No linuxcnc widgets in designer
29 Aug 2020 23:13 #180016 by lllars
No linuxcnc widgets in designer was created by lllars
This is on a clean install of Mint 19.3 Mate edition
LinuxCNC is the version 2.9 from this repository:
sudo apt-add-repository 'deb http://buildbot.linuxcnc.org/ stretch master-rtpreempt'
I followed the qtvcp installation instructions from here:
www.linuxcnc.org/docs/devel/html/gui/qtv...ude_linuxcnc_widgets
$ ls -l /usr/lib/x86_64-linux-gnu/qt5/plugins/designer
-rw-r--r-- 1 root root 31592 Aug 29 22:20 libpyqt5_py2.so
-rw-r--r-- 1 root root 31488 Apr 23  2018 libpyqt5.so
-rw-r--r-- 1 root root 18808 Apr 14  2018 libqquickwidget.so
-rw-r--r-- 1 root root 18752 Apr 14  2018 libqwebview.so
drwxr-xr-x 2 root root  4096 Aug 29 22:12 python
$ ls -l /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/
lrwxrwxrwx 1 root root 62 Aug 29 22:12 qtvcp_plugin.py -> /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py
I've also tried putting the link to qtvcp_plugin.py in ~/.designer/python/ --> no difference
Launching designer with:
$ designer -qt=5
It runs fine, just no linuxcnc widgets. Help-->About Plugins lists:
Loaded Plugins
    libpyqt5.so
    libpyqt5_py2.so
    libquickwidget.so
        QQuickWidget
    libqwebview.so
        QWebView
I tried moving libpyqt5.so elsewhere, and then it doesn't show up in about plugins, but with no other difference.
29 Aug 2020 23:18 #180017 by cmorley
Replied by cmorley on topic No linuxcnc widgets in designer
yes remove libpyqt5.so.
Then launch designer from a terminal and post anything printed in the terminal please.
29 Aug 2020 23:34 #180018 by lllars
Replied by lllars on topic No linuxcnc widgets in designer
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
libpng warning: iCCP: known incorrect sRGB profile
qt5ct: D-Bus system tray: no
29 Aug 2020 23:47 #180019 by cmorley
try adding this file to the plugin folder and launching the designer again to see if it prints to the screen.
29 Aug 2020 23:50 #180020 by cmorley
sorry I meant add it to:
29 Aug 2020 23:56 #180021 by lllars
I don't see any output. It should print in the terminal?
30 Aug 2020 00:04 #180022 by cmorley
yes.
so to summarize - you see libpyqt5_py2 in designer's about plugins and it doesn't print the message from the file we just added to:
30 Aug 2020 00:04 #180023 by lllars
yes, that is correct
30 Aug 2020 00:06 #180024 by lllars
I also tried putting it in ~/.designer/python/ --> same non-result
30 Aug 2020 00:31 #180025 by cmorley
Did you check the version of qt in designer and pick the same version of libpyqt5.so?
I'm running out of ideas :(
Time to create page: 0.338 seconds
