  • PCW
  • PCW's Avatar
12 Apr 2025 01:02
Replied by PCW on topic 7i92 firmware issue
7i92 firmware issue
Category: Driver Boards
I think that message usually means some issue with the script
 I get:
peter@peter-HP-EliteDesk-800-G1-USDT:~/Downloads$ ./getmac
Old MAC Addr: 00601B168000
peter@peter-HP-EliteDesk-800-G1-USDT:~/Downloads$ ./newmac
New MAC Addr: 00601B160801
Reseting Ethernet CPU
waiting for reset
Old MAC Addr: 00601B160801
what does
./setmac
reply
it should be
peter@peter-HP-EliteDesk-800-G1-USDT:~/Downloads$ ./setmac
Interface not in Environment
  • unknown
  • unknown
12 Apr 2025 00:44 - 12 Apr 2025 00:57
Replied by unknown on topic 7i92 firmware issue
7i92 firmware issue
./newmac: line 8: ./setmac: Text file busy
waiting for reset
./newmac: line 14: ./setmac: Text file busy
Is that a worry ? Or is that due to network latency ?
Board is behind a switch and I'm working on a laptop connect via wifi, I can ping and readhmid with mesa flash ok
I used ./setmac 00123456789A in the script
Dumb me I should have sourced the file. All is good.
  • PCW
  • PCW's Avatar
12 Apr 2025 00:11
7i92 firmware issue
12 hex characters (this is from an initialization script so the
last three characters (the $1) are supplied on the command line
that is:
etc
Note that "00601B" is Mesas range
  • unknown
  • unknown
12 Apr 2025 00:02
7i92 firmware issue
Wow thanks Pete, was just thinking about how to do this. I really think I owe you a few beers.
Another question, if I may.
[/code]./setmac 00601B168$1/[code]
What's the format for the MAC ?
  • Lcvette
  • Lcvette's Avatar
11 Apr 2025 23:34
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
Post your var file
  • Hakan
  • Hakan
11 Apr 2025 23:06
Replied by Hakan on topic ETHERCAT WAIT SYNC
ETHERCAT WAIT SYNC
Category: EtherCAT
Is it the same if you just install the ready apt package with ethercat instead of building ethercat master yourself?
  • andypugh
  • andypugh's Avatar
11 Apr 2025 22:56
  • PCW
  • PCW's Avatar
11 Apr 2025 22:45
  • sin-do-re
  • sin-do-re
11 Apr 2025 22:43
EtherCAT + 7i96s for encoder input and analog output
Category: EtherCAT
Hello
I have managed to get a few motors running with etherCAT, but I still need a simple I/O system with analog out and encoder input, to use a mesa THCAD.
How is it feasible? Do I need a dual Ethernet card?
The PCs I’m using have a single Ethernet port, so to run both mesa and ethercat I will need another Ethernet system, to have different NICs, right?
thank you.
  • Grotius
  • Grotius's Avatar
11 Apr 2025 22:25 - 11 Apr 2025 22:26
Replied by Grotius on topic ETHERCAT WAIT SYNC
ETHERCAT WAIT SYNC
Category: EtherCAT
The corbett install uses systemctl to start & stop the ethercat bus.
In debian 12 & 13 i use /etc/init.d/ethercat start.
At what time is your ethercat bus started, at pc boot time?
  • Grotius
  • Grotius's Avatar
11 Apr 2025 22:12
Replied by Grotius on topic Running an external program from a HAL pin
Category: HAL
@Pcw,
Yes, that should work.
Script below works.
$ halcmd -s show pin halui.estop.is-activated
prints:
halui bit   OUT FALSE halui.estop.is-activated
Then get the FALSE or TRUE in a script:
Warning: Spoiler!
  • PCW
  • PCW's Avatar
11 Apr 2025 21:51 - 11 Apr 2025 21:58
Category: HAL
Another possibility would be a script with halcmd  in a loop,
watching the desired pin/signal  (halcmd -s show pin spindle.0.on | grep TRUE)
(this could also turn off the spindle if LinuxCNC was not running)
  • Grotius
  • Grotius's Avatar
11 Apr 2025 21:50
Connecting TURCK B20 Gateway through EtherLab EtherCat
Category: EtherCAT
Here is a example project how to read & write to ethercat-master from any device.
I called the project twincat, because it is able to get and send info to the bus system.
The  ethercat-master source is slightly updated, It can print out more info as normal.
And the source had a nasty bug related to c code configuration wich i found.
This bug is still not resolved in etherlab master. I did tell them the bug, but i did not do a push request.
I think with this project you will be able to figur out how to use the TURCK device.
The project can print all details of the TURCK device. And you can send any data you want to the TURCK device.
1 bit send . Or 8bit, 16bit, and you can add more types if you need.
  • pgf
  • pgf
11 Apr 2025 21:39 - 11 Apr 2025 21:46
Category: HAL
I run Home Assistant (open source, no cloud involved) which does a good job of managing the devices. It's not the interface to zigbee that's the issue -- it's the interface to HAL. :-)
Is the NML channel documented somewhere?   [ Edit:  Never mind, I found it.   No, I won't be going there...  ]
Displaying 16816 - 16830 out of 17635 results.
Time to create page: 0.659 seconds
