  • JackRay
  • JackRay
17 Jun 2025 19:42
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
yes, I checked all that with 4 encoders but I never saw any change in the Z signal. I think my .hal is compliant. Could there be a connection subtlety on the 7i96s card?
  • Lcvette
  • Lcvette's Avatar
17 Jun 2025 19:33
Probe Basic Not Remembering Current Pocket Number
Category: QtPyVCP
excellent! glad you got it sorted! now you should be future proofed too for 2.10 when it is officially released as stable!
  • djones@burketruck.com
17 Jun 2025 19:14
Replied by djones@burketruck.com on topic Probe Basic Not Remembering Current Pocket Number
Category: QtPyVCP
I figured it out, I had to modify the math a bit (along with adding the stglue and RANDOM_TOOLCHANGER = 0 changes) but now it works perfectly. Not sure if it is something inherent to the Mazak index style ATC or if I had something wrong from the start when I used the sample configs as a reference to write the config for my machine. I just pushed the changes to my github attached above. I'll be sure to keep it public when I clean everything up and merge it to my main repo.
Thanks for the help!
  • Lcvette
  • Lcvette's Avatar
17 Jun 2025 18:36
Category: QtPyVCP
you can also ask on the probe basic facebook group chat, just join here, the group chat would allow realtime communication and video sharing to better help understand whats going on:
www.facebook.com/share/g/1E9TtGtPQv/
  • Todd Zuercher
  • Todd Zuercher's Avatar
17 Jun 2025 18:34
Replied by Todd Zuercher on topic Email Notification?
Email Notification?
Category: Forum Questions
I have only ever actually received 2 notification emails from the forum since I started this thread (the last one was on March 19, 2025). Maybe the problem is g-mail? But I've mostly given up. Yes the check box to be notified at the bottom of my replay is checked, and no it hasn't worked for this thread or any of the dozens of others I'm subscribed to.
  • Lcvette
  • Lcvette's Avatar
17 Jun 2025 18:29
Category: QtPyVCP
sounds like some math is going wrong somewhere. or a direction is wrong in one of your macros. without knowing more about the amchine its directions etc its hard to determine just looking over your code.
one thing i did notice is you didn't have
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool_inch.tbl
RANDOM_TOOLCHANGER = 0 <<<<<<
  • Todd Zuercher
17 Jun 2025 18:12
Replied by Todd Zuercher on topic LinuxCNC Dual-Head Gantry Setup Assistance Request
Sorry, I've been busy and hadn't checked the forum for a couple of weeks.
Are you using servos or closed loop steppers? if servos, how are they commanded? Are you using encoder feedback to Linuxcnc? What kind of tuning needs done to them yet? Is this a new machine or a retrofit of an older one? Are you sure all of the mechanics are in good order (no backlash, low compliance)
Have you decided exactly how you want to configure the machine and it's kinematics? is the Z and W heads completely independent on their own X axis so the configuration will be XYZ and UYW? Or will the configuration be more of an XYZ and XYW with merely u controlling the distance between the Z and W axis. (t is possible to have X1 and X2 be fully independant joints but still configure them such that the normally move together with the X command, but U commands control the distance.
I can try to help you as much as I can over the forum here.
17 Jun 2025 18:00
Category: QtPyVCP
I applied the stdglue change, no change. From what I can tell, the controller/Carousel module is losing count of the current pocket, mostly when running store tool in carousel. Is the logic built into the stglude to reflect the current pocket from probe basic back to the controller? Or is that something that the end user has to do when configuring it to their machine?
It looks like some people use a M68 E Q command to update motion.analog-out-00 => conv-float-s32.0.in and change the s32 count.
I just wasn't sure if the logic was already there inside of probe basic to do this and I didn't have something configured correctly, or if it is logic that has to be added.
  • Jens23
  • Jens23
17 Jun 2025 15:42
Replied by Jens23 on topic Einbindung AX5000 und EL3104
Category: Deutsch
Danke, die Dateien helfen mir schonmal etwas weiter.
Also scheinst du schon die in Linuxcnc-ethercat integrierte ethercat config zu nutzen..
Hättest du vielleicht noch die .hal, in der die Signale des 5106 zugeordnet werden greifbar? Hattest du es eigentlich geschafft den Betriebsmodus umzuschalten? Ich müsste zwischen Geschwindigkeits- und Positionsregelung umschalten, so zumindest der Plan. Ich weiß nicht so ganz, was in deiner Anlage alles drin steckt aber hört sich jedenfalls interessant an.
Ich werde es auf jeden Fall erstmal probieren, ich bastel auch gerne mal was und habe auch schonmal mit twincat gearbeitet.
Bevor ich irgendwann eine Beule am Kopf habe, weil ich die ganze Zeit gegen eine Wand renne, würde ich aber gerne auf das Angebot mit Teams zurück kommen :)
  • deedee
  • deedee
17 Jun 2025 15:23 - 17 Jun 2025 15:26
Replied by deedee on topic Einbindung AX5000 und EL3104
Category: Deutsch
Hallo Jens,
ich habe mich bis 2022 intensiv damit befasst, aber seitdem nicht mehr dran weiter gemacht und bin in den Details nicht mehr drin. Ich habe damit eine Anlage für die elektrochemische Bearbeitung (ECM) gebaut. Die Anlage läuft, dort ist aber ein rel. alter Stand von LinuxCNC aktiv.
In der Anlage sind auch rel. ungewöhnliche Beckhoff EL-Karten verbaut, welche für den Bearbeitungsprozess notwendig waren. Die Antriebe konnte ich selbst ans laufen bekommen, für die Feinheiten hat mit @db1981 hier aus dem Forum unter die Arme gegriffen. Er hat da wesentlich mehr KnowHow als ich. Was Ich Dir ggf. auch anbieten kann: Wir können mal per Teams/Remote draufsehen oder falls Du im süddeutschen Raum unterwegs bist, kannst Du auch gerne vorbei kommen.
Viele Grüße
  • Jens23
  • Jens23
17 Jun 2025 14:37
Category: Deutsch
Würdest du deine Einstellungen teilen, für den Ethercat part? Es gibt dazu echt wenige Infos. Ich habe nur herausgefunden, dass ich den 5106 wohl über twincat programmieren muss, bzw. eine XML generieren muss, die dann beim Start des Umrichters an diesen gesendet wird.
Ich bin auch über die Integration in Linuxcnc-ethercat gestolpert, wirklich eine Anleitung gibt es dazu aber nicht.
Wäre super, wenn du was von deiner Erfahrung teilen würdest. Bevor ich gefragt habe, wurde hier ja leider nur von Rückschlägen berichtet :)
  • EmilDLo
  • EmilDLo's Avatar
17 Jun 2025 14:30
Cumark Closed-Loop VFD with EtherCAT (non-CiA402) Configuration
Category: EtherCAT
Thank you very much, Hakan.
You are right to suspect it's an issue with the drive, and I am trying to get as much information as possible from the supplier. It's been a little tricky because the salesperson has to relay all the info to the VFD engineers in Chinese. The lesson for next time is to make sure the drive is CiA402 compatible.
It's hard to judge from the test results whether the 880 after start and stop makes a difference. Either way, I continue to experience inconsistent and prolonged delays.
Regarding the 6.05 section, I was trying to decode the decimal values of the control and status words used in Halrun and TwinCAT. I have now updated the PDO spreadsheet to include the decoding based on the bit tables in the manuals.
Any ideas what I should try next, if I don't have any luck with the VFD manufacturer?
  • Lcvette
  • Lcvette's Avatar
17 Jun 2025 13:41
Category: QtPyVCP
correct, here was the required change, we made a either or fix in the file. but if you are on 2,9,4, unless what ever broke things in 2.10 was also added to your specific branch version of 2.9.4 for what ever reason. either way, i would grab the latest python stdglue file and pop it in your config folder just to be safe.
  • meister
  • meister
17 Jun 2025 13:27
Replied by meister on topic Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
;P
the part is very tricky, at the moment i can't tell if it works and the ARM cores on it want extra love but i don't know how to configure them.
Ethernet won't work for now either, so if it does then only SPI and maybe later a bridge via the ARM cores.
  • unknown
  • unknown
17 Jun 2025 13:23
Replied by unknown on topic Xilinx Zynq 7010 fpga crypto windfall boards
So does that I'll have to buy one to play with the cool kids ?
Displaying 14911 - 14925 out of 15374 results.
Time to create page: 0.897 seconds
