  • pgf
  • pgf
15 Jul 2026 17:54
running the spindle as a lathe spindle
I have a couple of small parts that could/should really be done on a lathe, but my efforts at getting them right on my (manual) wood lathe have been... disappointing.
I heard recently of a technique I hadn't considered, using a 3-axis CNC machine:  Mount the stock to the collet of my  router spindle.  Mount a fixed cutter to the bed, oriented parallel to the X axis.  Adjust Y so that the cutter falls on the centerline of the spindle's (and stock's) spinning axis.  X will now control depth of cut, and Z will move the stock vertically lengthwise past the cutter.
First:  Does this technique have a name?  That might help my searching.
Second:  has anyone done this?  is it a worthwhile technique?
The parts in question are reproductions of antique hand crank handles.  Since they conveniently have a 1/4" bore down the middle, securing them to my 1/4" router collet will be relatively simple.  My bed is threaded-hole style, so pretty flexible in terms of mounting the cutting tool.  Just looking for ideas, cries of dismay, incredulity, encouragement -- whatever you all have on offer today.
paul
  • vermilion
  • vermilion's Avatar
15 Jul 2026 17:50
Is possible to use RS485 to read a CMOS laser sensor?
Category: Driver Boards
The manual specifies 8-bit asynchronous MODBUS via 2-pin RS-485 (A+ and B-); so, do I need to flash the pktUART driver? That is done by updating the firmware and using terminal commands, right? Gemini AI suggested something along those lines.
  • RoberCNC
  • RoberCNC
15 Jul 2026 17:47
Replied by RoberCNC on topic Problem with PROBE tab after running a program
Category: Qtvcp
Hi Chris.
I´ve been using it for a while and this last archive works fine, everything seems to works properly, pretty good.
Thanks a lot.
  • vermilion
15 Jul 2026 17:44
Okay, the first option is using the USB adapter, but having a long USB cable is a bit inconvenient for my setup; the electronics are at the back of the machine and the PC is in front, in an external rack. Still, if there's no other way, I don't mind—though I wonder if the reaction time is slower via USB compared to RS485? This matters because it involves the sensor I want to use to measure the plasma's Z-axis. Then again, it might not really matter, since the head doesn't move while measuring the Z-distance; it just measures and calculates, then moves directly to the initial cutting height.
  • pgf
  • pgf
15 Jul 2026 17:37
Replied by pgf on topic I hate the 7i97T
I hate the 7i97T
Category: Configuration Tools
This may be obvious to everyone, but just in case: there are two different ways of specifying subnet masks. You can either spell out the mask itself, in either hex or decimal( ff.ff.ff.00 or 255.255.255.0), or you can simply specify the number of 1 bits in the mask: 24. If the mask itself is given, it should always be written as 4 dot-separated octets. If the count is given, it's usually specified with a / character, after the network itself, as in 10.10.10.0/24. (Aside: note that using the count-of-bits method, you can never specify a subnet mask that isn't a contiguous set of 1 bits. Such "non-contiguous" masks are technically legal, but are really hard to manage, so, don't do that. :-)
  • PCW
  • PCW's Avatar
15 Jul 2026 15:48
What protocol does the sensor use?
Modbus is supported by Mesa FPGA cards with the hm2-modbus/PktUART
drivers.
If your sensor does not use Modbus, fora Mesa card, it would require
a driver part like hm2-modbus communicating with the PktUART driver
  • tuxcnc
  • tuxcnc
15 Jul 2026 12:55
Replied by tuxcnc on topic Getting Trixie to play nice
I am unable to stop the screen from going blank and
In Trixie you have to disable power manager and screensaver in startup options (Main menu -> settings -> session and startup) and add the line bellow to ~/.bashrc
xset dpms 0 0 0 s off
  • rodw
  • rodw's Avatar
15 Jul 2026 11:17
Replied by rodw on topic Getting Trixie to play nice
You should be able to disable the screen saver under power settings and/or Display but it has got more difficult
In my ISO, I had to go to great lengths to force this modifying xfce config files but its not in a format to share as a script as its in the live build environment
  • rodw
  • rodw's Avatar
15 Jul 2026 11:11
Replied by rodw on topic Trixy Install problems
Thanks for all your replies.  However, I found the only way I could do the install was by downloading Debian, doing apt update, apt upgrade, and then installing LinuxCNC via Synaptic.  Worked a treat.
That might be a fairly old version of linuxCNC.What is the version  number printed on the splash screen? Or in the console if stating from the terminal?  current is 2.9.10
  • rodw
  • rodw's Avatar
15 Jul 2026 11:03
qtDragon: Auto Return to Manual Mode After an MDI Command so MPG works
Category: Qtvcp
For interest, I had a pendant I had hardwired in that had a Deadman switch that had to be held in before you could jog. I was using Gmocappy at the time and I got sick of changing modes which also changed the tab. I was able to wire this Deadman switch to halui.mode.teleop and life was happy as I never had to bother swapping modes again.
  • Todd Zuercher
  • Todd Zuercher's Avatar
15 Jul 2026 09:52
Replied by Todd Zuercher on topic Is possible to use RS485 to read a CMOS laser sensor?
I've never attempted it myself, but supposedly it should be possible.
linuxcnc.org/docs/html/drivers/mesa_modbus.html
I have always used an ordinary serial port (such as a USB to RS485 adapter dongle) to communicate with Modbus devices using the MB2Hal driver.
  • meister
  • meister
15 Jul 2026 08:50
for the verilog/fpga developer:
Verilator and SDL2 is a good combination :)
PS: also added an pin oscilloscope function:
  • aaron
  • aaron
15 Jul 2026 08:03
Replied by aaron on topic Parallel port access is not allowed
Category: Installing LinuxCNC
Thanks, everybody.  Turns out the parallel port card was a cheap one that, wouldn't work anyway.
Got a new one and everything seems okay.
Cheers
  • MaxEkb77
  • MaxEkb77's Avatar
15 Jul 2026 07:59
  • aaron
  • aaron
15 Jul 2026 07:57
Getting Trixie to play nice was created by aaron
HI
I have just updated the hardware and the software running a 4-axis router to LCNC on Trixie. However, I am unable to stop the screen from going blank and, more annoyingly, when I run a program, the machine randomly stops moving partway through the job, and I have to press the stop button on the screen, click on the last line of code it ran, and then click 'run from here'.  When this happens, the screen is still active, but I am wondering if these two issues are related.
Can anybody offer a solution?
Thanks Everybody
Displaying 1711 - 1725 out of 13507 results.
Time to create page: 0.219 seconds
