  • Derek
  • Derek
25 Dec 2024 04:37
Replied by Derek on topic Retrofitting an 89 Chiron FZ12W aka Igor
Category: Milling Machines
Which spindle oil is used? Is the chamber where the motor and spindle connect also the oil reservoir? I too have a chiron fz12w I retrofitted.
  • Lcvette
  • Lcvette's Avatar
25 Dec 2024 04:06 - 25 Dec 2024 04:08
Replied by Lcvette on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
Your missing some things from config docs still,
AXES = ?
GEOMETRY = ?
  • Lcvette
  • Lcvette's Avatar
25 Dec 2024 04:03
Category: QtPyVCP
Add geometry ini line, that determines which dro displays are shown
Yes post gui hal must include what's in the docs. Add your current items below the probe basic items.
  • aikiaviator
  • aikiaviator
25 Dec 2024 03:28
Replied by aikiaviator on topic To Probe Basic from Gmoccapy
Category: QtPyVCP
Ok. I have a feeling that this is going to be either easy, OR a long road. I have the system popping up with no errors, however, when I try and test homing I get the following:Named parameter #<geometry> not defined. I cant seem to get it to complete anything else other than jogging and coolant pump Mist and Flood activations.
  • ccatlett1984
  • ccatlett1984
25 Dec 2024 02:13
Replied by ccatlett1984 on topic Wiring VFD to MESA 7C80
You rock, thanks for the speedy reply.
  • PCW
  • PCW's Avatar
25 Dec 2024 01:57
Replied by PCW on topic Wiring VFD to MESA 7C80
TB8 PIN    SIGNAL    WIRE COLOR   VFD
1    SPINDLE-           BLUE               GND
2    SPINDLE OUT   YELLOW            A11
3    SPINDLE+         ORANGE          P12 (12V)
4    NC                     BROWN
5    SPINDLE EN-    WHITE               GND
6    SPINDLE EN+   GREEN              X1
7    SPINDLE DIR-   BLACK               GND
8    SPINDLE DIR+  RED                  X2
VFD inputs must be set for NPN mode (J1)
  • ccatlett1984
  • ccatlett1984
25 Dec 2024 01:42 - 25 Dec 2024 01:46
Wiring VFD to MESA 7C80 was created by ccatlett1984
Here is the manual for my VFD:
workerbeeit.com/H100SeriesManual.pdf
Here is the wiring I have for the SPINDLE header coming off the 7c80 (I am aware that pin 4 is not connected/used, just terminated the wire so it was not hanging loose)
TB5 PINOUT
1    SPINDLE-           BLUE
3    SPINDLE+         ORANGE
4    NC                     BROWN
5    SPINDLE EN-    WHITE
6    SPINDLE EN+   GREEN
8    SPINDLE DIR+  RED
I am not sure how to wire the enable and direction controls to the VFD
VFD PIN   DESC                                    WIRE COLOR
AO            ALG. V OUT
GND        GND ISOLATED FROM PE
X4
X5
X6/Y1_FO
P12         12V OUT 150mA
AI1          ANLG V IN
AI2          ANLG V IN
X1
X2
X3
X1-6 are multifunction pins, and can be assigned, but i'm not sure how to wire this (someone on discord mentioned wiring as "single ended"?)
It also appears that this VFD can use ModBUS, not sure if that would be a better option than analog?
The mill also has a 2-wire manual (physical) speed dial (potentiometer) that I would also like to wire up, not sure if that should be wired to the 7c80 or directly to the VFD.
  • WarcoVMC
  • WarcoVMC
25 Dec 2024 01:15
Replied by WarcoVMC on topic Arduino IO Expansion
Category: Show Your Stuff
Have you a HAL file example
I have had this woking using the show hal example in you video
  • Grotius
  • Grotius's Avatar
25 Dec 2024 01:11 - 25 Dec 2024 01:30
Replied by Grotius on topic PathPilot V2 source code
Category: PathPilot
The planner in the video does account the abc axis into the motion using endvelocity's.
However it has no abc tooldir (tooldir blend) optimalisation feature at this moment.
  • gardenweazel
  • gardenweazel's Avatar
25 Dec 2024 01:05
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
Ok, here's the latest update.
Text from the log file:
[QTvcp.QTVCP.WIDGETS.GCODE_EDITOR][ERROR]  load_text(): [Errno 2] No such file or directory: '' (gcode_editor.py:338)
[QTvcp.QTVCP.WIDGETS.DIALOGMIXIN][DEBUG]  Setting ToolChangeDialog-geometry dialog geometry from from prefs. (dialogMixin.py:127)
[QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET][ERROR]  No callback or STATUS message specified for: toolDialog_ (dialog_widget.py:317)
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12756, resource id: 9629954, major code: 40 (TranslateCoords), minor code: 0
USRMOT: ERROR: invalid command
Linear move on line 277 would exceed Z's positive limit
Linear move on line 277 would exceed joint 3's positive limit
invalid params in linear command
The images I am attaching honestly make little to no sense, rather the values in the images.
  • PCW
  • PCW's Avatar
25 Dec 2024 00:14 - 25 Dec 2024 00:21
Replied by PCW on topic Threading Index Varies With Speed
setp hm2_7i92.0.packet-read-timeout 30
I would set this to 80 ( 80% = 800 usec at a 1 ms servo
thread period), or just comment it out
If you are dropping many packets, that might
be an issue.
Loss of steps might be an issue also. This may be improved
by using the interpolated encoder position, as a 10 count
per turn encoder is going to give a very rough Z axis position
command, only smoothed by the acceleration limits.
The Z motion plots look linear so the main error seems to be a variable offset
at the start. Are multiple passes at the same speed perfectly aligned?
The start and end of motion use maximum acceleration so  possible
locations of lost steps.
  • RDA
  • RDA
24 Dec 2024 23:28
Replied by RDA on topic PathPilot V2 source code
Category: PathPilot
Or maybe you have a better way to run more than 3 axis look ahead?
I think along with the s-curve another major update would be the look ahead.
  • Grotius
  • Grotius's Avatar
24 Dec 2024 23:16
Category: PathPilot
Snowgoeroe,
For my clarity.
You want pathpilot planner running in lcnc?
  • snowgoer540
  • snowgoer540's Avatar
24 Dec 2024 22:59
Replied by snowgoer540 on topic PathPilot V2 source code
Category: PathPilot
The planner can be used in lcnc within a few hours of work.
I can do that on request.
May I formally request this, please?
The work you guys are doing does seem very nice, but I do think there is value in having >3 axis look ahead using the current TP, on the master branch of LCNC.
  • vre
  • vre
24 Dec 2024 22:57
mill 4th axis was created by vre
mill 4th axis
Hello.
I have a 3T knee mill 1000mm x axis 400mm y/z axis.
What motor reducer you suggest for a rotating axis ?
Stepper with encoder and planetary reducer is good option ?
Displaying 21481 - 21495 out of 21680 results.
Time to create page: 0.421 seconds
