  • chris@cnc
  • chris@cnc
04 Aug 2024 15:49 - 04 Aug 2024 15:52
Replied by chris@cnc on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Hello PCW,
thank you for your answers! (sorry for delay, I was very busy the last days and couldn't do anything at my machine.)
I tried the lines in /etc/network/interfaces file and  after reboot my internal Intel network was disabled. Just  auto internet with RLT8111 is possible. The file is as follows:
Well, internet network is ok. What is the faulty setting here?
That's fine, but the wrong card was configured. I suspect that the Intelcard is calling enp2s0. Try modifying the file this way.
auto enp2s0
       iface enp2s0 inet static
           address 10.10.10.2
           hardware-irq-coalesce-rx-usecs 0
auto eno1
iface eno1 inet dhcp
  • Moutomation
  • Moutomation
04 Aug 2024 15:44
  • scotth
  • scotth
04 Aug 2024 15:25
Replied by scotth on topic Compensation Z axis respect at Y
Category: CNC Machines
If you can get the comp correct for Y Z it will help to use W axis rather than Z for boring.
  • jdowsonjr
  • jdowsonjr
04 Aug 2024 15:20
Ethercat installation from repositories - how to step by step
Category: EtherCAT
tried to write the iso from the post above to a usb twice. Both times after selecting locale in the installer i get that a file failed to be copied
live enviroment works fine but the installer is not there
has anybody else tried it?
  • frogandspanner
  • frogandspanner
04 Aug 2024 15:19
Replied by frogandspanner on topic Quadrature decoding to produce pulse + direction
Category: HAL
Ignore my stupidity - I have sorted the problem out.
I had though I was being clever in simplifying the HAL I was using, but to make it do what I wanted meant that the result was going to be more complex than the way I had already been doing things.
  • MarkoPolo
  • MarkoPolo
04 Aug 2024 15:10
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Great.
That all works.
You could also add "dro_axis_*" to the "button_response_list"
in the handler file so that these functions are not available during operation.
  • anfänger
  • anfänger's Avatar
04 Aug 2024 14:52 - 04 Aug 2024 15:58
Replied by anfänger on topic Mesa Analog Vs Step Dir
Category: Driver Boards
had still the oscillation.
But I dug myself a little deeper into the usage of pncconf with the discovery option and made a mint config file which I merged into my old config.
and the oscillation is gone and the axis are moving.
And just when I wanted to edit the post above when I saw you already answered.
here files which ware working now. also found out the the scale was wrong and adjusted it.
File Name: wully_2024-08-04.hal
File Size:31 KB
File Name: probe_basi...8-04.ini
File Size:7 KB
  • PCW
  • PCW's Avatar
04 Aug 2024 14:46
Replied by PCW on topic Mesa Analog Vs Step Dir
What are the specific issues you have now?
  • cmorley
  • cmorley
04 Aug 2024 14:44 - 04 Aug 2024 14:46
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
Here are the stylesheet properties, you can turn them on and off as you please.
They will change immediately.
DROLabel{
qproperty-showLast: true;
qproperty-showDivide : true;
qproperty-showGotoOrigin: true;
qproperty-showZeroOrigin: true;
qproperty-showSetOrigin: true;
 AxisToolButton{
qproperty-showLast: false;
qproperty-showDivide : false;
qproperty-showGotoOrigin: false;
qproperty-showZeroOrigin: false;
qproperty-showSetOrigin: false;
  • Moutomation
  • Moutomation
04 Aug 2024 14:38
Replied by Moutomation on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
Instead of binding this key to a button, is there a way to refresh the g-code file every few seconds while the g-code is not executing? I want to automatically load the g-code file into linuxcnc continuously. The name of the g-code file is always the same and never changes.
04 Aug 2024 14:09
Replied by tommylight on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
You will most probably have to reinstall everything.
In the networking HOWTO it is clearly stated to use that OR the /etc/network method, NEVER both!
You are using both. It also states to edit the existing wired connection, you did not, you added another one to the same interface.
Now you have 3 networks with the 2 of the same IP on a single interface, as you did not edit the existing one, but you added another one.
Try deleting every wired connection from the network manager and reboot.
If this does not work, reinstalling everything is the fastest way to get up and running, trying to fix this mess takes much longer.
  • Muftijaja
  • Muftijaja
04 Aug 2024 13:51 - 04 Aug 2024 13:52
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
OK, I switched ipv6 off in both networks, no effect. And I added the adress 10.10.10.2/24 in the four lines in etc/network/interfaces
Same issue as before. I'm asking me why there is this altname fault in ip a. I definitely have the right definitions in the two network settings, eno1 and eth2
(coming back later, have to bring the dog back to my son)
  • Muftijaja
  • Muftijaja
04 Aug 2024 13:40
Category: Deutsch
netmask is set to 10.10.10.2/24. Any alternative netmask?
  • PCW
  • PCW's Avatar
04 Aug 2024 13:29 - 04 Aug 2024 13:40
Replied by PCW on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
The only thing that I see is  different is the netmask
you might try
address 10.10.10.2/24
Also ipv6 has been enabled, which is really odd
  • Muftijaja
  • Muftijaja
04 Aug 2024 13:26
Category: Deutsch
Hmm I tried both, changed priorities eno1 to 1 and auto/enp2 to 0 - no effect.
Then I changed the position of the lines in /etc/network/interfaces - no effect at all.
On what reason ever, the network definitions are faulty.
WTF is going on there?
Displaying 23806 - 23820 out of 25058 results.
Time to create page: 2.745 seconds
