  • PCW
  • PCW's Avatar
24 Jun 2025 16:12
Replied by PCW on topic New with questions on LinuxCNC and Mesa
Typically, unless you need linear encoder feedback, you can use servo/closed loop drives that
just have local feedback, (no feedback to LinuxCNC) so you don't need encoder inputs, other than
one for the spindle if you want to do spindle synchronized moves.
For a simple system, I would consider a 7I96S or 7I76EU (the main difference is the the 7I76EU has
more digital I/0.) If you are sure you want to add encoder feedback a 7I95T would make more sense,
though you can add an encoder daughtercard to a 7I96S or 7I76EU (7I85/7I89 = 4/8 added encoders)
  • Russell072009
  • Russell072009
24 Jun 2025 15:35
New with questions on LinuxCNC and Mesa was created by Russell072009
I am new to the hobby CNC game. I currently have a little 3018that runs GRBL I bought to get my feet wet. My day job is CNC electronics maintenance so I have some experience with industrial controllers. What I would like to do is get a machine running with dual feedback. The biggest issue I have with the little guy is step loss. From what I have found you can run "closed loop" stepper systems which sort of solve the problem but not really so I want to build a system that will do exactly what I want and I was told LinuxCNC and a Mesa controller is the way to go. I have looked at the Mesa site and am thoroughly confused on the options. I see that I'm probably going to want an ethernet connection for real time. I'll have Linux running on a stand alone laptop so I want the controller external. I also know I'll need drivers for the servos and power supplies. Which controller and which daughter boards I need are the problem. I will build a 3 axis gantry machine with a slaved pair of Y motors. I would like future expandability options for a 4th axis down the road. I want all 3 axis to run rotary feedback on the motors as well as linear scales for each axis with machine primary positioning done from the scales and compared to the encoders. This is how industrial CNC machines run. Is this something that LinuxCNC and Mesa control boards can handle? If so can anyone help me out with selecting the mesa boards I would need to accomplish this?
  • bcorley
  • bcorley
24 Jun 2025 14:26
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
A test device would be great. What information do you need to get it to me?
  • JT
  • JT's Avatar
24 Jun 2025 14:21
Flex GUI 1.2.2 Released was created by JT
Category: Flex GUI
Flex GUI now has HAL I/O controls for a checkable push button, a check box, a spin box and a double spin box.
JT
  • electrosteam
  • electrosteam
24 Jun 2025 10:31
Replied by electrosteam on topic WiFi Problem on Raspberry Pi
Borrowed a dongle, TP-Link TP-WN722N, from a Forum Member.
Got an external antenna from another Form Member.
Much swapping and shifting around between bench, cubicle and cabled as far from cubicle as lengths would allow.
Dongle, antenna, 4GB and 8GB, power supplies, LC2.9.2 and LC2.9.4, etc etc
The Dongle works fine, Ebay says $15.
Eventually replaced the monitor on the mill with the one from the bench.
SUCCESS.
Even works in the cubicle with door open without the dongle.
Who would have thought !
Suggestions welcomed on what to do with the faulty monitor.
I am in Kingswood if you want to drop by and take it off my hands.
Thanks to all for the help,
John.
  • meister
  • meister
24 Jun 2025 10:06 - 24 Jun 2025 10:08
Replied by meister on topic LinuxCNC Machine Vision
there is already some opencv stuff included:
github.com/multigcs/riocore/blob/main/ri...ons/camjog/camjog.py
  • matasbuk
  • matasbuk
24 Jun 2025 08:58
Replied by matasbuk on topic 7i95t smart serial
7i95t smart serial
Solved it myself, had to set sserial_port_0=00xxxxxx
  • matasbuk
  • matasbuk
24 Jun 2025 08:30
7i95t smart serial was created by matasbuk
7i95t smart serial
Hello, can I connect both 7i83 and 7i84U to Mesa 7i95t? I need analog output for the spindle and 7i84U for IO expansion. If I connect them both, only the card in the first port gets recognized.
  • IonCarver
  • IonCarver's Avatar
24 Jun 2025 07:15
Regarding the question of following control on the assembly line
If we are speaking about communication delays, we also have to speak about communication delay between PC and camera.
After all, what is the speed requirement of the belt after all? Is it 0.1m/s? Is it 1m/s?
  • DMNZ
  • DMNZ
24 Jun 2025 07:10
Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
I use Mesa myself, and my motivation was not to spend hundreds of hours just to save 50 bucks on Mesa.
Mesa is the only turnkey solution here from what I can see that does not require JTAG programmer to start . I wanted to see what options would I have if for some reason Mesa will not be available in some future. I would hate to see it happen, but boy haven't we seen enough world craziness lately.
I admire all the people dedicating their personal time for the common benefit here.
>>I think the real question is, why arent i mining crypto when my machine has downtime? make the mesa fallback to a crypot miner
how do you know Peter is not doing this secretly while we sleep?
  • spincycle
  • spincycle
24 Jun 2025 05:37
Replied by spincycle on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Thanks for your input Langdons.
I used shielded on the encoder feed and analog control lead. The IO's I left unshielded. These looms are wired up and ready to go.
Little bit of progress. Got the control panel assembled with touchscreen and computer. It's definitely not a small screen....
The DB37 breakout units arrived, which will allow me to use the existing Heidenhain control cables to feed the relay board from the Mesa cards.
I just wanted to check VFD speed control wiring. The Delta data sheet only shows external speed control using a potentiometer. Can I wire it like below, using the axis 4 or 5 on the 7i97t to control it?
I'll activate the FWD/STOP, REV/STOP and OUTPUT SHUTDOWN via outputs on the 7i97t.
Thanks!
J
  • jimmyrig
  • jimmyrig
24 Jun 2025 05:20
Replied by jimmyrig on topic LinuxCNC Machine Vision
The nice thing about linuxcnc is you can call a python program from gcode, have it do whatever you want.... Options are endless really..... Then take that data and keep going.
Ask chatgpt how to do it, it's not that bad takes a bit to setup the m codes, O codes, and python program but is very doable especially with AI now a days
I have the basics built but not completed yet.
  • PCW
  • PCW's Avatar
24 Jun 2025 00:28 - 24 Jun 2025 01:47
MESA 7i76U inputs changing state without changes to config
Category: Basic Configuration
Well, tested the card and found no issues.
All inputs read low at 50% of field voltage and high at 65% of field voltage
applied to an input.
Heated to +70C and cooled to -40C and still no issues. Ran at 5V to 32V field
voltage and no issues.
Here is an image of all disconnected inputs in halshow (@ 24V)
  • TheTinkeringMechanic1
24 Jun 2025 00:24
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
It has a Mitsubishi A800 drive. (I can get the specs tomorrow) It came with 3 900+ page books. I know it receives forward and reverse signals separately. I I'm pretty sure it's PWM, but to me honest, I don't know. Sadly, I didn't build it or configure it. Coming in after someone else kinda stinks.
Displaying 12991 - 13005 out of 17374 results.
Time to create page: 0.404 seconds
