  • Micro2000
  • Micro2000
07 Nov 2024 13:24
Replied by Micro2000 on topic LinuxCNC Error
LinuxCNC Error
this is what returned
sudo gdebi '/home/dylan/Downloads/linuxcnc_2.9.3_amd64.deb'
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
motion controller for CNC machines and robots
 LinuxCNC is a fully-realised CNC machine controller that can interpret
 machine-control programs (such as G-code), plan trajectories and finally
 output low-level signals to machine control hardware
 LinuxCNC is modular and in principle the HAL (hardware abstraction layer),
 pluggable interpreters and variety of hardware drivers mean that it can
 control almost any software-defined physical system.
 LinuxCNC relies on a realtime kernel to support real-time motion control,
 typically updating the position waypoints every 1mS and reacting to
 input within tens of microseconds.
 Modules exist to use the low-level parts of LinuxCNC as a motion-control
 client for OpenPnP. Interfaces exist for ROS (the Robot Operating System)
 with which LinuxCNC has considerable overlap.
 LinuxCNC supports arbitrary kinematics (the mapping between coordinate
 space and actuator space) and can control both parallel (eg Stewart
 platform) and serial (eg robot arm) systems in addition to conventional
 cartesian machine tools.
 LinuxCNC supports 9 cartesian axes and 16 "Joints" (individual actuators)
 though the joint limit is build-time configurable.
 A variety of interface hardware is supported including Modbus, EtherCAT,
 analogue +/-10V velocity control and Step/Dir. Step/Dir is supported by
 several hardware interfaces, including, but not limited to, the legacy
 Parallel Port.
 A Hardware Abstraction Layer allows for great flexibility in signal
 mapping between the controller and the driver hardware. An extensive
 library of modules allow for complex signal processing within the HAL
 layer. For specialised tasks custom HAL components can be created using
 a C-like syntax and installed with the supplied tools.
 By default LinuxCNC supports RS274 G-code but is extendable to parse
 other grammars such as STEP-NC or Gerber through support for pluggable
 interpreters.
 If you want a computer to control things in the real world
 then LinuxCNC can do it. It is especially applicable to systems that
 are required to follow accurate paths described in cartesian space but
 has been used for numerous other applications.
 This package provides the main package for LinuxCNC.
Do you want to install the software package? [y/N]:y
/usr/bin/gdebi:113: FutureWarning: Possible nested set at position 1
  c = findall("[[(](\S+)/\S+[])]", msg)[0].lower()
(Reading database ... 185376 files and directories currently installed.)
Preparing to unpack .../linuxcnc_2.9.3_amd64.deb ...
Unpacking linuxcnc (1:2.9.3) ...
dpkg: error processing archive /home/dylan/Downloads/linuxcnc_2.9.3_amd64.deb (--install):
 trying to overwrite '/usr/share/applications/linuxcnc-documentation.desktop', which is also in package linuxcnc-doc-en 1:2.9.3
Processing triggers for libc-bin (2.36-9+deb12u7) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Errors were encountered while processing:
  • Aciera
  • Aciera's Avatar
07 Nov 2024 13:02 - 07 Nov 2024 13:04
Replied by Aciera on topic Remap of M6 not working correctly
The other thing (but maybe of no importance here) is that your ini files use FEATURES in the [RS274NGC] section
# turn on all optional features except RETAIN_G43
FEATURES= 30
which has been replaced by individual entries:
  • Aciera
  • Aciera's Avatar
07 Nov 2024 12:55
Just noticed this, there are two ini files in that config. Are you running 'Biesse.ini' or ''racktoolchange.ini'?
  • Aciera
  • Aciera's Avatar
07 Nov 2024 12:49
'tool_change started' was printed when the read-ahead ingested that line and then it stopped reading due to the queuebuster and waited for code execution to catch up. What this means is that the actual code execution does not reach the 'tool_change' subroutine.
Not sure what's going on but whatever it is it does not seem to be a problem in 'tool_change.ngc'.
Have you tried calling that subroutine directly from MDI:
o<tool_change> call
  • viesturs.lacis
  • viesturs.lacis
07 Nov 2024 11:01
Replied by viesturs.lacis on topic Remap of M6 not working correctly
Ok so what I did and what whas the result is shown in 2 pictures attached.
In the tool_change.ngc I added following lines so that the beginning was this:
o<tool_change> sub
(print, tool_change started)
M66 E0 L0
(print, tool_change after 1st queuebuster)
M73 (auto-restore modal settings on return)
M66 E0 L0
(print, tool_change after 2nd queuebuster)
G0 G53 X20 Y20 Z80
M66 E0 L0
(print, tool_change after 3rd queuebuster)
(MSG, Tool change: loaded tool=#<_current_tool> )
(MSG, Tool change: selected tool=#<_selected_tool> )
M66 E0 L0
(print, tool_change after 4th queuebuster)
The result is that in the terminal only the first message is posted. Meaning that it did not get past that queuebuster line. What was expected behavior there? I do not have anything connected to motion.analog-in-00 so I would expect it to read value "zero" and move on...
  • Grotius
  • Grotius's Avatar
07 Nov 2024 10:16
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
@Aleksamc,
But maybe it will be never realized
The linuxcnc sai lib, can maybe run multiple instances of the interpreter.
But that's not tested as this point.
The rs297 lib is tangled with python. Linked to many other lcnc libs.
This makes it hard to decouple and test it stand alone.
But you make it so easy!!! I very impressed about that!
The hardest part to figur out where the "unlimited" nested while loops.
Parsing a raw gcode file to something the interpreter can read is not that hard.
@Spumco,
Such as X1/X2, Y1/Y2, Z1/Z2, C1/C2, etc.
As i understand you want to send a X2 from master to slave machine directly in the gcode.
This is not realised yet. And i think the command should look a little different as the slave's have a name.
prototype : [Command_id] [Name] [Command]
Then you should send a command like "G200 n2 G0 X100 Y100 Z100 C0".
or something like  "SEND n2 G0 X100 Y100 Z100 C0".
Where G200 is a chosen as command_id.
Where n2 is the name of the duplicated axes (XYZC).
@Arciera,
That's exactly how it is!
And it's not easy to code this into lcnc. As everything is based on one instance of lcnc.
However it's interesting to try  to setup multiple hal environments.
This is an idea of how it might work:
Websocket line
    | - GUI Application (websocket client) (user land)
    | - HAL Environment A    (Super-Imposed Interpreter) (websocket server) (kernel space)
    | - HAL Environment B    (Machine controller 1) (websocket client) (kernel space) -|
    | - HAL Environment C    (Machine controller 2) (websocket client) (kernel space) -|
    | - HAL Environment D    (Machine controller 3) (websocket client) (kernel space) -|
        Ethercat bus
** Ps, Relating the the lcnc trajectory's planner, soon i have to make a opencascade viewer to check the fillet output's made
in the tpmod.so component. As i can not see anything now.
  • michaeln
  • michaeln
07 Nov 2024 10:12 - 07 Nov 2024 10:13
Replied by michaeln on topic ESP32 HAL2UDP setup for linux CNC noob.
Are the linux commands the problem?
Please use:
sudo apt install linuxcnc-uspace-dev
sudo apt install build-essential
sudo halcompile --install udp.comp
  • viesturs.lacis
  • viesturs.lacis
07 Nov 2024 09:39
I did insert G0 G53 X20 Y20 Z80 right after that M73 and the move is not executed. Ok, I will go back now and try your suggestion.
07 Nov 2024 08:36
Replied by tommylight on topic Suggestion for a PCI EPP card for 7i43
Check the green/black header.
07 Nov 2024 08:30
Replied by tommylight on topic Please help create atc code
Category: Configuration Tools
That is called a "rack tool changer", i am pretty sure it can be controlled with gcode only, not sure if it needs remaping (i guess it would), so it should be easy to do, although i never tried it.
forum.linuxcnc.org/20-g-code/36441-anyon...-length-probe#131714
  • Aciera
  • Aciera's Avatar
07 Nov 2024 08:17
Replied by Aciera on topic Please help create atc code
You might want to have a look at the example config in 'configs/sim/axis/remap/rack-toolchange' as a starting point.
Note the custom entries at the bottom of the inifile:
github.com/LinuxCNC/linuxcnc/blob/master...e/racktoolchange.ini
and the ngc remap:
github.com/LinuxCNC/linuxcnc/blob/master...ines/rack_change.ngc
  • Danil
  • Danil
07 Nov 2024 08:03
Replied by Danil on topic Please help create atc code
I have a spindle equipped with this feature for pidconnection to a relay. I need an approximate code M6 for linear tool change
  • Aciera
  • Aciera's Avatar
07 Nov 2024 07:57
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
Hm, as I understand it, this does _not_ give us multi thread gcode execution as that would require multiple parallel motion planners in the same linuxcnc instance. A single instance of linuxcnc cannot interpolate more than one tool path at the same time.
  • juliankoenig87
  • juliankoenig87
07 Nov 2024 07:56
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Thank you all.
So, I will give it a try. As far as I can see there is no header on the motherboard (small form factor).
07 Nov 2024 07:40
Replied by tommylight on topic LinuxCNC Error
LinuxCNC Error
sudo gdebi linuxcnc_2.9.3_amd64.deb
In the same folder where the downloaded files are.
Displaying 18526 - 18540 out of 24128 results.
Time to create page: 0.406 seconds
