19 Mar 2026 15:52
Replied by tommylight on topic Sudden - Strange behavior of arcs
Picture of the result?
  • kmeld
  • kmeld
19 Mar 2026 15:46
Sudden - Strange behavior of arcs was created by kmeld
I have this strange problem since today. Everything was working fine when I was last using the machine.
today I noticed that G2 and G3 for full circles gives me holes elongated in X.
I was trying to do 25mm in diameter hole and it ended up being 25 along Y and 26 along X.
When I was using the machine before (approx 2 weeks ago) I was using the same program and result was circular.
I was looking for some mechanical cause, like something getting loos, but found nothing.
I checked the same program on two very different feedrates 2400 and 300 to check for any inertia driven causes.
I checked backlash on X, and it came back normal, around 0,02.
I am puzzled.
Any suggestions?
Cris.
  • Xnke
  • Xnke
19 Mar 2026 15:29 - 19 Mar 2026 15:35
Mitsubishi MR-J3-XX"A" drive + 7i94 config?
Category: Driver Boards
Awesome. I figure by the time you have a good stable software, I might have a Y axis to hook up. I have to get the wire wheel into the column of the Z axis today and un-rustify it, so I can add in the new stiffeners and get it ready for heat treatment.
(I did kinda start this mess in 2020, and it's now 2026...)
EDIT: What's the X2 connector on the back side of the board for? And is this ethernet card a combo copper/fibre interface? Just looking at what the latching connector at the bottom of the top side, and that it looks like CN1 on some of the MR-J2 drives.
  • Spezidrohne
  • Spezidrohne
19 Mar 2026 14:58
Replied by Spezidrohne on topic StepperOnline A6 Servo
Category: EtherCAT
Thanks for the reply, but im still too dumb to integrate just these files. It just won't work. Can anyone guide me through this? What doch i have to do with these files? All i have done so far is to create a sample from the Premiere Samples and put the 3 files into the folder. Should i even call the Basic.hal from the axis.ini file? What am i doing wrong?
  • dkj4linux
  • dkj4linux
19 Mar 2026 14:40
Remora RP2040-W5500 — immediate joint 0 following error on first move
I'm an old retired engineer with limited LinuxCNC understanding trying to get @scottalford75 's Remora RP2040-W5500 project working.— and am now getting immediate joint 0 following error on first move (command ~125) after successful runs, low spike filters, W5500-EVB-Pico.
With Grok's help, I had this working reliably a couple of days ago... running full logo G-code and longer files to completion without errors. This was probably with unrealistic relaxed settings, however... just trying to get it running in the Axis visualizer.
After some tuning attempts and reflashes, it now fails immediately on the first G0 move with "joint 0 following error" at command 125, even with:
- SCALE = 38.5 (X/Y), 200 (Z) — proven on Grbl/FluidNC
- Acceleration set to 0 in [TRAJ]
- FERROR = 15+, MIN_FERROR = 1.5
- G61 exact path mode
- Clean reboot, minimal background, performance governor
- remora.status = TRUE, spike filters very low (~500-700), read.time stable
Tried:
- Full flash_nuke + both available .uf2 files from repo
- Re-upload config every time
- Power cycle Pico 60+ seconds
Halshow shows stable polling, no high spike filters, but pos-fb lags immediately on first move.
I've attached my .ini, .hal, and config.txt files.
Thanks for any help you can give me.
  • grossm5000
  • grossm5000
19 Mar 2026 14:31
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
I am wondering if my PCIe slot is bad. Trying a different slot today…stay tuned…
  • RLA
  • RLA
19 Mar 2026 14:05
tool compensation on joints was created by RLA
Hi...asked this before with another question that has not received any reply yet..
I currently have 2 tools on 1 axis as a rough and finish tool....as 1 tool is sharpened calibration between 2 changes ...I would need to adjust one tool diameter separately from the other...So the question is..if I set up as 2 joints on that axis can the tool diameters be changed independently and result in on joint compensating different from the other while following the motion for that axis?
Thanks for any help..
Rick
  • amanker
  • amanker
19 Mar 2026 14:03
Replied by amanker on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
Thanks for reply. I will wait.
  • aikiaviator
  • aikiaviator
19 Mar 2026 13:00
Replied by aikiaviator on topic Plasma table set, fine tuning a problem
Category: Plasmac
Hi Rod, Thanks. Found the section. Looks like no actual settings defined for the newer and current THCAD2. I guess I can muck my way through it. Looks like the calculator doesn't have it factored either. Thanks for the pointer.
  • spumco
  • spumco
19 Mar 2026 10:42
Replied by spumco on topic Trouble with XFCE (trixie) timed logouts
Category: Installing LinuxCNC
I just open power management under 'settings' menu and set all timing sliders to zero.
  • grossm5000
  • grossm5000
19 Mar 2026 01:51
Hey thanks for the fast reply. I ended up powering the 7i77 with a dedicated 5v power supply. Flipped all the appropriate jumpers on the 7i77 and 6i25
i would also like to point out that I removed the terminal blocks for ALL the encoders, drivers on the previously mentioned TB…so it can’t be shorted or drawing too much power because everything is disconnected!
I started to wonder if my 6i25 was dead. I don’t see any LEDs light up on it when I power up the PC. I also can’t find it with lspci
  • Lcvette
  • Lcvette's Avatar
19 Mar 2026 01:05
Replied by Lcvette on topic Probe Basic Errors after successfully probing
Category: QtPyVCP
yeah some video would be very helpful. so your probe length changing is not really gonna help your cause. it should be fine for x and y, but your z is gonna be all over the place. you will be better off using a non repeatable holder touchoff routine which will basically use the height between the tool setter trigger position and your finished spoilboard. and make z0 the spoilboard surface for your programs. then every tool touch off will reset the work offset based on a calculation between tool setter and spoilboard and new tool touch. other ways to do it also but im not really a router guy so maybe better posting a thread asking for router tool touchoff help from the other users doing that already.
19 Mar 2026 01:01
Replied by tommylight on topic Motor timing help
Motor timing help
Signaling usually from 100Hz to 1000Hz, some up to 100KHz, and very rarely up to 1MHz.
There is no recipe for it, depends on a lot of stuff, so not easily framed into an answer, but:
-switching power supplies from 15KHz (older) to 400KHz (new ones)
-CPU inside a PC nowadays 2-6GHz, but almost all use a 100MHz clock
-power lines in USA 60Hz, in Europe 50Hz
-Mesa boards can do up to 10MHz, but most i ever needed was 0.96Mhz or 960KHz
-etc etc
  • Lcvette
  • Lcvette's Avatar
19 Mar 2026 00:59
Replied by Lcvette on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
I've spent the last few days working on the backplot and simulation and just about have it sorted i think. but this will be in the pyside6 release only which is a few weeks out from being primetime ready after testing.
Here is simultaneous impeller simulation on youtube:
Displaying 601 - 615 out of 17469 results.
Time to create page: 0.237 seconds
