18 Sep 2025 21:20
That is almost always a locale issue and/or language issue, so for future reference you can boot from USB with LinuxCNC and use Live session to create a PncConf config while in English language, and also test the machine if it is attached to that PC, all from a Live session, but do not forget to save/copy that config to the internal hard drive/SSD/NVME. Then you can reboot and use the existing installation in your language to run that config.
Replied by tommylight on topic 7i76E Spindle configuration
Category: PnCConf Wizard
Try setting Locale to UTF-8, google how to do that on Debian.So, as a user, I wonder why the PncConf Wizard application did not provide me with the TB4 configuration. And that is my problem to solve.
- Robert312
- Robert312
18 Sep 2025 20:53
Replied by Robert312 on topic Homing is not working
Category: HAL
But in reply to someone saying my home switch wasn't connected, it was. And I don't see where my mesa inputs are wack. What is interesting is that in my new config the homing works and the hal and ini files are almost identical to the old config. So that is odd. But any-who problem fixed.
18 Sep 2025 20:51
Replied by PCW on topic Firmware Request for 7i92 – Plasma CNC Build
Category: Driver Boards
For a 7I92:
7i92_5ABOBx2D.bit
for a 7I92T:
7i92t_5abobx2d.bin
Would be closest If you are using the common "Mach 5 Axis" Sainsmart parallel port BOB
Note that the inputs of the common 5 Axis breakouts are not really suitable for encoder use
as they are quite slow and require 12 V signals.
7i92_5ABOBx2D.bit
for a 7I92T:
7i92t_5abobx2d.bin
- Robert312
- Robert312
18 Sep 2025 20:46
Category: HAL
Thank you, they were messed up. We ended up making a new config and the homing now works. We had skipped a section in pnnconfig that enabled homing. It is unclear in the documentation.
- RobotMatic
18 Sep 2025 20:45
Replied by RobotMatic on topic 7i76E Spindle configuration
thank you for your words, I am very sorry about Mr. PCW, I respect him and I appreciate him.
I want you to be able to put yourself in my shoes as a LinuxCNC user. I have an application (pcconf) that I have used without problems in previous versions, which is not working today. I create a thread in this forum seeking help because my ability is not enough to solve the problem, I receive help and instructions to resolve it, I try to do what is requested as best as I can, I send videos, images, explain, answer more than once what I am being asked, it is not a bad attitude, it is my lack of ability that cannot satisfy those who are helping me and it is respectable that they eventually reach their limit, but there was no bad intention!!.
I need to control a VFD with the ACM-AVI signals + 10VCC (YASKAWA GA500) The Pncconf wizard should have given me the TB4 configuration when I selected 7i76e, but it didn't. that is the problem !!
There is no tension on pins (1-2) (1-3) of the TB4
I was able to manually program turning on-off-enabling, but when I wanted to program the hal pwm component and assign it to spindle out, it did not allow me.
I know that the problem is overwhelming me, I just need to solve it because I have been an intensive user of linuxcnc since 2008, I use it every day of my life since then, I have learned a lot but not everything and I continue learning.
thank you for your time, I greatly appreciate it
- scotta
18 Sep 2025 20:40
Replied by scotta on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
I would suggest setting up a configuration for 4 joints X Y Y Z. You should not be pointing multiple step generators at the same frequency command or command feedback.
Take a look at this 5 joint config where there are two joints assigned to the Z axis. You can do the same for your dual Y axes.
github.com/scottalford75/Remora/tree/mai...figSamples/hypercube
- Gusgus
- Gusgus
18 Sep 2025 19:08
sorry i had a formatting error
Replied by Gusgus on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
"Board": "BIGTREETECH Octopus Pro",
"Modules":[
"Thread": "Servo",
"Type": "Reset Pin",
"Comment": "Reset pin",
"Pin": "PC_15"
"Thread": "Servo",
"Type": "eStop",
"Comment": "eStop",
"Pin": "PG_12"
"Thread": "Servo",
"Type": "PWM",
"Comment": "Spindle",
"SP[i]": 3,
"PWM Pin": "PB_0",
"PWM Max": 255,
"Hardware PWM": "True",
"Variable Freq": "True",
"Period SP[i]": 1,
"Period us": 200
"Thread": "Base",
"Type": "Stepgen",
"Comment": "X - Joint 0 step generator",
"Joint Number": 0,
"Step Pin": "PF_9",
"Direction Pin": "PF_10",
"Enable Pin": "PG_2"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Y1 - Joint 1 step generator",
"Joint Number": 1,
"Step Pin": "PC_13",
"Direction Pin": "PF_0",
"Enable Pin": "PF_1"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Y2 - Joint 1 step generator",
"Joint Number": 1,
"Step Pin": "PE_2",
"Direction Pin": "PE_3",
"Enable Pin": "PD_4"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Z - Joint 2 step generator",
"Joint Number": 2,
"Step Pin": "PE_6",
"Direction Pin": "PA_14",
"Enable Pin": "PE_0"
"Thread": "Servo",
"Type": "Digital Pin",
"Comment": "X min",
"Pin": "PG_6",
"Mode": "Input",
"Data Bit": 0
"Thread": "Servo",
"Comment": "Y min",
"Pin": "PG_9",
"Mode": "Input",
"Data Bit": 1
"Thread": "Servo",
"Comment": "Z min",
"Pin": "PG_10",
"Mode": "Input",
"Data Bit": 2
"Thread": "Servo",
"Comment": "Probe",
"Pin": "PG_11",
"Mode": "Input",
"Data Bit": 3
# Basic LinuxCNC config for testing of Remora firmware
[EMC]
MACHINE = Remora-XYZ
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 28.7
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 28.7
DEFAULT_ANGULAR_VELOCITY = 28.7
MIN_ANGULAR_VELOCITY = 0
MAX_ANGULAR_VELOCITY = 28.7
INTRO_TIME = 5
PROGRAM_PREFIX = ~/linuxcnc/nc_files
INCREMENTS = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm
[KINS]
JOINTS = 3
#KINEMATICS =trivkins coordinates=XYZ kinstype=BOTH
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 0
SERVO_PERIOD = 5000000
[HAL]
HALFILE = remora-xyz.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_LINEAR_VELOCITY = 4.17
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 28.7
MAX_ACCELERATION = 287.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1080.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1080.0
MAX_VELOCITY = 28.7
STEPGEN_MAXACCEL = 1000.0
SCALE = 100.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -45.000000
HOME_LATCH_VEL = -2.500000
HOME_SEQUENCE = 1
#*** AXIS_Y *******************************
[AXIS_Y]
MAX_VELOCITY = 28.7
MIN_LIMIT = -0.001
MAX_LIMIT = 950.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 950.0
MAX_VELOCITY = 28.7
SCALE = 100.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_LATCH_VEL = 2.500000
HOME_SEQUENCE = 2
#*** AXIS_Z *******************************
[AXIS_Z]
MAX_VELOCITY = 20.0
MAX_ACCELERATION = 150.0
MIN_LIMIT = -125.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -125.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 20
STEPGEN_MAXACCEL = 187.5
SCALE = 800.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_SEARCH_VEL = 15.000000
HOME_LATCH_VEL = 0.625000
HOME_SEQUENCE = 0
- souh-hil
18 Sep 2025 19:07
Firmware Request for 7i92 – Plasma CNC Build was created by souh-hil
Hello everyone,This is my first post here on the LinuxCNC forum, and also my very first CNC build — so please forgive any mistakes or lack of experience on my part. I'm doing my best to learn as I go.I'm building a plasma CNC machine and using a Mesa 7i92 card. For my setup, I’ll be connecting two 5-axis breakout boards — one on P1 and one on P2. I’m looking for a suitable firmware that would allow me to:
- Use 4 or 5 encoder inputs (for THCAD and potentially other uses)
- Have at least 10 inputs and 5 outputs for general machine control
- Gusgus
- Gusgus
18 Sep 2025 19:04
Hello once again!
I haven't really been active but we got to testing once again and now I have encountered another issue I don't understand.
So now we get movement and stable connection to the octopus, we got an spi cable with shielding and that worked wonders, thank you tommylight for the suggestion and thanks Scotta for all the help.
The issue we are encountering now is that we have x y1 y2 and z, but we only get movement from x and y1, y2 and z are completely unresponsive, we have eliminated the drivers and their wiring since if we connect the y2 and z terminals to the x and y1 outputs on the octopus we get movement from them.
We have them wired to the octopus' Motor 4, 5, 6, and 7 ports, which are decleared in the following config:
We are running this in our .ini file:
and this in our .hal file:
We flashed this firmware to it: github.com/scottalford75/Remora/tree/mai...in/STM32F446/BTT_446
and are running the above mentioned config file.
we also tried looking at the debug info but nothing came up, here's the printout:
All the pins are generated in the correct order it seem's, we are gonna test next the output signal strength, maybe the drivers don't have enough power on high state to start moving, even if everything is connected to the same ground.
[color=#d4d4d4]{[/color][color=#9cdcfe]"Board"[/color][color=#d4d4d4]: [/color][color=#ce9178]"BIGTREETECH Octopus Pro"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Modules"[/color][color=#d4d4d4]:[[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Reset Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Reset pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PC_15"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"eStop"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"eStop"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_12"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PWM"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Spindle"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"SP[i]"[/color][color=#d4d4d4]: [/color][color=#b5cea8]3[/color][color=#d4d4d4],[/color][color=#9cdcfe]"PWM Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PB_0"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"PWM Max"[/color][color=#d4d4d4]: [/color][color=#b5cea8]255[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Hardware PWM"[/color][color=#d4d4d4]: [/color][color=#ce9178]"True"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Variable Freq"[/color][color=#d4d4d4]: [/color][color=#ce9178]"True"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Period SP[i]"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Period us"[/color][color=#d4d4d4]: [/color][color=#b5cea8]200[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"X - Joint 0 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]0[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_9"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_10"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_2"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Y1 - Joint 1 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PC_13"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_0"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_1"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Y2 - Joint 1 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_2"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_3"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PD_4"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Z - Joint 2 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]2[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_6"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PA_14"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_0"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"X min"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_6"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]0[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Y min"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_9"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Z min"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_10"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]2[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Probe"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_11"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]3[/color][color=#d4d4d4]}[/color][color=#d4d4d4]][/color][color=#d4d4d4]}[/color]We are running this in our .ini file:
[color=#6a9955]# Basic LinuxCNC config for testing of Remora firmware[/color] [color=#d4d4d4][EMC][/color][color=#569cd6]MACHINE[/color][color=#d4d4d4] = Remora-XYZ[/color][color=#569cd6]DEBUG[/color][color=#d4d4d4] = 0[/color][color=#569cd6]VERSION[/color][color=#d4d4d4] = 1.1[/color] [color=#d4d4d4][DISPLAY][/color][color=#569cd6]DISPLAY[/color][color=#d4d4d4] = axis[/color][color=#569cd6]EDITOR[/color][color=#d4d4d4] = gedit[/color][color=#569cd6]POSITION_OFFSET[/color][color=#d4d4d4] = RELATIVE[/color][color=#569cd6]POSITION_FEEDBACK[/color][color=#d4d4d4] = ACTUAL[/color][color=#569cd6]ARCDIVISION[/color][color=#d4d4d4] = 64[/color][color=#569cd6]GRIDS[/color][color=#d4d4d4] = 10mm 20mm 50mm 100mm[/color][color=#569cd6]MAX_FEED_OVERRIDE[/color][color=#d4d4d4] = 1.2[/color][color=#569cd6]MIN_SPINDLE_OVERRIDE[/color][color=#d4d4d4] = 0.5[/color][color=#569cd6]MAX_SPINDLE_OVERRIDE[/color][color=#d4d4d4] = 1.2[/color][color=#569cd6]DEFAULT_LINEAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MIN_LINEAR_VELOCITY[/color][color=#d4d4d4] = 0[/color][color=#569cd6]MAX_LINEAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]DEFAULT_ANGULAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MIN_ANGULAR_VELOCITY[/color][color=#d4d4d4] = 0[/color][color=#569cd6]MAX_ANGULAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]INTRO_GRAPHIC[/color][color=#d4d4d4] = linuxcnc.gif[/color][color=#569cd6]INTRO_TIME[/color][color=#d4d4d4] = 5[/color][color=#569cd6]PROGRAM_PREFIX[/color][color=#d4d4d4] = ~/linuxcnc/nc_files[/color][color=#569cd6]INCREMENTS[/color][color=#d4d4d4] = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm[/color] [color=#d4d4d4][KINS][/color][color=#569cd6]JOINTS[/color][color=#d4d4d4] = 3[/color][color=#6a9955]#KINEMATICS =trivkins coordinates=XYZ kinstype=BOTH[/color][color=#569cd6]KINEMATICS[/color][color=#d4d4d4] =trivkins [/color][color=#569cd6]coordinates[/color][color=#d4d4d4]=XYZ[/color] [color=#d4d4d4][FILTER][/color][color=#569cd6]PROGRAM_EXTENSION[/color][color=#d4d4d4] = .py Python Script[/color][color=#569cd6]py[/color][color=#d4d4d4] = python[/color] [color=#d4d4d4][TASK][/color][color=#569cd6]TASK[/color][color=#d4d4d4] = milltask[/color][color=#569cd6]CYCLE_TIME[/color][color=#d4d4d4] = 0.010[/color] [color=#d4d4d4][RS274NGC][/color][color=#569cd6]PARAMETER_FILE[/color][color=#d4d4d4] = linuxcnc.var[/color] [color=#d4d4d4][EMCMOT][/color][color=#569cd6]EMCMOT[/color][color=#d4d4d4] = motmod[/color][color=#569cd6]COMM_TIMEOUT[/color][color=#d4d4d4] = 1.0[/color][color=#569cd6]COMM_WAIT[/color][color=#d4d4d4] = 0.010[/color][color=#569cd6]BASE_PERIOD[/color][color=#d4d4d4] = 0[/color][color=#569cd6]SERVO_PERIOD[/color][color=#d4d4d4] = 5000000[/color] [color=#d4d4d4][HAL][/color][color=#569cd6]HALFILE[/color][color=#d4d4d4] = remora-xyz.hal[/color][color=#569cd6]POSTGUI_HALFILE[/color][color=#d4d4d4] = postgui_call_list.hal[/color] [color=#d4d4d4][TRAJ][/color][color=#569cd6]COORDINATES[/color][color=#d4d4d4] = X Y Z [/color][color=#569cd6]LINEAR_UNITS[/color][color=#d4d4d4] = mm[/color][color=#569cd6]ANGULAR_UNITS[/color][color=#d4d4d4] = degree[/color][color=#569cd6]CYCLE_TIME[/color][color=#d4d4d4] = 0.010[/color][color=#569cd6]DEFAULT_LINEAR_VELOCITY[/color][color=#d4d4d4] = 4.17[/color][color=#569cd6]MAX_LINEAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]NO_FORCE_HOMING[/color][color=#d4d4d4] = 1 [/color] [color=#d4d4d4][EMCIO][/color][color=#569cd6]EMCIO[/color][color=#d4d4d4] = io[/color][color=#569cd6]CYCLE_TIME[/color][color=#d4d4d4] = 0.100[/color][color=#569cd6]TOOL_TABLE[/color][color=#d4d4d4] = tool.tbl[/color] [color=#6a9955]#*** AXIS_X *******************************[/color][color=#d4d4d4][AXIS_X][/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 1080.0[/color] [color=#d4d4d4][JOINT_0][/color][color=#569cd6]TYPE[/color][color=#d4d4d4] = LINEAR[/color][color=#569cd6]HOME[/color][color=#d4d4d4] = 0.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 1080.0[/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]STEPGEN_MAXACCEL[/color][color=#d4d4d4] = 1000.0[/color][color=#569cd6]SCALE[/color][color=#d4d4d4] = 100.0[/color][color=#569cd6]FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]MIN_FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]HOME_OFFSET[/color][color=#d4d4d4] = 0.000000[/color][color=#569cd6]HOME_SEARCH_VEL[/color][color=#d4d4d4] = -45.000000[/color][color=#569cd6]HOME_LATCH_VEL[/color][color=#d4d4d4] = -2.500000[/color][color=#569cd6]HOME_SEQUENCE[/color][color=#d4d4d4] = 1[/color][color=#6a9955]#******************************************[/color] [color=#6a9955]#*** AXIS_Y *******************************[/color][color=#d4d4d4][AXIS_Y][/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 950.0[/color] [color=#d4d4d4][JOINT_1][/color][color=#569cd6]TYPE[/color][color=#d4d4d4] = LINEAR[/color][color=#569cd6]HOME[/color][color=#d4d4d4] = 0.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 950.0[/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]STEPGEN_MAXACCEL[/color][color=#d4d4d4] = 1000.0[/color][color=#569cd6]SCALE[/color][color=#d4d4d4] = 100.0[/color][color=#569cd6]FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]MIN_FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]HOME_OFFSET[/color][color=#d4d4d4] = 0.000000[/color][color=#569cd6]HOME_SEARCH_VEL[/color][color=#d4d4d4] = -45.000000[/color][color=#569cd6]HOME_LATCH_VEL[/color][color=#d4d4d4] = 2.500000[/color][color=#569cd6]HOME_SEQUENCE[/color][color=#d4d4d4] = 2[/color][color=#6a9955]#******************************************[/color] [color=#6a9955]#*** AXIS_Z *******************************[/color][color=#d4d4d4][AXIS_Z][/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 20.0[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 150.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -125.0[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 0.001[/color] [color=#d4d4d4][JOINT_2][/color][color=#569cd6]TYPE[/color][color=#d4d4d4] = LINEAR[/color][color=#569cd6]HOME[/color][color=#d4d4d4] = 0.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -125.0[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 0.001[/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 20[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 150.0[/color][color=#569cd6]STEPGEN_MAXACCEL[/color][color=#d4d4d4] = 187.5[/color][color=#569cd6]SCALE[/color][color=#d4d4d4] = 800.0[/color][color=#569cd6]FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]MIN_FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]HOME_OFFSET[/color][color=#d4d4d4] = 0.000000[/color][color=#569cd6]HOME_SEARCH_VEL[/color][color=#d4d4d4] = 15.000000[/color][color=#569cd6]HOME_LATCH_VEL[/color][color=#d4d4d4] = 0.625000[/color][color=#569cd6]HOME_SEQUENCE[/color][color=#d4d4d4] = 0[/color][color=#6a9955]#******************************************[/color]
# load the realtime components
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt remora-spi SPI_num=0 CS_num=0 SPI_freq=2000000
#loadrt remora_lpc chip_type=LPC SPI_clk_div=64
# estop loopback, SPI comms enable and feedback
net user-enable-out <= iocontrol.0.user-enable-out => remora.SPI-enable
net user-request-enable <= iocontrol.0.user-request-enable => remora.SPI-reset
net remora-status <= remora.SPI-status => iocontrol.0.emc-enable-in
# add the remora and motion functions to threads
addf remora.read servo-thread
addf remora.update-freq servo-thread
addf remora.write servo-thread
# Joint 0 setup
setp remora.joint.0.scale [JOINT_0]SCALE
setp remora.joint.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd <= joint.0.motor-pos-cmd => remora.joint.0.pos-cmd
net j0pos-fb <= remora.joint.0.pos-fb => joint.0.motor-pos-fb
net j0enable <= joint.0.amp-enable-out => remora.joint.0.enable
# Joint 1 setup
setp remora.joint.1.scale [JOINT_1]SCALE
setp remora.joint.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net j1pos-cmd <= joint.1.motor-pos-cmd => remora.joint.1.pos-cmd
net j1pos-fb <= remora.joint.1.pos-fb => joint.1.motor-pos-fb
net j1enable <= joint.1.amp-enable-out => remora.joint.1.enable
# Joint 2 setup
setp remora.joint.2.scale [JOINT_2]SCALE
setp remora.joint.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net j2pos-cmd <= joint.2.motor-pos-cmd => remora.joint.2.pos-cmd
net j2pos-fb <= remora.joint.2.pos-fb => joint.2.motor-pos-fb
net j2enable <= joint.2.amp-enable-out => remora.joint.2.enable
# inputs
#endstops
net X-min remora.input.01 => joint.0.home-sw-in
net Y-min remora.input.00 => joint.1.home-sw-in
net Z-min remora.input.02 => joint.2.home-sw-in
Creating a std module
Remora PRU - Programmable Realtime Unit
Mbed-OS6
Remora-spi Driver
## Entering SETUP state
1. Reading json configuration file
Mounting the filesystem... OK
Opening "/fs/config.txt"... OK
Json config file lenght = 1996
Closing "/fs/config.txt"...
2. Setting up DMA and threads
Initialising SPI1 slave
Initialising DMA for SPI
3. Parsing json configuration file
Config deserialisation - Deserialization succeeded
4. Config threads
Creating thread 40000
Creating thread 1000
Creating thread 57600
5. Loading modules
Servo thread object
Reset pin
Make Reset Pin at pin PC_15
Creating Pin @
port = GPIOC
pin = 15
Servo thread object
eStop
Make eStop at pin PG_12
Creating Pin @
port = GPIOG
pin = 12
Servo thread object
Spindle
Make PWM at pin PB_0
Creating variable frequency Hardware PWM at pin PB_0
Creating Pin @
port = GPIOB
pin = 0
Base thread object
Creating Pin @
port = GPIOG
pin = 2
Creating Pin @
port = GPIOF
pin = 9
Creating Pin @
port = GPIOF
pin = 10
Base thread object
Creating Pin @
port = GPIOF
pin = 1
Creating Pin @
port = GPIOC
pin = 13
Creating Pin @
port = GPIOF
pin = 0
Base thread object
Creating Pin @
port = GPIOD
pin = 4
Creating Pin @
port = GPIOE
pin = 2
Creating Pin @
port = GPIOE
pin = 3
Base thread object
Creating Pin @
port = GPIOE
pin = 0
Creating Pin @
port = GPIOE
pin = 6
Creating Pin @
port = GPIOA
pin = 14
Servo thread object
X min
Make Digital Input at pin PG_6
Setting pin as No Pull
Creating Pin @
port = GPIOG
pin = 6
Servo thread object
Y min
Make Digital Input at pin PG_9
Creating Pin @
port = GPIOG
pin = 9
Servo thread object
Z min
Make Digital Input at pin PG_10
Creating Pin @
port = GPIOG
pin = 10
Servo thread object
Probe
Make Digital Input at pin PG_11
Creating Pin @
port = GPIOG
pin = 11
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 24
power on Timer 9
Starting the SERVO thread
Registering interrupt for interrupt number = 25
power on Timer 10
## Entering IDLE state
## Entering RUNNING state
## Entering RESET state
Resetting rxBuffer
- unknown
- unknown
18 Sep 2025 19:02
Replied by unknown on topic 7i76E Spindle configuration
When you make a config the only changes are made in the linuxcnc/configs directory in your home folder.
No changes are made to any system files, none at all. So it doesn't matter how bad a config is made it does not affect anything outside of the above mentioned directory.
PCW is a very patient member of the forum and the guy that runs Mesa Electronics. This is the first time I have show any frustration with a forum member. Ever.
When you have an issue, with anything in this world, diagnosis follows a process. Whilst it may not make sense to you, it does to those offering advice. To go off do something that is unnecessary and you have been advised not is deeply disrespectful and can quite possibly throw a spanner in the works and bring you back to where you started. Eventually people may come to the conclusion that trying to help is not worth their.
The best course of action would be to go back and follow PCE's advice to the letter, do not skip a step.
For a second time does your spindle controller require an analogue voltage, or does it require a PWM signal. Actually it may be an idea to qualify what controller you are using and any documents pertaining to the spindle controller.
- meister
- meister
18 Sep 2025 18:46
- amanker
- amanker
18 Sep 2025 18:42
Replied by amanker on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Finally I got it working. I shortened the spi cables, reduced spi frequency, tried erasing and flashing remora via stm32cube, nothing worked. But after some time it automagically started working. I don't know how it worked?
- RobotMatic
18 Sep 2025 17:51 - 18 Sep 2025 17:52
- RobotMatic
18 Sep 2025 17:44 - 18 Sep 2025 17:50
- andronick83
18 Sep 2025 16:49 - 18 Sep 2025 16:50
Replied by andronick83 on topic automatic initialization of the axis interface in full screen
In the latest linuxcnc also works:
root_window.attributes('-zoomed', True)
Time to create page: 0.631 seconds
