  • unknown
  • unknown
13 May 2025 08:00
Replied by unknown on topic LinuxCNC compatible industrial PC
Mostly it's a "bang for buck" issue.
I can argue for & against it.
  • meister
  • meister
13 May 2025 07:56
Replied by meister on topic LinuxCNC compatible industrial PC
what do you all have against a raspberry pi?
it works well and there are all kinds of cases for it.
2. NIC via USB
  • electrosteam
  • electrosteam
13 May 2025 07:26
Replied by electrosteam on topic Gmoccapy Tool Change Dialog
Category: Gmoccapy
Thanks Wischi, now works like it should.
I had not thought to go back to the ini file ! Getting old !
Not sure what you meant by "popup in the right hand corner".
My install starts clean without a pop-up.
I do get a warning when the code reaches the tool change that the bell is not connected (it isn't).
I will soon get a bell, or de-select it.
  • stenly
  • stenly
13 May 2025 07:26
Replied by stenly on topic Mesa 7i97T + 7i84 + 7i78 configuration
Hey there, JB-Motoring,
how did you manage to get the encoders in working order? Did you end up buying 5 IBV boxes? From past experiences EXE ones work better, but they are rather expensive. Or did you somehow directly connect them to the 7i97T card?
I have a similar machine I am looking to retrofit (DMU 50M, same encoders) and am wondering what hardware to buy.
Thanks.
  • Murphy
  • Murphy
13 May 2025 07:24
The more I think about this, It could very well be the PWM conversion onboard the EC500 is just to slow. It may not be able to keep up with the CSS speed adjustments. Any idea how to set the EC500 to output PWM instead and I'll hook up a PWM to Analog conversion board to test it. I know in the documentation you can switch it using Mach3 software.
  • SanzuiWorks
  • SanzuiWorks's Avatar
13 May 2025 06:50 - 13 May 2025 06:52
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
Reading Work Coordinates When Loading a New NGC File
When loading a new `.ngc` file in LinuxCNC, is it possible to read the work coordinates at that stage? Since the G-code has not been executed yet, the work coordinates might not be applied.
Would it be possible to create a custom button, similar to "WCS Sync," that reads the `.ngc` file and sends commands like `G55` to MDI?
Has anyone implemented something similar, or does LinuxCNC provide a built-in way to achieve this? Any insights or suggestions would be greatly appreciated.
Thanks!
  • SanzuiWorks
13 May 2025 06:39
Category: Qtvcp
[RS274NGC]
RS274NGC_STARTUP_CODE = G17 G21 G40 [color=#f1c40f]G43H0 G54[/color] G64P0.0005 G80 G90 G94 G97 M5 M9
I had been using it without much thought, but it seems better to remove G43H0 G54.
The tool length offset is unintentionally canceled, and the work coordinate system switches."
  • Wischi
  • Wischi
13 May 2025 06:07
Replied by Wischi on topic Gmoccapy Tool Change Dialog
Category: Gmoccapy
Postgui file looks fine.
You can remove this block from the gm.hal:
loadusr -W hal_manualtoolchangenet tool-change-request    =>  hal_manualtoolchange.change
net tool-change-confirmed  <=  hal_manualtoolchange.changed
net tool-number            =>  hal_manualtoolchange.number
It is not connected to anything but it will remove the popup in the right hand corner when starting linuxcnc. You don't need it anymore because you use the gmoccapy tool change dialog.
Check your ini config file if it includes this line under [HAL], if not add it:
POSTGUI_HALFILE = gmoccapy_postgui.hal
  • spincycle
  • spincycle
13 May 2025 05:59
Replied by spincycle on topic Bridgeport VMC760 retrofit
Category: Milling Machines
I recommend you keep all original brusheless motors, but perhaps you don't care about preserving old motors enough to spend the time.
Try to sell them, they may be worth more than their scrap value.
(Not sure what scarp metal prices are like where you are)
I'm assuming the closer you are to China (and Vietnam, Thailand, etc.), the higher the value of E-waste because the shipping to the reccling center in Asia is cheaper.
Hi Langdons,
I'd like to reuse them, but I haven't been able to find any successful examples of this online so far.
I can find Delta drives in the right voltage and they sell all their encoders as spare parts. I guess it's a matter of deciphering the spare part codes to match the right drives and figuring out how to adapt them. There is space to mount on the back of the motors where the Heidenhain encoders are.
Anyone done this?
  • Z3rni3
  • Z3rni3
13 May 2025 05:58 - 13 May 2025 06:04
Replied by Z3rni3 on topic hal functions
hal functions
I'm currently using PNCconf to set up my 7i96S board. So far, everything works fine when using stepgen for motor control. However, I'm running into an issue when switching to encoder-based feedback in a closed-loop setup. Specifically, whenever I try to home the joint using the encoder, I encounter a following error (the traveled distance until Error increases when i enlarge the "FERROR"). The stepgen setup homes without any problems, so it seems the issue is related to the encoder configuration. I'll upload my config in case anyone wants to take a look. I'd really appreciate any help or suggestions!
13 May 2025 04:51
Replied by tommylight on topic Moving from Axis to QtDragon?
Category: Qtvcp
MAX_VELOCITY on both.
  • akim14
  • akim14
13 May 2025 03:54
LinuxCNC Dual-Head Gantry Setup Assistance Request
Wow, that's amazing. Did each of the eight heads move on the X-axis independently? I wish you could help me; I think I bit more than I can chew. I downloaded your files, and I feel lost. I am trying to retrofit this bystronic dual head water jet, it looks like a mess. I have all the axis moving, but I can't get the XHC-WHB04B-6 to work. I have not picked a GUI yet, and I  have no clue of how to modify  one , it sounds easy reading about things but doing it seem to be another issue, I just really need help
  • Spyderbreath
  • Spyderbreath's Avatar
13 May 2025 03:51 - 13 May 2025 04:04
Replied by Spyderbreath on topic Moving from Axis to QtDragon?
Category: Qtvcp
Yes, I have looked in there and I only see max spindle override and max feed override. I do not see max velocity override or max rapid override. Not in my .ini file or any of the qtdragon .ini's. Maybe I should try and add those? Like MAX_VELOCITY_OVERRIDE =x.x and MAX_RAPID_OVERRIDE =x.x ?
Edit: And I just tried it, no change. Adding those into display with the feed and spindle did nothing.
  • cakeslob
  • cakeslob
13 May 2025 02:53
Thanks Cakeslob, I forgot your using the stm32 :/ the code in the hal file is the same for 0-10v and PWM ? Just the gain determines the difference?
In my VFD there is an option for 0-10v, 0-5v and external digital signal. Is it 0-5v or digital signal for PWM ?
@scotta , any ideas why it's doing this?
the gain thing was my mistake, they are both the same. remora outputs pwm, and if your hardware has a 0-10v, it will convert it to analog with the op-amp hardware circuit. digital signal might be referring to PWM
Displaying 15001 - 15015 out of 17468 results.
Time to create page: 0.324 seconds
