the board or the mouse pad will be crashed all the time but i was ignore them because they didn't really influence on my project.
After that i installed the same version of linuxcnc on a desktop computer in fact i used the same ssd so it was the same software, the same configuration at this moment the noise issue became more than usually now i lost the communication every 5 min around ana that's a big problem. Do you have an idea what is the exact issues happened to me , how could i decrease those noise
Thanks in advance
  • BabyDibbert
  • BabyDibbert
10 Jul 2025 06:53
Fried my LinuxCNC Setup was created by BabyDibbert
Well, that never took off. Purchased a used PC with a parallel port breakout board and set everything up with what looked correct. Used a buck converter to power the board and noticed it wouldn’t change the voltage. Powercycled the steppers and breakout board and PC immediately turned off. Left the PC unplugged and the buck converter came to life at 26 volts, immediately blowing the caps in dramatic fashion. Well now with a fried PC and breakout board, I’d like just a ready made solution to power my lathe. I was going for Linuxcnc as I wanted spindle sync and backlash compensation, so if there are any great budget options that are just a ready made solution so I can stop worrying about wiring and flashing boards, that would be fantastic.
  • meister
  • meister
10 Jul 2025 05:12
made it,
i bricked the board :(
because the linux version on it was too old i wanted to update, but that went wrong somehow, now i'm trying to compile a new one and get it running again somehow.
it's no fun and very time consuming
10 Jul 2025 00:44
Replied by tommylight on topic Bios error during lcnc start
BSD isn't forgotten, I've run it for years on a router/firewall.
+1
And used it's desktop versions for over 2 years, probably 20 years back.
  • unknown
  • unknown
10 Jul 2025 00:42
Replied by unknown on topic Bios error during lcnc start
Displaying 12391 - 12405 out of 17355 results.
Time to create page: 0.427 seconds
