07 Oct 2025 01:09 - 07 Oct 2025 01:14
Very small 4 axis mill for cutting plastic materials
Category: Show Your Stuff
Did anyone notice there is a question at the end? :)
Some random info running through my noggin :
-the rotational axis should do a full 360 degree to finish this
-the tool should remain always roughly normal to the teeth/cut plane
-i do not think this needs switchable kinematics
-pretty sure this needs TCP as the cut line is always 1mm under the material (also 1mm thick roughly)
-having a look through the included TRT configs right now ... well after i get back from the shop (nicotine level low), went to bed at 1AM got up at 2:10AM, way to much stuff going on last 3-4 days compounded by family health issues, but getting better so far.
Attached files in pts and gcode formats, compressed, the gcode has Y and Z axis values changed to reflect table orientation.
  • PCW
  • PCW's Avatar
07 Oct 2025 01:02
Replied by PCW on topic 5i25t firmware screwup
Category: Driver Boards
Do you get a blinking green light on the 7I84?
07 Oct 2025 00:50
Replied by tommylight on topic LinuxCNC Lathe Retrofit ... Where Do I begin?
Category: Turning
Were you able to replace the resolvers with encoders?
Yes.
Are they part of the motors?
No they were/are mounted on the screw shaft, not on the motors.
For resolvers, you should really try to find as much info as possible, preferably full spec sheet, and preferably push as much as humanly possible to use them, Mesa has resolver cards.
  • Cooped-Up
  • Cooped-Up
07 Oct 2025 00:47
Replied by Cooped-Up on topic 5i25t firmware screwup
I have just now added another wire going to 7i84 field power so now A and B has power. I added the line you suggested having both serial 0 and sserial 1 called out. I still am currently getting the same error that the pins on 7i84 don't exist.
07 Oct 2025 00:42
  • Cooped-Up
  • Cooped-Up
07 Oct 2025 00:37
The red light is on yes, I don't have power to a and b just one. I was thinking the jumper position tied the 2 together but I could be wrong
  • Digger011
  • Digger011
07 Oct 2025 00:35 - 07 Oct 2025 00:38
Replied by Digger011 on topic Strugling with installation
Category: Installing LinuxCNC
After running sudo apt-get install -f I've got this:
dpkg: error processing package linux-image-rt-amd64 (--configure):
dependency problems - leaving unconfigured
Processing triggers for initramfs-tools (0.142+deb12u3) ...
update-initramfs: Generating /boot/initrd.img-6.1.0-40-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
linux-image-6.1.0-40-rt-amd64
initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Then went with
sudo apt-get check
apt-cache depends
I got this:
milos@cnc:~$ apt-cache depends linux-image-rt-amd64
Depends: linux-image-6.1.0-40-rt-amd64
milos@cnc:~$ apt-cache depends linux-image-6.1.0-40-rt-amd64
Depends: kmod
Depends: linux-base
|Depends: initramfs-tools
Depends: <linux-initramfs-tool>
dracut
initramfs-tools
tiny-initramfs
Conflicts: linux-image-6.1.0-40-rt-amd64-unsigned
Breaks: fwupdate
Breaks: initramfs-tools
Breaks: wireless-regdb
Recommends: firmware-linux-free
Recommends: apparmor
Suggests: linux-doc-6.1
Suggests: debian-kernel-handbook
|Suggests: grub-pc
|Suggests: grub-efi-amd64
Suggests: extlinux
Replaces: linux-image-6.1.0-40-rt-amd64-unsigned
what should I do next? I don't understand this.:(
  • PCW
  • PCW's Avatar
07 Oct 2025 00:23
Some versions of LinuxCNC require the sserial_port_n stanza or the port is not enabled  (for ports 1,2,3)
Is the 7I84 red LED illuminated?
Do you have field power supplied to both A and B 7I84 field power sections?
  • Cooped-Up
  • Cooped-Up
07 Oct 2025 00:07
I added port 1 and it did t change anything, I also tried getting rid of the port call-out as I read in another forum post that if you don't specify then all ports are available. Neither changed the results
Displaying 13126 - 13134 out of 13134 results.
Time to create page: 0.856 seconds
