No linuxcnc widgets in designer
- JohnnyCNC
- Thank you received: 115
10 Dec 2020 01:22 #191544
by JohnnyCNC
Here you go.
Replied by JohnnyCNC on topic No linuxcnc widgets in designer
Maybe someone with a working system can run qtdiag and compare the output to this? Thanks.
Here you go.
Qt 5.9.5 (x86_64-little_endian-lp64 shared (dynamic) release build; by GCC 7.4.0) on "xcb"
OS: Linux Mint 19.3 [linux version 4.19.106-rt46-lcnc]
Architecture: x86_64; features: SSE2 SSE3 SSSE3 SSE4.1 SSE4.2
Environment:
QT_ACCESSIBILITY="1"
QT_QPA_PLATFORMTHEME="qt5ct"
Features: QT_NO_EXCEPTIONS
Library info:
PrefixPath: /usr
DocumentationPath: /usr/share/qt5/doc
HeadersPath: /usr/include/x86_64-linux-gnu/qt5
LibrariesPath: /usr/lib/x86_64-linux-gnu
LibraryExecutablesPath: /usr/lib/x86_64-linux-gnu/qt5/libexec
BinariesPath: /usr/lib/qt5/bin
PluginsPath: /usr/lib/x86_64-linux-gnu/qt5/plugins
ImportsPath: /usr/lib/x86_64-linux-gnu/qt5/imports
Qml2ImportsPath: /usr/lib/x86_64-linux-gnu/qt5/qml
ArchDataPath: /usr/lib/x86_64-linux-gnu/qt5
DataPath: /usr/share/qt5
TranslationsPath: /usr/share/qt5/translations
ExamplesPath: /usr/lib/x86_64-linux-gnu/qt5/examples
TestsPath: /usr/tests
SettingsPath: /etc/xdg
Standard paths [*...* denote writable entry]:
DesktopLocation: "Desktop" */home/john/Desktop*
DocumentsLocation: "Documents" */home/john/Documents*
FontsLocation: "Fonts" */home/john/.local/share/fonts* /home/john/.fonts
ApplicationsLocation: "Applications" */home/john/.local/share/applications* /usr/share/xfce4/applications /home/john/.local/share/flatpak/exports/share/applications /var/lib/flatpak/exports/share/applications /usr/local/share/applications /usr/share/applications
MusicLocation: "Music" */home/john/Music*
MoviesLocation: "Movies" */home/john/Videos*
PicturesLocation: "Pictures" */home/john/Pictures*
TempLocation: "Temporary Directory" */tmp*
HomeLocation: "Home" */home/john*
AppLocalDataLocation: "Application Data" */home/john/.local/share/QtProject/qtdiag* /usr/share/xfce4/QtProject/qtdiag /home/john/.local/share/flatpak/exports/share/QtProject/qtdiag /var/lib/flatpak/exports/share/QtProject/qtdiag /usr/local/share/QtProject/qtdiag /usr/share/QtProject/qtdiag
CacheLocation: "Cache" */home/john/.cache/QtProject/qtdiag*
GenericDataLocation: "Shared Data" */home/john/.local/share* /usr/share/xfce4 /home/john/.local/share/flatpak/exports/share /var/lib/flatpak/exports/share /usr/local/share /usr/share
RuntimeLocation: "Runtime" */run/user/1000*
ConfigLocation: "Configuration" */home/john/.config* /etc/xdg/xdg-xfce /etc/xdg /etc/xdg
DownloadLocation: "Download" */home/john/Downloads*
GenericCacheLocation: "Shared Cache" */home/john/.cache*
GenericConfigLocation: "Shared Configuration" */home/john/.config* /etc/xdg/xdg-xfce /etc/xdg /etc/xdg
AppDataLocation: "Application Data" */home/john/.local/share/QtProject/qtdiag* /usr/share/xfce4/QtProject/qtdiag /home/john/.local/share/flatpak/exports/share/QtProject/qtdiag /var/lib/flatpak/exports/share/QtProject/qtdiag /usr/local/share/QtProject/qtdiag /usr/share/QtProject/qtdiag
AppConfigLocation: "Application Configuration" */home/john/.config/QtProject/qtdiag* /etc/xdg/xdg-xfce/QtProject/qtdiag /etc/xdg/QtProject/qtdiag /etc/xdg/QtProject/qtdiag
File selectors (increasing order of precedence):
en_US unix linux linuxmint
Network:
Using "OpenSSL 1.1.1 11 Sep 2018", version: 0x1010100f
Platform capabilities: ThreadedPixmaps OpenGL WindowMasks MultipleWindows ForeignWindows NonFullScreenWindows NativeWidgets WindowManagement SyncState RasterGLSurface SwitchableWidgetComposition
Style hints:
mouseDoubleClickInterval: 400
mousePressAndHoldInterval: 800
startDragDistance: 10
startDragTime: 500
startDragVelocity: 0
keyboardInputInterval: 400
keyboardAutoRepeatRate: 30
cursorFlashTime: 1000
showIsFullScreen: 0
showIsMaximized: 0
passwordMaskDelay: 0
passwordMaskCharacter: U+25CF
fontSmoothingGamma: 1.7
useRtlExtensions: 0
setFocusOnTouchRelease: 0
tabFocusBehavior: Qt::TabFocusBehavior(TabFocusAllControls)
singleClickActivation: 0
Additional style hints (QPlatformIntegration):
ReplayMousePressOutsidePopup: 0
Theme:
Platforms requested : gtk3,gnome,generic
available : gtk2,gtk3,qt5ct
Styles requested : qt5ct-style
available : bb10dark,bb10bright,cleanlooks,gtk2,cde,motif,plastique,qt5ct-style,Windows,Fusion
Icon theme : Mint-Y, from /var/lib/flatpak/exports/share/icons,/usr/share/icons
System font : "Ubuntu" 10
Fonts:
General font : "Ubuntu" 10
Fixed font : "Monospace" 10
Title font : "Ubuntu" 10
Smallest font: "Ubuntu" 10
Palette:
WindowText: #ff000000
Button: #ffa0a0a4
Light: #fff0f0f6
Midlight: #ffc8c8cd
Dark: #ff505052
Mid: #ff6b6b6d
Text: #ff000000
BrightText: #ffffffff
ButtonText: #ff000000
Base: #ffffffff
Window: #ffa0a0a4
Shadow: #ff000000
Highlight: #ff000080
HighlightedText: #ffffffff
Link: #ff0000ff
LinkVisited: #ffff00ff
AlternateBase: #ffcfcfd1
NoRole: #ff000000
ToolTipBase: #ffffffdc
ToolTipText: #ff000000
Screens: 1, High DPI scaling: inactive
# 0 "HDMI-2" Depth: 24 Primary: yes
Manufacturer:
Model:
Serial number:
Geometry: 1920x1080+0+0 Available: 1920x1047+0+0
Physical size: 509x286 mm Refresh: 60 Hz Power state: 0
Physical DPI: 95.8114,95.9161 Logical DPI: 96,96.2526 Subpixel_None
DevicePixelRatio: 1 Pixel density: 1
Primary orientation: 2 Orientation: 2 Native orientation: 0 OrientationUpdateMask: 0
LibGL Vendor: Intel Open Source Technology Center
Renderer: Mesa DRI Intel(R) UHD Graphics 600 (GLK 2)
Version: 3.0 Mesa 20.0.8
Shading language: 1.30
Format: Version: 3.0 Profile: 0 Swap behavior: 0 Buffer size (RGB): 8,8,8
- DemonClaW
- Thank you received: 7
16 Dec 2025 17:45 #340206
by DemonClaW
Replied by DemonClaW on topic No linuxcnc widgets in designer
Does someone have this trouble up to date? Have tryed all of it but nothing worked
- Thank you received: 2178
17 Dec 2025 13:58 #340240
Replied by cmorley on topic No linuxcnc widgets in designer
What version of linuxcnc are you using?
Is it an installed version or a run in place version?
What specifically have you tried?
If you run qtdrasigner from a terminal, what does it print?
The following user(s) said Thank You: DemonClaW
- DemonClaW
17 Dec 2025 14:55 #340243
by DemonClaW
I have the installed version of linuxcnc on the 2.9.7 version, ive tryed to follow the orders of previes posts but they are to old and much of the links dont work anymore, if i run it from terminal the only output i get is that the plugins for LED, Buttons etc. is missing
18 Dec 2025 02:18 #340263
how about these instructions?
github.com/LinuxCNC/linuxcnc/blob/2.9/li.../designer/README.txt
Time to create page: 0.169 seconds
