25 Oct 2024 14:59
Replied by tommylight on topic IP Blocked
IP Blocked
Category: Forum Questions
Might be, so in settings see if there is something like "load tabs in background" and set it to off.
I use FireFox and usually have 50 to 200 tabs open with mixed content, but i never have issues.
  • spontarelliam
  • spontarelliam
25 Oct 2024 14:46
Replied by spontarelliam on topic IP Blocked
IP Blocked
Thank you, it worked!
Very strange. If I open a web browser that has 10 linuxcnc.org tabs open on it, would all of those loading at once cause issue?
25 Oct 2024 14:27
IP Blocked
I have unblocked your IP, although having looked at the logs, it will probably be blocked again as it was blocked 4 times in a very short period, for 30 minutes at a time.
You should really check your PC/laptop/phone or whatever you use to login here for malware.
  • rajsekhar
  • rajsekhar
25 Oct 2024 13:37
5 axis kinematics implementation was created by rajsekhar
I am configuring a spindle tilt (AB tilt) type 5axis (XYYZABC) machine, where C axis is optional rotary head.
Joint0->X, Joint1->Y, Joint2->Y1, Joint3->Z, Joint4->A, Joint5->B, Joint6->C
HAL, INI file attached.
Now I want to add TCP mode. I modified a kinematics component file (atiltbtiltkins.c; attached). I am not sue whether that is correct or not, need testing.
But how to implement/ activate this kinematics file?
  • Grotius
  • Grotius's Avatar
25 Oct 2024 13:11
Replied by Grotius on topic linuxcnc trajectory planner
Hi Arciera,
For test, i removed homemod.so from the rtlib and did :
~/linuxcnc_trajectory_planner/src$ make BUILD_VERBOSE=1
Output of this:
Reading 203/203 dependency files
Done reading dependencies
Reading 266/266 realtime dependency files
Done reading realtime dependencies
Linking ../rtlib/homemod.so
ld -d -r -o objects/homemod.tmp objects/rtemc/motion/homemod.o objects/rtemc/motion/homing.o
objcopy -j .rtapi_export -O binary objects/homemod.tmp objects/homemod.sym
(echo '{ global : '; tr -s '\0' < objects/homemod.sym | xargs -r0 printf '%s;\n' | grep .; echo 'local : * ; };') > objects/homemod.ver
gcc -shared -Bsymbolic -Wl,--version-script,objects/homemod.ver -o ../rtlib/homemod.so objects/rtemc/motion/homemod.o objects/rtemc/motion/homing.o -lm -L/home/user/linuxcnc_trajectory_planner/lib -Wl,-rpath,/home/user/linuxcnc_trajectory_planner/lib -ltirpc  -lgpiod
chmod -x ../rtlib/homemod.so
You now need to run 'sudo make setuid' in order to run in place with access to hardware.
-Wl,
is a prefix used to pass options directly to the linker.
sets the runtime library search path for the executable
Now these are added here and here we have to use
${SRC_DIR}
as this is the cmakelists.txt current directory.
Relative from here the filepath is compiled with it.
I hope this solves the problem.
25 Oct 2024 13:00
IP Blocked
We got mail, i am not near my PC so will check later as it seems JT was online now.
  • meister
  • meister
25 Oct 2024 12:59
the 'spaces in name' problem is fixed, i replace it with '_' now.
25 Oct 2024 12:59
Replied by tommylight on topic Getting Gnome desktop.
Category: Installing LinuxCNC
Those are probably wrong, just pasted from the net as i do not use gnome.
Should be 2 l and 2 m, either way it will complain if it is wrong.
  • spumco
  • spumco
25 Oct 2024 12:58
Russian machine tool company that uses LinuxCNC with Probe Basic
Category: QtPyVCP
Yeah that is shameful, and pretty sure it is illegal. Did anyone check our license?
I believe LCNC is covered under GNU GPL-2.0 (as published on github).
The GNU page has a quite good FAQ on the license, but as with most legal issues nothing is black and white.
It's possible that because APSX (and other LCNC re-packagers) are distributing LCNC-derived software to the public, they are required to provide source code to anyone who asks - but I'm not an IP lawyer.
There are plenty of smart people around who are intimately familiar with the details of enforcing/managing a GPL license.
  • JT
  • JT's Avatar
25 Oct 2024 12:51
Replied by JT on topic Flex GUI Tutorials
Flex GUI Tutorials
Category: Other User Interfaces
Tutorial 12
JT
  • meister
  • meister
25 Oct 2024 12:41
the tangbob board is updated 2weeks ago,
because i had problems with the 1.8V pins:
github.com/multigcs/rio-tangbob
this updated version is not tested, but it should work (there is only a new diode to drop the voltage on the level-shifters)
the ICE40 on the iceshield board is not BallGrid but also hard to solder by hand,
not necessarily the FPGA, but the 2.5V diode, which is extra small and you don't really recognize the direction.
I would wait for digiex_chris's Version or ask him if he have a spare one.
Octobot: remember that the icewerx board also costs money.
RPI-Pins:
MOSI, MISO, SCLK, CS0, CS1, GPCKL0, GND, 3.3V, 5V
all other pins are not connected and freely usable, don't know if there was a ready to use lcnc component, but a little python-script will do the job
  • spontarelliam
  • spontarelliam
25 Oct 2024 12:21
IP Blocked
Ok i just reported it again on my post from the 23rd
  • gitano
  • gitano
25 Oct 2024 12:15 - 25 Oct 2024 12:16
aah, stupid me -> i actually named that pin "P8 OUT" in the Name section, changing the name to "P8_OUT" -> all works well x)
regarding 1) - 4) -> that clarifies a lot, thank You very much!
Well, i am considering ordering a small batch from JLPCB, the last layout on github (edited in August) is working ok, so far?
speaking about that and looking at the prices there i am considering getting some octobot and iceshield boards as well, they look too tempting to ignore and would be fun to toy around with
I am still not sure about 2 things regarding the iceshield:
- ball soldering sounds indeed frightening... i tried that once with a CPU socket of an old mainboard (bent pins) and failed completely x) There is a version on here with pre-soldered SMD parts, maybe i should go this route?
- as i get it, the communication between RPI and shield goes via SPI, so just 4-5 pins, correct? what about the other GPIO pins, can these still be used f.e. by soldering a connector on top of the shield? Is there actually a component for using these with LinuxCNC?
Thank You very much!
Cheers,
-lgitano
  • JT
  • JT's Avatar
25 Oct 2024 12:09
Flex GUI 1.0.2 released was created by JT
I'm pleased to announce that Flex GUI 1.0.2 has been released with many improvements.
JT
Displaying 19231 - 19245 out of 24144 results.
Time to create page: 0.594 seconds
