  • JT
  • JT's Avatar
27 Mar 2026 18:48
Ext hard buttons duplicate Power_PB and Reset
Category: Flex GUI
Flex GUI has nothing to do with halui.
This is my code for my BP external Estop.
# E-Stop Chain
loadrt estop_latch count=1
addf estop-latch.0 servo-thread
# E-Stop Loop
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-loopout estop-latch.0.ok-out => iocontrol.0.emc-enable-in
# E-Stop Reset
net estop-reset iocontrol.0.user-request-enable
net estop-reset => estop-latch.0.reset
net remote-estop0 estop-latch.0.fault-in <= hm2_5i25.0.7i77.0.0.input-06-not
JT
  • JT
  • JT's Avatar
27 Mar 2026 18:43
Replied by JT on topic Flex GUI Keyboard Jogging
Category: Flex GUI
And you can now set the jog increments using the keyboard.
gnipsel.com/linuxcnc/flexgui/ini.html#keyboard-shortcuts
JT
  • JT
  • JT's Avatar
27 Mar 2026 18:42
Replied by JT on topic Jog troubles
Jog troubles
Category: Flex GUI
That's a LinuxCNC issue the joints are numbered 0-8 for xyzabcuvw so c is joint 5.
Maybe a jog axis button would work. I'd have to test.
JT
  • rodw
  • rodw's Avatar
27 Mar 2026 18:39
Replied by rodw on topic Updating Old GladeVCP Files?
Category: GladeVCP
This may not help but this 2017 post shows how to update a gmoccappy screen handler from gcode which sounds like your problem 1
forum.linuxcnc.org/plasma-laser/32691-settings-from-g-code-file
Here different values are set using an analog input which is decoded and used to modify screen elements. eg 900 and 999 change screen settings.
  • grossm5000
  • grossm5000
27 Mar 2026 18:28
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
Category: Driver Boards
kind of weird that i can see it talking to a 5i25 in the error file
  • grossm5000
  • grossm5000
27 Mar 2026 17:44
still cant seem to find the board
  • PCW
  • PCW's Avatar
27 Mar 2026 17:13
Yes, you need to install firmware that matches the 7I77
You first need to download the 5i25.zip from
 www.mesanet.com/software/parallel/5i25.zip
unzip and then change to the configs/hostmot2 directory and then
sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit --reload
  • djdelorie
  • djdelorie
27 Mar 2026 17:02
Replied by djdelorie on topic Configuring and Homing dual Y Axes
Category: PnCConf Wizard
Sigh, my brain couldn't help but try to fix this. My idea: change debounce() to act like this:
state in out action
neg 0 x state = -delay
neg 1 x state ++
zero 0 1 out=1 state = delay
zero 1 0 out=0 state = -delay
pos 1 x state = delay
pos 0 x state --
(if out isn't persistent, use state == +1 or -1 instead of zero)
  • scsmith1451
  • scsmith1451's Avatar
27 Mar 2026 16:53
Probe Active before non-probe move was created by scsmith1451
File Name: level-check.ngc
File Size:1 KB
  Hi all;I was having this error randomly pop-up while running my level-check routine. Searching the forum I found  Billiiles  response to seuchato's post on a similar topic and applied his suggestion to add some dwell to insure the machine was stable before the next move statement, but I'm still getting random errors during the routine. The routine I wrote uses a touch plate made from 1/8 aluminum plate offset from the table by 5 cabinet bumpers, one in each corner and one in the middle. (See attached picture).I had used this routine and plate extensively without issues prior to a major rebuild of my machine to add a second Y axis to eliminate racking and a 2 DOF gimble to square the Z axis to the table. With all of that retrofitting completed over the winter I'm finally back to leveling the table. Now I'm having issues with the routine. In addition, I've verified that there is a open between the plate and the table using an Ohm meter on the 2 ohm setting while there is .2-.3 ohms resistance between the touch plate and the point where the touch plate cable plugs into its receptacle on the front of the bench.  Connection is made with a banana plug and socket. I've attached my code for your review. I'm probably missing something obvious (forest and the trees syndrome).  Any suggestions would be greatly appreciated.
Kind Regards,
  • djdelorie
  • djdelorie
27 Mar 2026 16:47
I have to add debounce to my sensors, too, and I don't like doing it. I tried using probing moves to move "away" from the sensors, but that's too complicated. The problem with debounce.N is that it delays the signal (it's a low pass filter). Perhaps we need a different kind of debounce? Something that reacts immediately to the first edge, then ignores further edges for a while? That would trigger on the first hit, then ignore the bouncing, trigger on the first release, then ignore that bouncing, etc. That would make probing and non-probing moves more predictable without delaying anything.
  • scsmith1451
27 Mar 2026 16:00
Replied by scsmith1451 on topic Configuring and Homing dual Y Axes
I've got both axes homing correctly though I did have to add 50 ms of debounce to all field inputs for everything to work correctly and consistently. Thanks for all your help.
  • oldmanzwing
  • oldmanzwing
27 Mar 2026 15:50
Replied by oldmanzwing on topic Ethercat boards and hardware
Thank you for the tip.
i currently just setting up a lab/Prototyping so don't need thing to work flawlessly just enough to test things, so trying to get away cheaply witch seems a bit hard with ethercat.
so mainly IO board that you could output LinuxCNC stepper signals out of would be ideal but it seems really hard to find at least when it comes to Ethercat, if i was more versed in electronics i would probably try and develop my own Ethercat board and open source it for other experimenters.
  • grossm5000
  • grossm5000
27 Mar 2026 14:59 - 27 Mar 2026 15:05
HEY! I am so dumb I didn't see your reply till just now. I actually bought another 6i25 convinced I had an issue with the card.
ANYWAY...I don't get any errors when I launch LinuxCNC, just a hard, full computer shutdown if the 7i77 is connected to the 6i25. If the 6i25 is NOT connected to the 7i77, I just get the Linuxcnc error i posted earlier.
So...I put in the NEW 6i25 just now, hooked up the 7i77 and launched Linuxcnc...and it DIDNT CRASH this time! Exciting. Now i just get a new Linuxcnc error:
Looks like the firmware wants an update? Do I do this with mesaflash?
  • Spezidrohne
  • Spezidrohne
27 Mar 2026 14:43
Replied by Spezidrohne on topic Ethercat Setup help needed for beginner
Category: EtherCAT
So i just take those files and copy them in the folder of my machine?
  • Hakan
  • Hakan
27 Mar 2026 14:03 - 27 Mar 2026 14:05
Review Request for Arc Volt Sensor Schematic
Category: Plasma & Laser
In what way do you see 2x50k as a better way than 1x100k?
You get voltages in the 50-60V range to THCAD.
With one 100k, and recognize that ground is really close to ground on the 5V rail,
you only get a few volts in after the voltage divider.
I thought about that on my card.
Only what is in red has 100V (well, -100V) and thereabout, the rest is 5V max.
I made some distance between torch voltage and copper as you can see in the read.
I always excuse myself by saying I am not an electric engineer, so I can be wrong.
Regarding filter, I have a digital lowpass filter with 10 Hz pole frequency in the controller. No hardware filter.
Linuxcnc has a "lowpass" hal filter component so it can be done there also.
I used the Herocut equivalent to the Lotos. Worked fine.I live in a place where we only can have 16A, absolutely max 20A, 230V at home.
I couldn't use all the 55A, the fuse blew all the time. I replaced it with a Herocut HC8000, three phase 400V 16A. I can now max out
the plasma cutter. But the compressor need to run off the petrol generator, it's too much with that one on one phase too.
Displaying 361 - 375 out of 17400 results.
Time to create page: 0.606 seconds
