14 Apr 2026 13:52
Replied by tommylight on topic My Z-axis stopped moving
Make a new config and give it a try.
If that does not work:
-make sure the analog wires are properly making contact inside the connectors
-check if analog is correctly wired as reversing polarity of those two wires can cause most of the issues you have
  • rodw
  • rodw's Avatar
14 Apr 2026 12:39
Replied by rodw on topic Hello to all, I am new here
all you need to do is type
sudo apt-get install linuxcnc-uspace linuxcnc-uspace-dev
This will get you 2.94 which is  a couple of bug fixes behind the current 2.98 version
If you want to get to 2.98 (which is probably not a big issue  for now), follow the directions here
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
Laptops are not good candidates for linuxCNC because of all the latency inducing features in them but its worth trying. If you do need a better PC, go to 2.98 then. Install with the ISO on the downloads page
linuxcnc.org/downloads/
I have a few installation videos on my @MrRodW YouTube channel
  • erikfriesen
  • erikfriesen
14 Apr 2026 12:28
Custom widget management was created by erikfriesen
Category: Qtvcp
Is there a way to create custom widgets without directly editing /usr/lib/python3/dist-packages/qtvcp/ items?
I'd prefer to store these custom widgets in user directory to track modifications easier.  Otherwise I have to edit as root.
I've tried and failed to pinpoint where the include directory is defined.
  • rodw
  • rodw's Avatar
14 Apr 2026 12:25
Replied by rodw on topic SIEG SX3.5Z Drivers EtherCAT A6 Steppers
Category: Driver Boards
why not get a kit of closed loop steppers and use them with say a 7i97t in velocity mode. or use a 7i96s and add an encoder board later.
Then you might be able to get your scales going in position mode at your leisure and have a dual feedback system.
But I have a similar Seig SX3 and it may be overkill for what it is. A friend has an early Syil CNC machine which is based on a SX3.... open loop steppers and he does some really intricate stuff.
  • juan13372k
  • juan13372k
14 Apr 2026 11:40
Replied by juan13372k on topic SIEG SX3.5Z Drivers EtherCAT A6 Steppers
Okay i see so i dont get away with a cheap stepper driver like those from steppersonline.
I need one which has real closed loop capability. Like  leadshine el8  I mean this is a total different price class :(
I wonder if it makes sense on a cheap chines benchmill... Probably not my bad I bought the mill with the glass scales.
The leadshine el8 has this external encoder plug. This cheap chines glass scales have only VGA plug.
The question also would be if the glass scales provide the right signal via the cabel for the stepperdriver.
Has anybody have experience with that?
  • rodw
  • rodw's Avatar
14 Apr 2026 11:32
Replied by rodw on topic New Laser Build - raster engraving
Category: Plasma & Laser
Sorry about the delay. I cant upload the file because it has a sh extension. Please email me This email address is being protected from spambots. You need JavaScript enabled to view it. and I send the file.
just change it to end in .sh.txt
  • rodw
  • rodw's Avatar
14 Apr 2026 11:28
Replied by rodw on topic HAL component for tangential knife
Category: HAL
Thanks, I don't know how good a teacher I will be...
I'm almost there on my state_tag_arcs branch at github.com/rodw-au/linuxcnc
I've got all of the calculations tested and working in the interpreter. For some reason, data is getting lost on its way to motion. I will troubleshoot that in the next day or so.
Its been more complicated than I remember. I've got a better method of setting the tags but they are only updated at the beginning of a gcode segment but we want to get real time headings all the way around a G2/G3 arc. To do this, I needed to calculate the heading in real time (eg with the servo thread) in motion. No wonder no-one has tried to do this before!
  • axemas
  • axemas's Avatar
14 Apr 2026 11:27 - 21 Apr 2026 10:34
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Hello everyone,
I would like to announce the release of NativeCAM 2.0b — a community port
of the original NativeCAM (by Fernand Veilleux) migrated to Python 3 and GTK3.
The original NativeCAM was written for Python 2.7 / GTK2, which is no longer
available on modern distributions. This port makes it fully compatible with
LinuxCNC 2.9 on Debian 13 Trixie.
--- What's new in 2.0b ---
* Full Python 3 / GTK3 migration
* New: Side Drill feature — horizontal drilling from Top / Bottom / Left / Right
  faces of the workpiece, designed for multi-spindle machines like Biesse Rover
* New: Horizontal tool visualization in AXIS — tool rotates correctly in the
  3D view when a side spindle is active (uses tool table Q column: 10-13)
* Fix: Phantom GTK popup windows no longer remain on screen after LinuxCNC exits
* Fix: About dialog now shows version correctly (Python 3 bytes decode bug)
* Fix: Validation Messages menu now uses checkboxes showing current state
* Debian packaging updated for modern build tools
--- Download ---
GitHub: github.com/cnc-proton/nativecam-py3-gtk3
Releases: github.com/cnc-proton/nativecam-py3-gtk3/releases
Install:
  sudo apt install ./nativecam_2.0b-4_all.deb
--- Tested on ---
* Debian 13 Trixie + LinuxCNC 2.9
* Biesse Rover 336 (multi-spindle, 4-side horizontal drilling)
Any feedback, bug reports or pull requests are welcome on GitHub.
Credits to Fernand Veilleux (FernV) for the original NativeCAM project.
Best regards,
CNC Proton
  • grandixximo
  • grandixximo's Avatar
14 Apr 2026 11:02 - 14 Apr 2026 11:03
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
You are using DC. Confirmed.
All four slaves show "Distributed clocks: yes, 64 bit" and all four report 0x1C32:01 = 0x0002 which means DC Sync0. Your drives are running in DC synchronized mode right now. This is the best mode for a CNC machine.
The only thing that does not work for you is the alternative sync strategy where the master follows the reference slave clock instead of the other way around. But that is just a different way of keeping everyone in sync, not a better or worse one. What you have now, master as reference with refClockSyncCycles=1, is perfectly fine and is DC.
One thing I notice is that your reference clock, slave 0, is not one of the SD700 drives. It is a separate device, the first on the bus. That could be related to why syncToRefClock=true causes problems, if that device reports timing that my PLL does not handle well. If there is an opportunity to test this any time in the future within a better setting, I'd love to debug it remotely.
  • papagno-source
  • papagno-source
14 Apr 2026 10:53
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
I'm actually at the client's site performing the installation. This machine was already running Debian 10, but I wanted to test Debian Trixie and we're encountering these problems, which we seem to have solved.
The output of the ethercat slaves -v command is:
=== Master 0, Slave 0 ===
Device: Main
State: OP
Flag: +
Identity:
Vendor Id: 0x0000022b
Product code: 0x0531ec01
Revision number: 0x00000003
Serial number: 0x0001894b
DL information:
FMMU bit operation: yes
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 3151034175 0 0
1 MII up open yes 1 3151039505 5330 935
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x1000/1024, TX: 0x1400/1024
Standard RX: 0x1000/128, TX: 0x1080/128
Supported protocols: EoE, CoE, FoE
General:
Group:
Image name:
Order number:
Device name:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
=== Master 0, Slave 1 ===
Device: Main
State: OP
Flag: +
Identity:
Vendor Id: 0x00850104
Product code: 0x01030507
Revision number: 0x02040608
Serial number: 0x00000000
DL information:
FMMU bit operation: no
DC system time transmission delay: 935 ns
0 MII up open yes 0 3730859530 0 935
1 MII up open yes 2 3730862990 3460 855
2 MII down closed no - - - -
3 MII down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Supported protocols: CoE
General:
Group: ServoDrive
Image name: DRIVE
Order number: SD700_ECAT Drive
Device name: SD700_ECAT_V1.2_G
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
=== Master 0, Slave 2 ===
Device: Main
State: OP
Flag: +
Identity:
DL information:
DC system time transmission delay: 1790 ns
0 MII up open yes 1 3711076970 0 855
1 MII up open yes 3 3711078720 1750 875
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
=== Master 0, Slave 3 ===
Device: Main
State: OP
Flag: +
Identity:
DL information:
DC system time transmission delay: 2665 ns
0 MII up open yes 2 3704486570 0 875
1 MII down closed no - - - -
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
while the command:
ethercat upload -p 0 -t uint16 0x1C32 0x01 = 0x0002 2
ethercat upload -p 1 -t uint16 0x1C32 0x01 = 0x0002 2
ethercat upload -p 2 -t uint16 0x1C32 0x01 = 0x0002 2
ethercat upload -p 3 -t uint16 0x1C32 0x01 = 0x0002 2
  • rodw
  • rodw's Avatar
14 Apr 2026 10:17
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
A USB wifi adapter is also fine for a second network connection. I have often used one with an external antenna. If the PC is in your enclosure, run a SMA cable up to a bulkhead connecter and place the antenna on the outside of the enclosure. You just need to drill a hole for the connector. Something like this but check if you need male or female. www.amazon.com.au/Boobrie-Bulkhead-Exten...BRMR/ref=sr_1_4_sspa
The problem with wifi, often you need to search for  drivers and often you need to build them from source. Like my current wifi dongle. But it is bulletproof now its built. The wired NIC I use for Ethercat.
  • Dudelbert
  • Dudelbert
14 Apr 2026 09:49
My Z-axis stopped moving was created by Dudelbert
I am retrofitting a CNC lathe right now. In that process, I ran into a problem: my Z axis, which already worked, stopped doing so. I was messing with the encoder wiring, but I don’t think that is related. So X still works fine, but Z does not. I still get encoder feedback and see that when the machine is enabled, the Z axis drifts slowly.
I use a 7i97T and Chinese AASD motor drivers.
Troubleshooting I already did:
Driver: I confirmed that all the I/O still works. External E-stop, enable line from LinuxCNC, these are fine and work as expected. I then injected voltage into the analog line from the Mesa connector. The drive moves and stops after the following error gets too big, and the enable signal is removed by Mesa.
So I don’t think it is the driver or the wiring to it.
PWMgen: I then switched the pluggable connectors for X and Z on the Mesa and changed the HAL accordingly. Still, the X axis works fine and Z does not. In HAL Show I watched .pwmgen.nn.value, which started to grow after the machine was enabled and the Z axis started drifting. After a few seconds, it reached 60, which is the value of output-scale. With that, I would expect 10 V on that line, but I measure barely a few mV.
That really seemed like a hardware defect to me, but as I said, I switched the outputs between X and Z, and the PWMgens are confirmed to both be OK.
So in my head, only the software (e.g. HAL and INI) is left, but I did not really change anything there, at least I cannot think of anything.
With that, I am at the end of what I can think of. Please, if anyone has an idea, I am going insane trying to find this. I swear, if it is the equivalent of a missing semicolon in C…
I have the current .hal and .ini in the attachments.
At the end, I want to describe what I was doing immediately before this problem appeared. I cannot think of a reason how this would be connected, but still:
I had both axes moving and mostly tuned. I was testing the repeatability of the hall switches I use for homing. I found these to not be reliable and wanted to use the index pulses from the motor encoders. But I have linear scales on the machine, so I wired only the index pulses from the motor drivers to the Mesa inputs, while the A and B lines from the linear scales go directly to the bed and cross slide.
I changed only HOME_USE_INDEX = NO to HOME_USE_INDEX = YES and started the machine, at least that is what I remember. Since then, the INI and HAL have changed slightly as I tried to solve this. The HOME_SEQUENCE has changed as I wanted to check if the index thing worked for the X axis at least. It does.
So yes, I would be thankful for any help you can provide.
  • Pudding1960
  • Pudding1960
14 Apr 2026 09:49
Replied by Pudding1960 on topic Probleme mit G Code...
In this case i have Home switches on all axis,660x500 cm Travel on X,Y ,but i need only 40mm with a 2mm Endmill.... With a 3,175mm Endmill the Contour works fine,but the Finishing with the 2mm Endmill didnt !
  • raggielyle1@gmail.com
14 Apr 2026 09:38
Replied by raggielyle1@gmail.com on topic New Laser Build - raster engraving
  • grandixximo
14 Apr 2026 09:14
Category: EtherCAT
Yes, you are using DC. Both of your working configurations are DC.
syncToRefClock does not mean "DC on or off". It only controls who is the time reference that everyone else follows. Both modes use Distributed Clocks.
refClockSyncCycles=1 means the master pushes its time to the slaves every cycle. The slaves follow the master. This is DC.
refClockSyncCycles=-1 (without syncToRefClock) means the master adjusts its own cycle to follow the first DC slave. The master follows the slave. This is also DC.
refClockSyncCycles=-1 with syncToRefClock="false" flips the sign, making it effectively +1. So it is the same as refClockSyncCycles=1. Master pushes time to slaves.
Both your working configs resolve to the same thing: master as reference, sync every cycle.
What does not work for you is the mode where master follows the slave (syncToRefClock="true" or negative refClockSyncCycles alone). That is what I want to investigate, whether it is a problem with what your first slave reports or something else in my code.
To confirm DC is active on your slaves, run these commands:
ethercat slaves -v
This will show "Distributed clocks: yes" or "no" for each slave. If it says yes, the hardware supports DC.
Then to check what sync mode is actually active:
This reads the sync mode from the first slave. Value 0 means free run, 1 means SM-synchronous, 2 means DC Sync0, 3 means DC Sync1. You want to see 2 or 3. Replace -p 0 with -p 1, -p 2 etc for each drive.
Please post the output here, or if possible email me at luca at aitalmac.com about remote access. A USB to Ethernet adapter would give the machine internet while keeping the EtherCAT port dedicated.
Displaying 3586 - 3600 out of 13607 results.
Time to create page: 3.605 seconds
