15 Apr 2025 18:54
What are the chances of getting this setup working?
Category: Pick and Place
@my1987toyota,
How is the recovery going?
  • PCW
  • PCW's Avatar
15 Apr 2025 18:38
Replied by PCW on topic Mesa 7i97T unresponsive analog outputs
Category: Driver Boards
If any analog output is not close to 0V at power up, (and no output mis-connections)
there is a hardware problem (perhaps a damaged op-amp) on the card and it needs repair.
  • vre
  • vre
15 Apr 2025 18:31
Replied by vre on topic spindle with encoder
Category: Basic Configuration
more notches are better but how can i set encoder
if encoder can only positioned before geartrain ?
  • Grotius
  • Grotius's Avatar
15 Apr 2025 18:28
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Thanks,
Will give it a try tomorrow.
  • my1987toyota
  • my1987toyota's Avatar
15 Apr 2025 18:26 - 15 Apr 2025 18:31
Replied by my1987toyota on topic What are the chances of getting this setup working?
Well with my project I got interested in other things and haven't spent much time on it in a while.
Partly the placer head desperately needs updating to modern day equipment. Cable and pulley
for the Z axis is in my opinion a terrible idea but the machine was designed in 1993. We have a few
other PnP machines where I work so this one was more or less an experiment. Plus work just
doesn't seem to ease up.
  • matasbuk
  • matasbuk
15 Apr 2025 18:22
Mesa 7i97T unresponsive analog outputs was created by matasbuk
Hello, trying to setup the 7i97T, but output 0 always seems to be at 4.55v no matter what, its enough to power up the board and not connect it to anything. Output 3 is the same. other outputs stay at 0 and do not change through halshow then I enter value manually. Even though they are enabled and scale set. My .ini and .hal files are attached.
  • rodw
  • rodw's Avatar
15 Apr 2025 18:21
Replied by rodw on topic asd-a2 e delta homing
Category: EtherCAT
Are you sure homing mode 2 is valid? Most drives I have seen are from 17 to 35
  • rodw
  • rodw's Avatar
15 Apr 2025 18:07
Replied by rodw on topic LinuxCNC S-Curve Accelerations
ANd also try installing this 6.12 kernel another user built
drive.google.com/drive/folders/16Xlry00L...SlwznPLv?usp=sharing
  • rodw
  • rodw's Avatar
15 Apr 2025 18:01
Please ignore the custom kernel here but follow all other optimisations
docs.google.com/document/d/1jeV_4VKzVmOI.../edit?usp=drive_link
There are many new features like energy efficient Ethernet that need setting for best latency
  • notJamesLee
  • notJamesLee
15 Apr 2025 17:58
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
Big pulley count - 60 and 20 for the small one.
The point about the micro steps is messing with me too.
I put everything back together, changed the value to 533, the closest i could get with an integer and it works. It does a full revolution but after 5+ you can see the error propagation. Same behavior with dip switches on default and set to 1600..
is this just something i'm forced to deal with using the PID once i move it to LCNC?
Th
  • rodw
  • rodw's Avatar
15 Apr 2025 17:50 - 15 Apr 2025 17:53
HI Rod,A tester send me this :Debian 10 : jitter max 45200Debian 12:jitter max 29000Debian13:jitter max 522000Ir looks very bad.
I think something is wrong with his setup. He needs to review my Google drive doc to optimise the  performance.I thought I had Debian 13 running here at home but it is on my work computer.But even so,  his Debian 12 latency seems high. Ethercat is installed on this PC
  • Grotius
  • Grotius's Avatar
15 Apr 2025 17:19
The used kernen in debian 13 :
linux-image-6.12.21-rt-amd64
I havent done the latency myself so far.
For the tester i will make a debian 10 with his current kernel.
But somehow we need a better kernel for debian 13. This looks not usable at all.
15 Apr 2025 17:05
Replied by tommylight on topic LinuxCNC S-Curve Accelerations
Debian 13 does not seem to be using an RT kernel, based on the numbers, but it just might be, i know i had worse on a new PC back in 2020, with RT kernel it would not do anything under 6000000 (yes 6 million).
That was an outlier as i have used over 50 PC and laptop from then, but never that terrible.
I do have a Dell laptop that does that, even with RTAI kernel, if anyone is interested. :)
  • aDm1N
  • aDm1N's Avatar
15 Apr 2025 16:34
Replied by aDm1N on topic ChatGPT LinuxCNC Assistent
The link for the same Page.
I tested all of the public file services offered; some of the alleged URLs were not assigned; a private FTP server or cloud was allegedly tested positive, but no data arrived.
  • heaven
  • heaven
15 Apr 2025 15:55
Replied by heaven on topic duplicate component name "usergenserkins"
I  just reseted my pc and it worked, weird  . Thanks anyway
Displaying 16786 - 16800 out of 17469 results.
Time to create page: 0.348 seconds
