01 Aug 2024 16:09
A strange 5 axis machine detailed build log with limited tools, on youtube
Category: Show Your Stuff
NOT my stuff!!!
Several videos of building a strange 5 axis machine with hand tools, he does a great job of explaining every step in detail:
  • Thayloreing
  • Thayloreing
01 Aug 2024 16:07
How to make Linuxcnc open with the feed and override 0?
Thank you very much, I will test it as soon as possible, get back to you if everything goes well
  • Mecanix
  • Mecanix
01 Aug 2024 15:52
hmm, ok fair enough. I'm no expert and so glad you are. I'm quite grateful I can actually get step pulses out to the oscope and comm with Lcnc already. Pretty cool. Guess fine-tuning this comm reliably will require some significant effort (knowledge?). I'll have a look at the RMII and Esp32 solutions when time allows, and see what comes out. Expect stupid/clueless questions coming your way soon enough though!!
01 Aug 2024 15:48
Replied by tommylight on topic help with installation
Category: Installing LinuxCNC
Do a new full install and start over.
Never use root or SU to install stuff as everything will be installed in the root folder and nothing will work as a normal user, always use sudo.
LinuxCNC will refuse to run as root due to having full hardware control and stopping misuse.
  • besriworld
  • besriworld
01 Aug 2024 15:36
Replied by besriworld on topic Tuning of servo-drive
Category: EtherCAT
MIN_FERROR = 0.010 - This is the value in machine units by which the joint is permitted to deviate from commanded position at very low speeds. If MIN_FERROR is smaller than FERROR, the two produce a ramp of error trip points. You could think of this as a graph where one dimension is speed and the other is permitted following error. As speed increases the amount of following error also increases toward the FERROR value.
FERROR = 1.0 - FERROR is the maximum allowable following error, in machine units. If the difference between commanded and sensed position exceeds this amount, the controller disables servo calculations, sets all the outputs to 0.0, and disables the amplifiers. If MIN_FERROR is present in the INI file, velocity-proportional following errors are used. Here, the maximum allowable following error is proportional to the speed, with FERROR applying to the rapid rate set by
If you are on the factory settings of the PID regulator. They are almost always very soft. They must be set up.
When the driver is activated, the motor axis must be locked - by hand, the axis must not move.
  • meister
  • meister
01 Aug 2024 15:33 - 01 Aug 2024 15:35
the rmii code is not mine, unfortunately my knowledge of verilog is not sufficient for that, i have only adapted it to rio
github.com/sipeed/TangPrimer-20K-example...Ethernet/verilog_UDP
you can run the rio-test tool to see the timeouts:
PYTHONPATH=. bin/rio-test riocore/configs/MecanixDev/config-test.json 192.168.10.194:2390
all in all, it works quite well with the w5500, but with the esp32 I get no timeouts at all
EDIT: the ping is completely handled inside the W5500, so it's not a good test
  • Mecanix
  • Mecanix
01 Aug 2024 15:33
Comparison added for the sake of having something to compare too. Nothing scientific ofc, however goes to show. Here's me brutalizing the gateway the same way, yet here we are talking, lket alone streaming 4k vids, dwloading gigabytes of data from int'l servers.
I'm not an network expert but, this W5500-over-RIO seems to be bullet proof!! Fairly impressed already.
  • cnbbom
  • cnbbom
01 Aug 2024 15:32
Replied by cnbbom on topic help with installation
I can now say what condition I am in
  • Aciera
  • Aciera's Avatar
01 Aug 2024 15:11 - 01 Aug 2024 15:22
Save this as 'feed_zero.py', mark as executable and save to a folder called 'python' inside your machine config:
#!/usr/bin/env python
import hal
import linuxcnc
h = hal.component("feed_zero")
h.ready()
# create a connection to the status channel
s = linuxcnc.stat()
# create a connection to the command channel
c = linuxcnc.command()
file_last = None
try:
    while 1:
        s.poll() # get values from the status channel
        if s.enabled:
            file = s.file
            if s.task_mode != 2 and file != file_last :
                c.feedrate(0)
                c.rapidrate(0)
            file_last = file
except KeyboardInterrupt:
    raise SystemExit
Then add this line to the [HAL] section of your ini file:
HALCMD = loadusr ./python/feed_zero.py
This should then zero the feedrate and rapid-feedrate when the machine is first enabled and also whenever a new gcode file is loaded.
Note this will not zero the feedrates if the same file is loaded/reloaded.
  • Mecanix
  • Mecanix
01 Aug 2024 15:02
i am not yet satisfied with the W5500, better not to plan for it, there are packet losses and i have no idea why, it can't be because of the cables as i have test setups without them.
I also have a working RMII interface, but so far I have only been able to get it to run on a TangPrimer20K (with gowin toolchain) and even there I still have a few problems.
Are you sure about that w5500 pkts losses issue? Perhaps my silly jumper leads are less inductive/destructive than anticipated, I don't know. To me the losses are within 'functional specs' when a brutal ping beat-up is applied (see visual). Not 0% perfect ofc, but then no interfaces are perfect under that stress, to my limited knowledge mind you.
The RMII reference design is an excellent one indeed. Not easy to implement though, you have my respect.
  • Aciera
  • Aciera's Avatar
01 Aug 2024 14:47
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
How relevant is this option at the moment?
Not relevant, I was just wondering if I could run the output on a simulator.
  • meister
  • meister
01 Aug 2024 14:19
thank you, you make me embarrassed :)
At the moment a UDP2SPI bridge (esp32) is still the best solution.
In principle, you could also programme the FPGA via an esp32 (JTAG or SPI flash), but you would have to adapt the firmware first.
  • cnbbom
  • cnbbom
01 Aug 2024 14:14 - 01 Aug 2024 14:15
apt purge linuxcnc*
Reading package lists... Done
Building dependency tree... Done
Reading status information... Done
The package 'linuxcnc' is not installed, so it will not be removed
0 packages upgraded, 0 newly installed, 0 to be removed, 0 not upgraded.
  • cnbbom
  • cnbbom
01 Aug 2024 14:11
the second option worked but the first one didn't
1To install from a fresh Debian 12 with NO LCNC installed yet, just use: sudo dpkg -i (package name here without brackets) for each deb and reboot. Choose the RTAI kernel in Grub, enjoy.
2To install on Debian 12 with linuxcnc-uspace already installed use : sudo apt purge linuxcnc* and wait for apt to completely remove every trace of LCNC.
Then follow the instructions for a fresh Debian 12 install above.
  • JT
  • JT's Avatar
01 Aug 2024 13:55
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Other User Interfaces
@MennilTossFlykune do you know if it's possible to zoom to the machine extents (the red box) with a pushbutton?
Displaying 24076 - 24090 out of 25068 results.
Time to create page: 0.732 seconds
