  • LucaGiorcelli
  • LucaGiorcelli
10 Mar 2026 21:31
Machine choice for composite panel CNC + probe-driven XY/Z G-code compensation
Category: Milling Machines
Hi all,
I'm planning a gantry router build for machining composite panels into cabinet components. Looking for advice on machine choice and stack.
Material
- Sandwich panels: 1mm aluminium skins on both faces, polyurethane foam core
- Total thickness: ~60mm nominal, but varies ±1mm across a batch
- Panel size: up to 1500x3000mm
Parts and operations
- Cutting outlines
- Pockets and step joints on panel face
- V-scoring the aluminium skin to create precise fold lines (score-and-fold)
These operations require multiple tools in a single job (end mills for pockets and joints, V-bit for scoring), so automatic tool change (ATC) is a hard requirement.
The step joints are the critical operation: they create mechanical overlap between mating panels so cabinets assemble with tight joints. A 1mm thickness variation in the stock translates directly into a gap.
Workflow
probing → generate Z map → process map (Python) → adjust G-code geometry (XY and Z) → send corrected G-code → machining
- Fusion 360 CAM produces nominal G-code
- Before cutting, I probe a grid of Z points across the panel surface
- A Python script reads the probe map and rewrites the G-code: step depths and joint profiles are adjusted to the actual measured local thickness — for both the panel being cut and its mating counterpart
- This is not just Z surface compensation: XY profiles are modified based on the probe map so that mating joints match regardless of thickness variation
Why LinuxCNC
- Workflow already tested with LinuxCNC + MESA cards (7i96/7i77) on an entry level router.
- Plan to use the Python socket interface for probe data collection and G-code rewriting — tight integration between probing and post-processing is central to the workflow
My questions
1. Are there manufacturers selling new gantry routers with these specs who ship with LinuxCNC, or sell mechanics separately from the controller?
   - Working envelope: ~1600x3200mm
   - HF spindle: 18k+ RPM
   - Integrated vacuum table with independently switchable zones
   - ATC (tool magazine or rack)
   - Probe input
2. For a retrofit path: which used industrial gantry platforms have the best LinuxCNC community experience?
   - Main concerns: ATC integration and vacuum zone management via MESA I/O
3. Any experience with probe-map-driven G-code modification beyond simple Z surface mapping?
   - Currently planning G38.x + Python
   - Is there a better pattern for this use case?
  • rszemeti
  • rszemeti
10 Mar 2026 21:21
Base threadwith Mesa? was created by rszemeti
Phew, its taken a few years, but my irrecoverable account has finally been deleted and I have been able to re-register under my usual username,hoorah! :)
While trying to troublshoot a CNC router that has been running just fine for years and suddenly can't find its 5i25 card ... it occurred to me ... does a Mesa based install even need a base thread?  Surely just a servo thread is all thats needed?
Can I comment out the BASE_THREAD in [EMCMOT], remove the thread start in HAL and move any HAL things that were on the base thread to the servo thread?
I w
  • djdelorie
  • djdelorie
10 Mar 2026 20:53
Replied by djdelorie on topic Configuring and Homing dual Y Axes
Category: PnCConf Wizard
In your INI file look for a KINEMATICS entry. Change XYZ to XYYZ to tell it you have two Y joints. Further down you end up with [AXIS_Y] but [JOINT_1] and [JOINT_2]. PNCCONF should have set this up for you.
The other important thing is that the two Y motors can't share a homing sensor input. You can share X and Y1 or Y2 and Z but not Y1 and Y2.
You may also need to reverse the rotation of one of the Y motors. How you do this depends on your hardware, of course.
  • scsmith1451
  • scsmith1451's Avatar
10 Mar 2026 20:25
Configuring and Homing dual Y Axes was created by scsmith1451
1. Over the winter I modified my DYI Router Mill adding a tandem Y axis and rebuilding my Z axis support with a 2-DF gimbal  to true the spindle to the table. Today, I attempted to home the machine however, when the Y axes homed, one triggered before the other causing LCNC to complain about not being able to home one axis while the other is moving off the the home position.
What the the best way to resolve this issue such that both axes travel together, both for homing and moving off the home switch.
2. Using PNCCONF for configuring LCNC with tandem Y axes, when testing the Y axis only one of the steppers responds. Is there something that I missed in PNCCONF that will allow both Y steppers to be tested together?
3. What is the .ini PARAMETER that tells LCNC that two axes are in tandem?
Kind Regards,
  • andrax
  • andrax's Avatar
10 Mar 2026 20:10
400V Servo (51 Nm) mit EtherCAT / CiA402 in LinuxCNC – bezahlbarer Drive gesucht
Category: Deutsch
Stell doch mal ein Bild ein.
Stuttgart ist arschweit weg.
Sitze in sachsen
  • depronman
  • depronman
10 Mar 2026 19:29
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
So whilst trying to install you effectively had no internet connection
Same result that myself and friend of mine experienced
  • depronman
  • depronman
10 Mar 2026 19:27
No problem at all I was just a little unsure who Tommy was replying too
I think the grub problem that you are seeing is down to lack of internet
Both myself and friend of mine who knows linux FAR better than I do experienced the same issue with the 2.9.8 iso when trying to install with no internet present
  • Finngineering
  • Finngineering
10 Mar 2026 19:03
I installed LinuxCNC 2.9.8 on a virtual machine a few weeks back. It also failed during the grub installation phase. I'm 99% that at least in my case, something with the automatic network configuration did not work properly, and this caused the grub installation to fail. If I recall correctly, the DNS server was incorrectly set, and I had to manually edit /etc/resolv.conf to put the correct DNS server first.
  • Xnke
  • Xnke
10 Mar 2026 18:46 - 10 Mar 2026 18:48
Boots and works perfectly in live mode. The same system loads and runs Windows XP with zero faults, and will boot and run an old Mandrake linux installer USB with no errors. (OLD! Like kernel 2.2!) Of course, the NIC doesn't work with Mandrake, but everything installs. It won't boot after because of the lack of UEFI support, but it does install.
Depronman, the reason I jumped in on this thread with you is that I think I might also be having a network installation error. I am wondering if it's relying on having internet access to download any missing packages that it needs, and that it's missing a few critical packages if it can't get internet access.
  • liutas4x4
  • liutas4x4
10 Mar 2026 18:44 - 10 Mar 2026 19:05
some qs about Axis tuning was created by liutas4x4
hi,
- is it possible to increase size of buttons for axis control at Axis?
- is it possible to have control of secondary spindles at Axis?
may be I need rewrite something? what? where? how?
/eugenius
  • depronman
  • depronman
10 Mar 2026 16:57
I’m not sure who you are replying too, but on my original post about failing the install at grub install, yes I could load the live version without any errors
It was only on any of the install option that it’s failed at grub unless it had access to the internet either wired or Wi-Fi
  • masawee
  • masawee
10 Mar 2026 15:57 - 10 Mar 2026 15:59
Replied by masawee on topic LinuxCNC with Raspberry pi 4
have anybody make rpi4 working linuxcnc, what need doing gpio pins config, this hal,demo and html not help anything what need doing, not understand what must make, ewer not has written and understand code, only test run "blink" code and working.
just buy rpi4 and encoder wheel, buttons, rotate switch, shift level converter 3,3V to 5V and stepper motor drivers DM556 and nema 23 470 OZ/ 3 Nm motors, and install rpi4 linuxcnc image to card and run image, ok, but were is config wisard gpio pins ?
config wisard has only paraller port pin config.
pnc config has only ower expensive mesa card config.
how config all pins to rpi4 gpio ???? has anybody make this and can tell step by step or send config files what need rpi4 working whit this linuxcnc rpi image.
image boot and run ok, step conf wisard no help how gpio pins setting.
  • masawee
  • masawee
10 Mar 2026 15:22
Replied by masawee on topic LinuxCNC at RPI4 with using IO Pins only ?
arduino shield can use only toy motors, less than 2A motors can use, not have cnc machine motors too small, normal cnc used nema 23 470 OZ 3Nm motor 3-6Ampere current minimum cnc motors. and not need BOB card use big stepper motor drivers etc, DM556 drivers,
  • masawee
  • masawee
10 Mar 2026 15:18
not is problem rpi use 3,3V and then use shift level converter module, cost 1-4 $ about and convert this gpio 3,3V to 5V out, then this 5V can connect wire to stepper motor drivers ETC, DM556.
Displaying 5161 - 5175 out of 13548 results.
Time to create page: 0.292 seconds
