  • scotth
  • scotth
16 Jun 2025 15:05
Replied by scotth on topic Linux vs Windows value
What government??
  • SebastianM
  • SebastianM
16 Jun 2025 14:48
Replied by SebastianM on topic Email Notification?
Email Notification?
Category: Forum Questions
When I write a reply I always tick the box “check this box to be notified of replies to this topic”, but I just don’t get any emails.
  • my1987toyota
  • my1987toyota's Avatar
16 Jun 2025 14:15
Replied by my1987toyota on topic Linux vs Windows value
The Windows 11 slogan should be " We aren't spying for the Government honest."
  • PCW
  • PCW's Avatar
16 Jun 2025 13:46
Replied by PCW on topic Rote LED
Rote LED
Category: Deutsch
60000 packets transmitted, 59992 received, +8 errors, 0.0133333% packet loss, time 60099ms
rtt min/avg/max/mdev = 0.048/0.133/6.074/0.075 ms, pipe 9
Not good
What host hardware do you have (CPU and Ethernet chip)?
16 Jun 2025 12:37
Replied by tommylight on topic Email Notification?
Email Notification?
You have to subscribe. Its not automatic
It was for any topic you replied to or started. And you could subscribe to any topic manually.
No idea if that is the case now as i get e-mails for every post.
16 Jun 2025 12:34
Email Notification?
Ok. Guess if they work for you they work for everyone.
I did not say that.
  • rodw
  • rodw's Avatar
16 Jun 2025 12:18
Replied by rodw on topic Email Notification?
Email Notification?
  • rodw
  • rodw's Avatar
16 Jun 2025 12:12
Replied by rodw on topic Linux vs Windows value
I've been forced to use Windows again recently. Scarlett Solo Sound card supported natively in Linux needed a driver install and then it would fail every second start. I did manage to install an old Office license key after a forced upgrade, several restarts, a hang and attempts  to wean me off Chrome! Now I am on Win 11 so excited :(
  • Jens23
  • Jens23
16 Jun 2025 12:12
Replied by Jens23 on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Did you ever get a Beckhoff AX5xxx vfd and got it running? I am looking for something I can work with but there isn't really that much about these vfds and linuxcnc ethercat out there.
  • rodw
  • rodw's Avatar
16 Jun 2025 12:05
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
You should be able to set up auto login the same way it is done with an x86 machine as its the OS you are logging into
  • meister
  • meister
16 Jun 2025 11:56
Replied by meister on topic Modbus T3D Servo Treiber
Category: Deutsch
und wenn du P-076 einfach versuchst zu schreiben sobald du eine andere geschwindigkeit nutzen möchtest ?
  • m3chanist
  • m3chanist's Avatar
16 Jun 2025 11:49
Replied by m3chanist on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
"What's wrong? I'm using Stepperonline A6 motors, but they're the same as the EL8, just with a different name. "
Are you sure?
I had a look at those A6 drives, from appearance they look nothing at all like my EL8's. Similar form factor, that's about it.
  • tar_san
  • tar_san
16 Jun 2025 11:43
Replied by tar_san on topic Missing link in homing LC10E
Category: EtherCAT
Hello everyone.
I need help for homing LC10E.
I've read cia402.comp and cia402_homecomp.comp ( the latest version )
1)
This line was commented out in last commit in cia402_homecomp.comp Line 217.
//customH[joint_num].request_custom_homing = 1;
2)
In HAL,
net x-home-request joint.0.request_custom_homing => cia402.0.home
I think cia402.opmode doesn't change to homing mode(6) because of it.
Should I use older version of cai402_homecomp to get driver-homing work?
(if in this situation, which version should I use ? )
  • Hakan
  • Hakan
16 Jun 2025 11:41
Cumark Closed-Loop VFD with EtherCAT (non-CiA402) Configuration
Category: EtherCAT
One need a vfd expert rather than an EtherCat expert I would say.
You say you get the same results using TwinCAT, that's good since it rules out linuxcnc being the problem.
Unless you get some good tips here you should probably go to the seller/manufacturer and ask them to provide details to make the vfd work.
But the behavior of the vfd doesn't seem correct.
Anyway, I looked at the config and manual and it may perhaps be that the start command should only be given a short time, really only one cycle. So give start 882 and immediately after 880. Same for stop: 881 followed by 880. Just a possibility, you must test to verify. If that turns out to be the case you can use the "oneshot" hal component.
Not sure what you mean regarding 06.05. 06.05 is the controlword you send to the vfd, right?
  • Jens23
  • Jens23
16 Jun 2025 11:39
Replied by Jens23 on topic Einbindung AX5000 und EL3104
Category: Deutsch
Hallo,
hast du den AX5106 jemals zum Laufen bekommen? ich möchte den für meine nächste Spindel nutzen, da die einen Encoder drin hat und die Position regeln soll.
Würde mich interessieren.
Displaying 1471 - 1485 out of 25065 results.
Time to create page: 0.337 seconds
