  • chrischan
  • chrischan
04 Nov 2025 19:44
Replied by chrischan on topic Alle Desktopsymbole verschwunden
Category: Deutsch
Ja im Home Ordner ist alles vorhanden. Es wird nur nix angezeigt. Und auch RMB macht nix
  • rodw
  • rodw's Avatar
04 Nov 2025 19:37
Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
[b]From what I’ve read, the Product ID is defined in the driver source (like usb.h), and you’d need to rebuild it — which I can’t manage.[/b]
Anybody can build linuxcnc from source. I did a video guide. studio.youtube.com/video/Oe4Hfq3G2_A/edit
  • rodw
  • rodw's Avatar
04 Nov 2025 19:33
Replied by rodw on topic USB activity causes network error
Category: Plasmac
Once you have isolated cores, Real time applications (like Linuxcnc) will run on one of those cores. More particularly, the RT servo thread will run there. I think user space parts will run on non isolated cores where there is no need to be in time...
  • Ul
  • Ul
04 Nov 2025 19:33 - 04 Nov 2025 19:33
Replied by Ul on topic Alle Desktopsymbole verschwunden
Category: Deutsch
Gut, dann hat es immerhin kein Upgrade gemacht. Ist der Desktopordner im /home Verzeichnis zu finden?
  • unknown
  • unknown
04 Nov 2025 19:30
It's the IDs that are the issue which are hard coded into the driver. 2.9.7 won't help.
  • unknown
  • unknown
04 Nov 2025 19:28
Replied by unknown on topic Suggest RTAI version for me
Try the wheezy ISO from the downloads page, tho it will limit the version of Linuxcnc you can use. That really isn't an issue as it will work fine. Actually there's a few members that run earlier versions.
  • rodw
  • rodw's Avatar
04 Nov 2025 19:28
Replied by rodw on topic Suggest RTAI version for me
I personally think that modern Operating systems need more than 2 cores to  run  Linuxcnc these days. Give RTAI for 2.94 a go and see how you go.
I have no experience.
  • SvenRSA
  • SvenRSA
04 Nov 2025 19:28
Replied by SvenRSA on topic Maho 700C A-axis (rotating table)
Thanks I’ll be sure to check this.
  • rodw
  • rodw's Avatar
04 Nov 2025 19:26
Linuxcnc 2.9.4 was released to fix some things with with XHC USB pendants. Perhaps an upgrade will fix things. Here is how to get it on Trixie
  • Hakan
  • Hakan
04 Nov 2025 19:21
There may be more than the usb product code that differ between them.
Here is where to change github.com/LinuxCNC/linuxcnc/blob/fb1480...-whb04b-6/usb.h#L311
Then build linuxcnc and run-in-place.
  • PCW
  • PCW's Avatar
04 Nov 2025 18:54
Replied by PCW on topic Analog controller for servos
Category: Driver Boards
Mesa just shipped product to Welectron  and Eusurplus
In addition Eusurplus has 7I97Ts in stock
  • chrischan
  • chrischan
04 Nov 2025 18:53
Category: Deutsch
No LSB modules are available
Distributior ID: Debian
Codename: bookworm
  • PCW
  • PCW's Avatar
04 Nov 2025 18:52 - 04 Nov 2025 19:10
Replied by PCW on topic Maho 700C A-axis (rotating table)
2. When the clamps are release and the scale is plugged in and the NC- ready is on its almost as if the mesa card sends out a voltage causing the motor to “bump” which causes a joint error. If I unplug the scale and still leave the clamps off the machine runs fine and the table is steady doesn’t drift.
If this is a analog system and you prevent motion, Normally you would need to disable the PID
feedback when locked (especially if there is any I term)  Otherwise a large output can develop
as the PID "fights" against the apparent resistance to motion.
  • Nkbhvid
  • Nkbhvid
04 Nov 2025 18:48
Replied by Nkbhvid on topic Analog controller for servos
Pico is on my watchlist.
Unfortunately they do seem to have any dealers in EU.
  • Ul
  • Ul
04 Nov 2025 18:47
Category: Deutsch
Gib mal im Terminal ein: lsb_release -ic
Was wird ausgegeben?
Displaying 11506 - 11520 out of 12861 results.
Time to create page: 1.401 seconds
