  • my1987toyota
  • my1987toyota's Avatar
30 Jul 2024 16:14 - 30 Jul 2024 16:17
Replied by my1987toyota on topic Was the SPAM topic a test
since it is a spam topic I posted some spam videos there.
  • my1987toyota
30 Jul 2024 15:50
Replied by my1987toyota on topic Interesting Youtube Video
So when do we get A.I. to replace the execs, and such? Not that I feel that it would make life any better.
  • my1987toyota
30 Jul 2024 15:37
Replied by my1987toyota on topic Who wants to use MODBUS ? Video.
Yes, but it's for the safety and security of the (cough) people. Oh, did I say that out loud?
  • my1987toyota
30 Jul 2024 15:33 - 30 Jul 2024 16:01
and the spammers are already back.See the General LinuxCNC questions.
forum.linuxcnc.org/38-general-linuxcnc-q...ces-las-vegas#306407
  • cakeslob
  • cakeslob
30 Jul 2024 15:25
lpkkk, upload your screenshots to the forum and not that external site
  • AirRacer
  • AirRacer
30 Jul 2024 15:09
Replied by AirRacer on topic Mesa CT Huge Improvements Coming
Category: Driver Boards
I just realized that 7/16/2024 is probably the correct version date for 2.1.5 so it looks like the version number itself that’s displayed in the window title bar just wasn’t updated when 2.1.5 was created.
  • Krulli_Fräser
  • Krulli_Fräser
30 Jul 2024 14:48
Replied by Krulli_Fräser on topic Verify my Mesa selection
It shouldn't matter either way. I just want to know if this setup will work fpr my needs so I can go ahead with ordering the parts.
  • PCW
  • PCW's Avatar
30 Jul 2024 14:47
Replied by PCW on topic Verify my Mesa selection
Note that 7I84s should become available in a week or so.
  • manfrel
  • manfrel
30 Jul 2024 14:22
Replied by manfrel on topic Mesa 7i96s + DM556T -> Motors not moving
Stepper online drivers have a 24v and a 5v logic switch at the top. It needs to be 5v for the mesa
It actually was this switch. Now everything works fine.
Thank you all very much for your help!
  • ffffrf
  • ffffrf
30 Jul 2024 13:56 - 30 Jul 2024 13:57
help with millrun and/or custom Z-X-A(or C) lathe/machine
Category: Fusion 360
edit: just to share a bit of my progress: I found an old fusion support thread that suggested to use the doosan millturn fusion360 post processor and set "gotyaxis" to false everywhere. When I do that, and generate Gcode, it successfully does not include Y axis movements, however, I believe other changes are needed to align the gcode output to be compatible with linuxcnc and am struggling on where to start.I will attach this modified post processor, and attach a simple off center drilling gcode that I generated using it:
File Name: 1221copyas...rmat.txt
File Size:0 KB
File Name: doosanmill...copy.txt
File Size:169 KB
  • ffffrf
  • ffffrf
30 Jul 2024 13:32
Hello everyone, hoping someone in the community can help. I have a lathe that I modified to have the headstock be driven by a positional stepper motor, and have added a spindle on the cross slide WITHOUT a Y axis. Thus, I am looking for help getting a working processor that can generate gcode for 2d milling in this configuration, meaning I can do things like drill holes on the face of my stock off center.
What is the best way to go about doing this? Has anyone already made or used a working post processor for this? An old thread in fusion360 support said to find a post processor for millturn and remove mention of the Y axis so it only generates gcode without it - is that the right way to go about it?
Lastly, can someone verify if my kinematics are organized correctly in fusion360? My rotational/positional axis is along the Z axis and holds the stock, my spindle is on the cross slide (X axis) and points along the Z axis (attached image)
  • Grotius
  • Grotius's Avatar
30 Jul 2024 13:12 - 30 Jul 2024 14:20
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
For coleair lines and curves with curvature=0 (clothoid, spline that is in fact a line), i fused them to one piece of type line.
This seems to work better.
  • spumco
  • spumco
30 Jul 2024 13:05
Replied by spumco on topic Which Mesa Card Should I Buy?
@GeckoWorks & @PCW - Thanks for pointing out the 'alternative' MPG connection situation.  Overview post updated; if my edit is unclear, please suggest some wordsmithing.
  • Krulli_Fräser
  • Krulli_Fräser
30 Jul 2024 12:58
Alright so it turns out I can use sinking outputs since all the outputs go to a relais board and I can just give the common on the coils +5V and then switch them by sinking. That means I can use the 7i97t as my "main card" with ethernet connection to the pc and the 7i84D for I/O. The 7i73 in the control cabinet could then be connected using the adaptor talla83 shows in the video, right?
I think with that I am all set.
7i97t: connection to PC, 3 analog axis outputs, encoder feedback with linear scales, spindle output, 3 handwheel mpg inputs(uses 6 inputs), 10 inputs, 6 outputs
7i84D: 32 inputs, 16 outputs
  • RotarySMP
  • RotarySMP's Avatar
30 Jul 2024 12:28
Replied by RotarySMP on topic Verify my Mesa selection
A whole 7i96 is a lot of card, for the potential expansion of a stepgen, maybe in the future. All those FPGA cards have a 25 pin expansion slot which we mostly dont use (P1 on the 7i97).
I am pretty sure you can add a stepgen onto a couple of those pins with a bit of playing around in the MesaFlash utility. It looks like you could also use that to hook in a second SS for the 7i73.
Peter (Talla83) has done some excellent videos on how to edit the bitfile for the mesa cards, such as this one (In german, but Youttube does good tranlations subtitles.
Displaying 24271 - 24285 out of 25074 results.
Time to create page: 0.456 seconds
