  • Aciera
  • Aciera's Avatar
02 Aug 2024 15:40 - 02 Aug 2024 15:41
Replied by Aciera on topic Closed Loop Computer Vision Enabled CNC
Category: QtPyVCP
Regarding OpenCV there is also Dmitry's Pick and Place machine, uses OpenCV (python) for parts positioning and angular alignment.
his config files can be found here:
github.com/yur7aev/linuxpnp/tree/master/configs/pnp
  • Aciera
  • Aciera's Avatar
02 Aug 2024 15:30
Category: QtPyVCP
No need for additional controllers but you would likely need to write a custom hal component to get your machine vision results into hal.
There is a simulation configuration 'configs/sim/axis/external_offsets/eoffsets' with external offsets for X,Y,Z axes (this will also run on a non-real time installation):
  • skunkworks
  • skunkworks
02 Aug 2024 15:29
Replied by skunkworks on topic Closed Loop Computer Vision Enabled CNC
Category: QtPyVCP
I would look at opencv.. (I think it is still a thing) I goofed around with it a few years ago with linuxcnc.. I can see if I can find the python code...
  • Sandro
  • Sandro
02 Aug 2024 15:28
Replied by Sandro on topic Homing with Absolute Encoders (Again)
Yes correct these are the only lines I have kept. I have set HOME_SEQUENCE = -1 for now so I am forced to home at startup in order to get the soft limits active. This way I will not move the axes by accident without limits in place. Later I plan to automate it so I don't need to press the button anymore.
  • meister
  • meister
02 Aug 2024 15:28
I did a test with the new w5500.v, initialization of the IP seems to work, I can ping.
but port 2390 is not open :( so I can't communicate with it either
  • Hauligali22
  • Hauligali22
02 Aug 2024 15:08
Replied by Hauligali22 on topic Closed Loop Computer Vision Enabled CNC
Category: QtPyVCP
This is very interesting. Would I need additional controllers or components to enable this external offset feature or could I run this directly from LinuxCNC? Has this type of feature been explored on multiple axes simultaneously? Thanks for the response!
  • PCW
  • PCW's Avatar
02 Aug 2024 15:05
Replied by PCW on topic Error at startup
Error at startup
Category: Configuration Tools
There does not seem to be any parallel port reference in the hal files.
Maybe the generic "cannot gain I/O privileges" message includes
the parallel port warning.
This "cannot gain I/O privileges" message does suggest a build
problem with the LinuxCNC version he is using.
  • Aciera
  • Aciera's Avatar
02 Aug 2024 14:53
Replied by Aciera on topic Monitoring SDO value
Category: EtherCAT
Admin, maybe this could be moved to the EtherCAT section.
  • Mecanix
  • Mecanix
02 Aug 2024 14:48
If you have a look at the figures on the wiz net wiki you’ll see as packet size drops so does the overall throughput.
All I could find is the implementation and proposed data integrity stuff. I know you're past your daylight but when you have a chance tomorrow, see if you can find that bit of info you ref'ed and we'll talk to their engineer about it. See if we can flip a Magic Register to disable that supposedly/suspected throttling thingy...
Impl. Ref: docs.wiznet.io/Product/iEthernet/W5500/Application/udp
  • Aciera
  • Aciera's Avatar
02 Aug 2024 14:45 - 02 Aug 2024 21:26
Replied by Aciera on topic Homing with Absolute Encoders (Again)
Oh my, totally missed that one. Thanks for reporting back.
Actually, I think this may be all you need:
HOME_ABSOLUTE_ENCODER = 2
HOME_SEQUENCE        = 0
  • Mecanix
  • Mecanix
02 Aug 2024 14:29
I’ve only access to Xilinx and Lattice stuff ATM.
Yeah standard .v clocking stuff. Just need to change your pinouts (pin mapping in the *cst, in it current format).
That'd be awesome man. Let us know what you come up with when/if you can.
Have a good one [beer_cheers_emoji_here!]
02 Aug 2024 14:19
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
When running within the context of Linuxcnc in a basic setup 21 byte packets are being sent via UDP back and forth at the servo thread speed of 1ms, now that 21 bytes doesn’t include the source & dest port and addresses.
So it would be interesting to see how it would go sending smaller packets back and forth at 1ms intervals, as this would being replicating what the situation is when running Linuxcnc.
I will try and have a look but I’ve only access to Xilinx and Lattice stuff ATM. Tho I do have a few W5500 modules in 2 different formats.
  • scottlaird
  • scottlaird's Avatar
02 Aug 2024 14:18
Replied by scottlaird on topic Exotic data types in .xml config
Category: EtherCAT
Ah, yeah, the EL6751. I keep meaning to get around to trying to use mine for something, but it looks like more work than I really want right now :-).
The problem with mapping anything more complex than ints or floats is that LinuxCNC doesn't really have a good type to hold them, so there's no good way to create a pin for them. Even if we had an array of ints, there's no array type in LinuxCNC. OTOH, a fixed-size array is pretty trivial to map to 8 individual ints.
I'd love to see a working EL6751 config for *anything*; IIRC people have claimed that they've got it working once or twice, but I don't think we do a very good job at it.
If we *really* wanted to do a good job with the EL6751, we'd probably want to refactor LCEC to create a generic CANopen layer (PDOs, SDOs, etc), and then tie that to a lower-level EtherCAT layer plus a lower-level CANopen layer. Then the EL6751 could be a CoE EtherCAT device that exports a CANopen interface that we could run CANopen devices on top of.
That'd let us use generic CAN devices, and maybe even some RS485 devices, in addition to the EL6751 for talking to CANopen CiA 402 devices and so forth.
Except we don't actually *want* to use most CAN CiA 402 devices, because they don't support CSP/CSV modes, because CAN isn't fast enough. Mostly.
Anyway, it'd be a lot of work, and I'm not sure that there's a real payoff.
  • Sandro
  • Sandro
02 Aug 2024 14:14 - 02 Aug 2024 14:34
Thank you Aciera!
I just changed the settings to these random values:
HOME_OFFSET = 0
HOME = 0
HOME_SEARCH_VEL = 30
HOME_LATCH_VEL = -5
HOME_FINAL_VEL = 10
HOME_USE_INDEX = YES
HOME_SEQUENCE = 0
HOME_IGNORE_LIMITS = YES
Now it works as intended and my absolute position persists through the homing process (not set to zero anymore). But no idea why...
[edit]
Alright I have found it. It was a simple spelling mistake in the HOME_ABSOLUTE_ENCODER = 2 line. This led to the setting not beeing applied. Nothing to do with the other lines. In fact I can delete anything about homing besides the absolute encoder setting = 2. Feel really stupid now :D
  • Mecanix
  • Mecanix
02 Aug 2024 14:11
You had me worried. Thought you had a go at it and already binned hope! Wish I'd be able to give it a TRUE Lcnc perf stress-test myself but can't - dependent on meister on that side of things. If you needed 'delays', those spi and w5500 sync'd state machines should deliver that magic plenty ;)
Let's try again when the weather is better... f n inferno hot here lool
Displaying 23971 - 23985 out of 25069 results.
Time to create page: 0.564 seconds
