  • Hakan
  • Hakan
01 Nov 2025 13:02
Machine plasma torch IPTM-80 and ohmic sensor
Category: Plasmac
I only found this recom dc-dc converter and bought it from tme.eu
www.tme.eu/en/details/rs3k-2424sz_h3/dc-dc-converters/recom/
I see that Mouser, Digikey, Farnell and those big ones have the item.
Can't find it on cheap places ebay, alix etc.
  • unknown
  • unknown
01 Nov 2025 13:00
RaspberryPi 4/5 Ethercat Rtelligent ECT60 Synchronization error
Category: EtherCAT
I'm not too sure if this may help
github.com/MichaIng/DietPi/issues/6577
The power saving feature shouldn't be kicking whilst there is traffic, but stranger things do happen. And I know the RPi is on a later kernel.
Actually that reminds me I'll have to talk to Rod about Ethercat repos for the new image.
  • lev
  • lev
01 Nov 2025 12:21
Category: Plasmac
I'm not good at electronics. i will try implement a hypersensing circuit from plasma-cnc-primer docs with yours schematic. similarly, without surgery in a long cable.
for ohmic sense i only have thcad-10. i have thcad-300 but i used it for THC in this plasma cutter with 1:1 devider.
I found almost all the components (FY0022 + FY0023 connector,24VDC >20A relay ). but i can't find Isolated dc-dc converter with on/off signal.
  • DerKlotz
  • DerKlotz
01 Nov 2025 11:29 - 02 Nov 2025 14:38
Try to activate Gladevcp with setp gladevcp -> Linuxcnc
Category: GladeVCP
Hello,
i try to activate some glade functions. Therefore i use "gladevcp.table1 1" in my custom_postgui.hal.
In the attached file i deactivated "gladevcp.table1 1". Then you can see the light grey button/leds but you can´t use them. If activated you just see a blank site.
  • kate
  • kate
01 Nov 2025 11:08
  • Hakan
  • Hakan
01 Nov 2025 10:57
Category: EtherCAT
Well, I don't have a pi with linuxcnc and only googled a bit.
forums.raspberrypi.com/viewtopic.php?t=362866#p2229969 worth a try I guess if you haven't done so.
  • DerKlotz
  • DerKlotz
01 Nov 2025 10:27
Replied by DerKlotz on topic Joint 2 on limit switch error -> Z Axis
Category: Basic Configuration
There was "A Maximum Limit + Home set" instead of "Z Maximum Limit + Home"
  • kate
  • kate
01 Nov 2025 10:24 - 01 Nov 2025 11:17
Category: EtherCAT
May be I have found least workaround and some glue what's wrong. I tested adding ethernet switch between my Raspberry Pi 5 and ETC60 Ethercat stepper controller. After adding this switch i have not got any synchronization errors or got Raspberry ethernet link up/down causing that error.
Because i have got same error between multiple tested Raspbelly Pi 4 and 5 boards and least three controller boxes having Rtlligent ETC60it cant be just a faulty unit but more common compatibility issue. Least adding switch is workaround fix.
My general experience from Linuxcnc / Ethercat / ECT60 is very positive. First I replaced always failing PC hardware with Raspberry Pi and PIO controlled steppers but I wanted better and Ethercat felt best choice. In beginning i needed to build everything from sources. This joint x motion error / synhcronization error was only unresolved issue and it took long time to find out that it was not caused by other factors like insufficient real time performance.Now when everything works and there is easy installation package i think that it will be my number one option. Next I will try Lichuan Ethercat servo and lets see is do I need switch between Lichuan ethervcat controller or not
  • rodw
  • rodw's Avatar
01 Nov 2025 10:06
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
Major update 1 Nov 2025
First image I feel is suitable for testing.
Linuxcnc 2.9.7 is pulled from the Linuxcnc repos.
Thats pretty cool!
  • ihavenofish
  • ihavenofish
01 Nov 2025 09:47
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
so if i home and crash, is there something in the controlword and statusword i should see? it happens in a few ms.
Use halscope to record, it catches every ms.
If I look at cia402 code the only reason I can see (but I might miss of course)
is that it does an auto fault-reset due to it receiving a fault code.
Halscope.
And thumb on e-stop.
OK, ill try that tomorrow.
  • unknown
  • unknown
01 Nov 2025 09:46
After much frustration "the eye candy stuff" is sorted. Background was edited to the best of my "artistic" skills, and first attempt at inkscape, using a standard xfce background with a Linuxcnc logo found on forum member's KurtJacobson's git hub page
Splash screen artwork was found on the forum.
Artwork for the background of the Login screen was also found on the forum (robertspark I think was the poster)
If anyone is familar with the rights regarding the artwork it would be appreciated.
There is still some software that could be pruned, cups is a major one which will also not have the various cups services running. Avahi is another that could be turned off.
Thanks to all who help and gave input
Cheers
Rob
  • ihavenofish
  • ihavenofish
01 Nov 2025 09:46
Yup, that's what's not working as expected. It has zero effect on homing.
The section after that is what ill try that tomorrow. That hopefully at least will tell me if linuxcnc is causing the motion, or the drive.
  • Hakan
  • Hakan
01 Nov 2025 09:45 - 01 Nov 2025 09:45
Halscope.
  • rodw
  • rodw's Avatar
01 Nov 2025 09:38
immediate homing is covered here linuxcnc.org/docs/stable/html/config/ini...ml#_immediate_homing
But spending an hour wiring home switches will be well worth it!
I could not use a machine without home switches and yes I tried!
  • ihavenofish
  • ihavenofish
01 Nov 2025 09:29
Nothing seems to change when i home other than the joint error from the crash (i've blocked the axis). So maybe its not the drive homing after all.
still makes zero sense.
Displaying 7816 - 7830 out of 16728 results.
Time to create page: 0.265 seconds
