  • fenton06
  • fenton06
05 Feb 2026 04:37 - 05 Feb 2026 04:38
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Looks like the Trixie issues repo got nuked, does anyone know what happened?
  • Salrodri
  • Salrodri
05 Feb 2026 04:23
7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
Category: Driver Boards
When I try the command on the command line I get this error
efx_run.py : The term 'efx_run.py' is not recognized as the name of a cmdlet, function, script file, or operable
program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ efx_run.py seveni95t.xml --flow program --pgm_opts mode=jtag
+ CategoryInfo : ObjectNotFound: (efx_run.py:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
  • Salrodri
  • Salrodri
05 Feb 2026 04:15
I download the standalone programmer instead of the IDE.
I am using this JTAG,
www.amazon.com/dp/B0BKZ8X2C7?ref=ppx_yo2ov_dt_b_fed_asin_title
I am not sure how to connect
/RESET and /SS are these necessary?
This the error that I am getting.
According to efinity I should use bit files when using the JTAG and Hex when using SPI
Wed February 4 26 21:07:24 - Board Profile: Generic Board Profile Using FT4232
Wed February 4 26 21:07:26 - Valid device ID found: 0x00210A79
Wed February 4 26 21:07:26 - Board Profile: Generic Board Profile Using FT4232
Wed February 4 26 21:07:26 - Using FTDI URL (SPI = ftdi://0x0403:0x6011:1:3e/1, JTAG = ftdi://0x0403:0x6011:1:3e/2)
Wed February 4 26 21:07:26 - jtag programming started!
Wed February 4 26 21:07:26 - JTAG Programming on ftdi://0x0403:0x6011:1:3e/2
Wed February 4 26 21:07:27 - Programming 'C:/Users/srodriguez/Downloads/95tinit/95tinit/outflow/seveni95t.bit' via JTAG at freq 6.0 MHz
Wed February 4 26 21:07:27 - Device ID read from JTAG: 0x00210A79
Wed February 4 26 21:07:30 - ... finished with JTAG programming
Wed February 4 26 21:07:30 - Detecting device status...
Wed February 4 26 21:07:33 - Failure to configure was detected
  • Bansardo
  • Bansardo
05 Feb 2026 03:36
Replied by Bansardo on topic Can the OPI5 be Configured to Run LCNC?
For those who like it, I've got an Armbian image ready with Linux 6.17 Cinnamon which is ready to go.
drive.google.com/drive/folders/1_WMbZC0k...ceNNI?usp=drive_link
Last core already isolated
Included sata overlay (which had to be adjusted)
LinuxCNC installed
HDMI audio works
GPU acceleration works
VPU acceleration doesn't work in the web browsers, 1080p on YouTube works fine
IRQ of ethernet automatically pinned to core 5
Greetings, it's great job you done! Can you suggest to run it on OrangePi 5 plus?
  • PCW
  • PCW's Avatar
05 Feb 2026 03:01
Our initialization script does the programming from the command line:
Pretty sure use this uses a .hex or .bit file (in the outflow directory)
  • rodw
  • rodw's Avatar
05 Feb 2026 02:59
Stepperonline Y series/ YAKO YKD2608PE configuration
Category: EtherCAT
the pin names in your XML are what are used in hal. Yours are completely different so it won't work. Bring them into line.
  • tar_san
  • tar_san
05 Feb 2026 02:46
Replied by tar_san on topic initramfs-tools error (sudo apt upgrade)
Yes, I'm using 2.9.8 from 2.9.4 iso image,
there is a line.
raspi-firmware: missing /boot/firmware, did you forget to mout it ?
... z50-raspi-firmware exited with return code 1
I'm not using raspberry pi, but N150 PC
What should I do ?
  • Salrodri
  • Salrodri
05 Feb 2026 00:24
I do not think that I was able to program the FPGA.
I am stuck where programmer says "Device is in user mode!"
I do not know what is the next step
05 Feb 2026 00:10
Replied by tommylight on topic Custom PC build for my brothers company and more
Category: Show Your Stuff
Very long and very boring video of the entire shooting session, at 4C in the shop apparently i was in a t-shirt for nearly an hour the first round, roughly 1 and a half hour in a t-shirt, and the worst thing was one of the characters in this video kept using the laser thermometer to check every 5 minutes and reminding me with "how are you not shivering?". Oh well...
No sound, unfortunately, something wrong with the drone cam i used to record this.
  • PCW
  • PCW's Avatar
05 Feb 2026 00:07
Did you manage to program the FPGA via JTAG?
This would be shown by the green LEDs flashing in sequence
and the link and speed LEDs lighting up on the 7I95T's RJ-45
jack.
05 Feb 2026 00:03
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
Had to say "goodbye" to this monstrosity some two weeks ago, but it went with a lot of fanfare and ceremoniously (sorry but i have no video, was busy being thanked by some 150 people there), ended up looking pretty good and the school it went to are very happy:
And here is a short
youtube.com/shorts/AZbsfR1q7-w?feature=share
  • Salrodri
  • Salrodri
04 Feb 2026 23:58 - 05 Feb 2026 00:16
Efinity software reported an error. After reviewing my wiring, I was able to make progress.
I can now connect via JTAG using the Efinity Programmer tool. When I click Start Program, it appears to detect the board, and I receive the message “Device is in user mode.”
At this point, I’m not sure what the next step should be.
I have jumpers W15 and W16 set to UP,UP position so I can attempt an Ethernet connection to 192.168.1.121 However, when I run the following command:
mesaflash --device Ethernet --addr 192.168.1.121 --verbose
No ETHERNET board found
  • PCW
  • PCW's Avatar
04 Feb 2026 23:30
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
Not sure, sounds like the PWM is not setup properly
Can you run your test (where you expect 1V)
and in a terminal type
halcmd show all | grep pwm > pwm.txt
and post pwm.txt here
  • Nkbhvid
  • Nkbhvid
04 Feb 2026 23:11
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Yes
The multimeter gave a jump to 0.5 volt in a glimpse . I don’t know for how long since the meter was set to store highest
I just tried to repeat the test.
This time the 0 was dead 0
Could it have any impact on the result that I also had the 24 v on the enable pin at the same time in the first test?
  • rodw
  • rodw's Avatar
04 Feb 2026 23:09
Replied by rodw on topic Building from source for Trixie
I should mention I show how to build for RIP but you can keep with the Debian way and build the debs and install with sudo dpkg -i on the folder above where you are.
Displaying 2866 - 2880 out of 17282 results.
Time to create page: 0.276 seconds
