  • spumco
  • spumco
05 Aug 2024 21:22
Can a 'servo drive' be used to power a 3 phase AC spindle motor with encoder?
Category: Driver Boards
I'd bet decent money that the gear looking thing the pins engage IS the C-axis gear.  It's painted, but shows no real signs of wear... because your lathe didn't have the C-axis option.
The pins are strange.  Pneumatic lines to actuators, and proxy sensors if the pins are retracted... fishy.  No idea what they do, other than maybe they're part of an alignment mechanism.
Hypothesis: Perhaps when C-axis is commanded, the main spindle rotates slowly to the encoder index, then one of the pins drops in place (indicating gear alignment with axis servo), then is retracted with the air after the C-axis servo is swung in to engage the bull gear.  That way the gear alignment isn't dependent on the encoder index pulse if the belt is replaced.
If you can find a pic of another lathe I bet you'll see a servo and some sort of swing-arm bracket so a spur gear on the servo can be brought in to mesh with the spindle gear using an air or hydraulic cylinder.  Just like the miniature version on my lathe.
I think asking on Practical Machinist would be your best bet, or call Hardinge and see if they've got any older repair/parts manuals.
  • chernogorsky
  • chernogorsky
05 Aug 2024 20:59 - 05 Aug 2024 20:59
qtdragonhd / probing was created by chernogorsky
Category: Qtvcp
Im trying to get probing working
currently it looks like working all the functions I need but cant set up tool dia measurement
It test the dia with Z=0*, not 0*-Z_CLEARANCE
so the flow is
1. do probe_tool_with_toolsetter
1.1 touch TS
1.2 go back Z_CLEARANCE (Z = *0 + Z_CLEARANCE)
2. perform XMinus
2.1 Go to X+ # move X - edge_length- xy_clearance
2.2 Go down with z_clearance_down (Z = Z - Z_CLEARANCE == *0)
2.3 Perform probe('xplus')
on 2.3 I have an issue, since its try to locate the edge of the TS with Z = top_of_TS == *0
lcnc: 2.9.3
  • PCW
  • PCW's Avatar
05 Aug 2024 20:57
Replied by PCW on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
So I tried with a PC with Debian 12 and LinuxCNC 2.9.2 and
everything works as expected. I did setup the real time interface
in the network manager and just added the interfaces file settings
for IRQ coalescing.
OS version
Linux EliteDesk800G3 6.1.0-18-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.76-1 (2024-02-01) x86_64 GNU/Linux
Debian release:
File Name: version.txt
File Size:0 KB
interfaces:
File Name: interfaces...8-05.txt
File Size:0 KB
ip a result:
File Name: ipa.txt
File Size:1 KB
  • steveb48
  • steveb48
05 Aug 2024 20:32
Replied by steveb48 on topic More - Error Finishing Read
Hmm, it looks like I got them backwards. I’m away until tomorrow afternoon but I’ll have a look then.
As always, thanks for your help!
  • Bennett
  • Bennett's Avatar
05 Aug 2024 19:48
For those with any experience with this kind of serial control, here are some pages from the service manual describing the control commands. Does anyone having any experience interpreting this kind of data and maybe finding a way to link this up with linux cnc? Might be in over my head but worth a look anyway.
  • TucsonSean
  • TucsonSean
05 Aug 2024 19:46
Replied by TucsonSean on topic Probe panel for Axis GUI
Category: AXIS
Here are my hal and ini files.
-Sean
File Name: Probe_preload.hal
File Size:1 KB
File Name: Probe_postgui.hal
File Size:8 KB
File Name: Taig_Mill_7i92.ini
File Size:9 KB
File Name: Taig_Mill_7i92.hal
File Size:13 KB
  • PCW
  • PCW's Avatar
05 Aug 2024 18:25
Replied by PCW on topic More - Error Finishing Read
OK it looks like you have the Realtek Ethernet setup for the 7I76E
Is that what you had intended?
If so, you need to
1. Install the Realtek 8168 DKMS driver
2. Disable Ethernet and ASPM PCIE power management in the kernel command line
05 Aug 2024 18:14
Ethercat installation from repositories - how to step by step
Category: EtherCAT
after 12-13 times during my payed hours trying to install this i took home the shitty chinese computer and tried another 6-7 times... doesn't work
Posting mutliple times with the same question/issue does not help, nor does giving no info on what or where or how it is failing.
05 Aug 2024 18:06
  • steveb48
  • steveb48
05 Aug 2024 18:06
steve@debian:~$ sudo lshw -class network
*-network
description: Ethernet interface
product: Ethernet Connection I217-LM
vendor: Intel Corporation
physical id: 19
bus info: pci@0000:00:19.0
logical name: eno1
version: 04
serial: 98:90:96:b4:ce:f7
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.1.0-18-rt-amd64 duplex=full firmware=0.13-4 ip=10.0.0.123 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:28 memory:f7c00000-f7c1ffff memory:f7c39000-f7c39fff ioport:f080(size=32)
*-network
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 06
serial: 00:e0:4c:68:1f:2a
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.1.0-18-rt-amd64 duplex=full firmware=rtl_nic/rtl8168e-2.fw ip=10.10.10.1 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:16 ioport:e000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
steve@debian:~$
  • PCW
  • PCW's Avatar
05 Aug 2024 17:55
dmesg | grep -i eth
or perhaps
sudo dmesg | grep -i eth
should also work
or install lshw
  • steveb48
  • steveb48
05 Aug 2024 17:53
Command not found.
  • PCW
  • PCW's Avatar
05 Aug 2024 17:22 - 05 Aug 2024 17:24
First, to make sure of your hardware, you can run
lshw -class network
  • steveb48
  • steveb48
05 Aug 2024 17:15
More - Error Finishing Read was created by steveb48
Hi All,
I'm getting an Error Finishing Read after a couple hours of run time on a Dell OptiPlex 9020.
I followed Rod's Google doc (Nice job!). I've also rattled the ethernet cable while running and routed it away from some noise sources.
It is not shielded cable. I believe it's an Intel NIC.
 I've included some images which show values from questions in other threads.
Any suggestions?
Thanks,
Steve
Displaying 24331 - 24345 out of 24521 results.
Time to create page: 0.620 seconds
