  • grzester
  • grzester
22 Jan 2026 20:57 - 22 Jan 2026 21:29
Replied by grzester on topic Cia402 no connection
Category: EtherCAT
Hallo Hakan, thanks for Your response .I do like You sad but after removing sim files there is another problem like in the picture
 Only for another try i create separate second config, files like .hal , .xml are exactly the same as before., but there is simlar problem like in the picture
My goal for that moment is only confirm that drive is talking to LCNC.Thanks again.
File Name: axis_2026-01-22.ini
File Size:5 KB
File Name: ethercatCA...1-22.hal
File Size:3 KB
File Name: ethercat-c...1-22.xml
File Size:1 KB
  • 5_Zylinder
  • 5_Zylinder
22 Jan 2026 20:39
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
Hello,
It would be very kind and helpful if you could create a bitfile for a 7I97, 7i89, and 7iA0.
Currently, not all 14 encoder inputs are needed; this is just a preparation for glass scales. Currently, the encoder for the handwheel would be connected there.
The 7iA0 is to be connected to the 7i89 via the serial interface.
I managed to establish a connection in the old configuration of 7i97 + 7i74 and 7iA0, and the watchdog was gone. But this configuration no longer exists.
  • DemonClaW
  • DemonClaW
22 Jan 2026 20:24
Replied by DemonClaW on topic Generating a own Popup
Category: Qtvcp
Sure I will let you know about the finished Project
  • cmorley
  • cmorley
22 Jan 2026 20:21
Replied by cmorley on topic Generating a own Popup
Category: Qtvcp
Excellent! Thanks for not giving up.
In this kind of trouble shooting details really matter.
qtdragon is not the same as qtdragon_hd, error messages need to be quoted exactly etc.
When you get everything finished I hope you post a pic of your creation.
  • DemonClaW
  • DemonClaW
22 Jan 2026 20:14
Category: Qtvcp
It worked, i forgot the handler in the /share/ path the Terminallog showed it wanted to load it. After deleting it started with the Button and i can Open the Pop-up too. Thank you very much for your Help and stamina with me
  • cmorley
  • cmorley
22 Jan 2026 19:47
Category: Qtvcp
If you run linuxcnc from a terminal then there should be more information on that error.
it's not enough for me to track it down
  • DemonClaW
  • DemonClaW
22 Jan 2026 19:41
Category: Qtvcp
This is interresting with your files i still get the error message:
AttributeError: 'MainPage' object has no attribute 'PREFS_'
  • cmorley
  • cmorley
22 Jan 2026 19:32
Category: Qtvcp
Ok I edited your handler file - I should have explained how to combine the code.
I didn't remove your popup code but it's not used.
I used your modified qtdragon_hd.ui file
I made a sample vacuum panel based as a mainwindow with just an LED in it.
I confirmed this works on my system
  • PCW
  • PCW's Avatar
22 Jan 2026 19:30
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Category: Driver Boards
At the moment, whether or not "sserial_port_0=0xxxxxxx" is added to the hm2_eth line, all 7i42TA pins behave as GPIO - they can be set/cleared in halshow.
This is expected behaviour: if a sserial device is not found on a particular channel, its I/O pins revert to GPIO
I would be grateful if you could send the firmware for that card including: 6x analogue servo, 6x encoder, 2x pktuart and 2x sserial modules, for 7i80HD-25, 7i48, 7i52 combination.
I'll try and get to this sometime today or tomorrow.
  • DemonClaW
  • DemonClaW
22 Jan 2026 19:21
Category: Qtvcp
OK this worked and we got rid of the type error, if i start i now i get a attribute error: object has no attribute 'PREFS_' , i hope you dont get frustraded with me its all very new for me. I really appreciate your work with me. And it means a lot.
  • cmorley
  • cmorley
22 Jan 2026 19:01
Category: Qtvcp
please build your panel as a main window instead of a dialog
  • DemonClaW
  • DemonClaW
22 Jan 2026 18:59
Category: Qtvcp
No idea how this happend i will post and check it this time
  • cmorley
  • cmorley
22 Jan 2026 18:54
Category: Qtvcp
The ui files are 0 kb for some reason
  • grandixximo
  • grandixximo's Avatar
22 Jan 2026 18:46
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I'm not expert too, I've just been experimenting with AI and looking at the halscope, trying to wrap my head around things in general, it helps to just chat about these things, even just to make sure I'm not persuing a weird irrational tangent, and I'm actually making sense not just to myself lol. YangYang has the math down, he is the main arbitror, nothing goes to master without his stamp of approval, and he checks on what the AI comes up with, and so far nothing really sticks, only what he write himself works best. I've found something with the arcs, I want him to take a look, and I think we maybe possibly be able to do similar tricks with Béziers, but I don't want to keep your hopes up, I think it is possible that, the fact that Béziers change curvature, may not fit with the current tp lokahead/blending architecture, but maybe... maybe I am wrong.
  • DemonClaW
  • DemonClaW
22 Jan 2026 18:42 - 22 Jan 2026 18:46
Category: Qtvcp
Yeah for sure these are the files, the error code is already above.
Displaying 3811 - 3825 out of 17133 results.
Time to create page: 0.529 seconds
