  • PCW
  • PCW's Avatar
23 Nov 2024 15:10
Replied by PCW on topic PROBLEM SETING UP LINUX CNC -111
Sounds like possibly an IP address issue
What IP address did you select in pncconf and what IP address is set on the host?
ip a
will report the host IP address's
  • gardenweazel
  • gardenweazel's Avatar
23 Nov 2024 15:08
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
Yes, correct.
Would adding a G43 to this make a difference?
RS274NGC_STARTUP_CODE = G17 G21 G40 G80 G90 G94 G54 G97 G64 P0.025 S5000
  • PCW
  • PCW's Avatar
23 Nov 2024 15:07
Replied by PCW on topic 6i24 and boot / gpu
6i24 and boot / gpu
Category: Driver Boards
I haven not seen this kind of issue but sometimes, motherboards with x4/x8/x16 slots
won't work with a X1 card. Also make sure that the 6I24 is jumpered for 33 Mhz clock
(and all jumpers match the default jumper positions in the manual page 4.
  • benjamin
  • benjamin
23 Nov 2024 15:05
PROBLEM SETING UP LINUX CNC -111 was created by benjamin
Hello !
I have a problem with setting up linux cnc i go thru pconf and when i want to run my configuration a get the next error message.
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Connection refused (-111)
./deckel.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./deckel.hal:9: /usr/bin/rtapi_app exited without becoming ready
./deckel.hal:9: insmod for hm2_eth failed, returned -1
2097
Stopping realtime threads
Unloading hal components
  • JT
  • JT's Avatar
23 Nov 2024 14:34 - 24 Nov 2024 14:30
Flex GUI Hole Ops was created by JT
Flex GUI Hole Ops
Category: Other User Interfaces
Hole operations using parameters set from the GUI in subroutines.
JT
  • JT
  • JT's Avatar
23 Nov 2024 13:48
Replied by JT on topic Flex GUI Tutorials
Flex GUI Tutorials
Tutorial 22
JT
  • martyop
  • martyop
23 Nov 2024 13:40
Replied by martyop on topic rtapi_app: caught signal 11 - dumping core
That's with sudo for sure.
01:00.0 Serial controller: Nanjing Qinheng Microelectronics Co., Ltd. CH384 Dual Port Serial and Parallel Port Adapter (rev 10) (prog-if 05 [16850])
    Subsystem: Nanjing Qinheng Microelectronics Co., Ltd. CH384 Dual Port Serial and Parallel Port Adapter
    Flags: fast devsel, IRQ 16, IOMMU group 2
    I/O ports at e000
    Memory at df308000 (32-bit, prefetchable) [size=32K]
    I/O ports at e100
    Expansion ROM at df300000 [disabled] [size=32K]
    Capabilities: [60] Power Management version 3
    Capabilities: [68] MSI: Enable- Count=1/32 Maskable+ 64bit+
    Capabilities: [80] Express Legacy Endpoint, MSI 00
    Capabilities: [100] Advanced Error Reporting
    Kernel driver in use: wchpciserial
    Kernel modules: parport_serial, wch, wch_pre
  • martyop
  • martyop
23 Nov 2024 13:38
Yes you did type sudo lspci -v, I think I did too.
I put the address in the wizard for the parallel port.
I get the same no par port registered error but with the new address 0xe000.
Maybe I should get a new pci parallel port card.
  • timo
  • timo
23 Nov 2024 13:34
  • FPM
  • FPM
23 Nov 2024 13:27
Replied by FPM on topic converting a tos/intos fngj 40
Category: Milling Machines
Pin8 of the servo driver is like written in pinout a inhibit pin. So this should be connected to the mesa enable+ pin and enable- pin to GND. The Manual i ve attached says Pin 8 can sink about 200mA but this has nothing to do with how much it draws. So the 50mA of the enable switch should be fine right?
23 Nov 2024 13:17
Replied by tommylight on topic rtapi_app: caught signal 11 - dumping core
I did type
sudo lspci -v
did i?
The port is there and working, but there is no info on capabilities as you did not use sudo.
The port address to type into the wizard is 0xe000
  • martyop
  • martyop
23 Nov 2024 13:09
Here is the relevant section of the response to lspci -v
    I/O ports at e000
    I/O ports at e100
    Capabilities: <access denied>
    Kernel driver in use: wchpciserial+
Thanks,
Marty
  • royka
  • royka
23 Nov 2024 13:00 - 23 Nov 2024 13:06
Replied by royka on topic Real-Time Kernel with Orange Pi 4 LTS
That's nice, how is the latency? It might help to isolate the last 4 cores (isolcpus=2-5)if just isolating the last core is not good enough (isolcpus=5)
For spi, open /boot/armbianEnv.txt and edit the following:
overlay_prefix=rockchip-rk3399
overlays=spi-spidev
  • Hossein74Majidi
  • Hossein74Majidi
23 Nov 2024 12:42
Replied by Hossein74Majidi on topic Real-Time Kernel with Orange Pi 4 LTS
You can try this rt kernel for the rk3399:
drive.google.com/drive/folders/12VfNmKC3...feCnnzYX?usp=sharing
For the spi rt patch I'll see if I'm able to do something. For sure it won't be as complete as the "original" patch but maybe it'll be good enough.
Have you already been able to use the spidev driver at all?
This worked and it made it real-time.
However its spi driver couldnt be enabled. I mean I've enabled it from armbina-config but in /dev/ directory, the spidev doesnt show up.
  • zmrdko
  • zmrdko's Avatar
23 Nov 2024 12:23
What would be the best 3d printer board to use with remora spi and raspberry pi 5 please? For k40 style co2 laser, so I dont need too many motors.
Displaying 21421 - 21435 out of 22562 results.
Time to create page: 0.432 seconds
