  • turbohoolik
  • turbohoolik
15 Feb 2026 15:35
Replied by turbohoolik on topic Soft limits are not working all the time...
Category: Basic Configuration
Found my problem, the problem was me!
My soft limits were further away than hard limit switches. Why I was set it up like this, I have no idea...
Thank everybody for thinking with me!
  • PCW
  • PCW's Avatar
15 Feb 2026 15:15
Integrating a BCL-AMP capacitive sensor to LinuxCNC
Category: Plasma & Laser
If you do not, you will have a huge offset that would have to be compensated
by using a similar setpoint. If you use the 22900 offset, you will now have
a 0 to 1000 active range ( if scale = 1)
15 Feb 2026 14:44
Replied by tommylight on topic socket raw Eth.
socket raw Eth.
That was me, i did check and it was the same post, and at the time the post here was not deleted.
Sorry for the inconvenience.
  • Marcos DC
  • Marcos DC's Avatar
15 Feb 2026 14:12
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
Good point about the homing bits being mode-specific / poorly documented. I initially mentioned bit12 as an example, assuming we’re aiming for a generic solution, but that’s clearly not something we can rely on.
I think the right approach is to keep the core logic generic (state machine + timeouts + progress watchdog), and make the actual homing status (done/active/error) configurable per drive, e.g. via masks on 0x6041.
While internal homing runs, keeping pos_cmd slaved to pos_fb still seems necessary to avoid the jump when control is handed back.
With that, A6 becomes just one mapping, not a special case baked into the algorithm.
  • MRx
  • MRx
15 Feb 2026 13:38
Replied by MRx on topic XHC WHB04B development?
Disconnects might be caused by multiple reasons.
a) poor xhci support for that system - try to connect the pendant to a USB 2.0 port
b) check if USB autosuspend is disabled (as root)
cat >/sys/module/usbcore/parameters/autosuspend
echo -1 >/sys/module/usbcore/parameters/autosuspend
c) if connected to a USB hub - don't do that, connect it directly
d) EMI issues, check if there's a pattern that can trigger this, check if a relay is able to disconnect it somehow; I had HDMI displays resetting due to issues with relays a decade ago (eg. missing flyback diodes)
I worked on the XHC pendant some years ago to fix some issues, I never had disconnect issues with it.
  • Aciera
  • Aciera's Avatar
15 Feb 2026 13:30
Replied by Aciera on topic socket raw Eth.
socket raw Eth.
The issue was that you have posted the same question in two different topics. That is called 'Double posting' and is against forum rules and why I removed the post here.
Unfortunately somebody else seems to have worked on removing the other topic at the same time.
  • Mr. Mass
  • Mr. Mass's Avatar
15 Feb 2026 13:02
Replied by Mr. Mass on topic Control panel
Control panel
Category: Show Your Stuff
Thank you. This is an industrial keyboard from SYNTEK, model SK4-MB. It is made on a single board, but electrically there are two keyboards. The upper part with letters and numbers is a standard PS/2 (I had to figure out how to remap it). The lower part is a matrix keyboard combined with LEDs. Connecting and configuring it was the most time-consuming part of the job.
  • Looby
  • Looby
15 Feb 2026 13:00
Replied by Looby on topic Electrical Contactors/Relay Help?
Category: Milling Machines
I feel like Im taking crazy pills... I swear Ive read that 2 dozen times in the past few days.  I THINK whats happened is I have been making an assumption on some things that I shouldnt have.  I have seen that inrush current on inductive loads can be 5-10x the constant running amps and assumed that I needed to have a contactor that was rated for THAT amount.  WOW I feel like a huge mental burden has been lifted as I have been stressing over this for a week.  Ive bought all the stuff for this CNC project and then hit this and was worried my plan wasnt possible and I had wasted a bunch of time and money.
About a quarter the way down this states
"As a result, the motor attempts to draw the locked-rotor current (LRA), which is typically 6 to 8 times greater than the full-load current. If this high inrush current is not quickly reduced, the motor windings will overheat and may eventually burn out."
www.electricaltechnology.org/2025/06/siz...ctor-controller.html
Under the AC3
"The most common category, AC3, governs contactors for squirrel-cage induction motors, which constitute 70% of industrial motor applications812. These motors exhibit high inrush currents (5–7× rated current) during startup but stabilize during running."
viox.com/electrical-standards-for-contac...lization-categories/
The below are just amazon listings and are specific to solid state relays
At the bottom of the page under the wiring diagram this relay states
"How to choose correctly:
STEP 1: Choose a correct type Current of Equipment/Ratio = Current of SSR PS: The Ratio depend on the kind of your loading equipment. Resistive load :70%, Inductive load:20%,Capacitive load:10%."
www.amazon.com/CGELE-SSR-80DD-3-32VDC-5-...astic/dp/B09HRX922Z/
This one states the
"Step 2: Choose the Correct Current
For resistive loads:SSR current = 2 x operating current of the load (heating equipment, etc.)
For inductive loads:SSR current = 6 x operating current of the load (motor, etc.)
For capacitive loads:SSR current = 10 X the operating current of the load (capacitance, etc.)"
www.amazon.com/LCLCTC-Solid-Output-24-48...iator/dp/B0BVFP7YB2/
  • Hakan
  • Hakan
15 Feb 2026 12:49 - 15 Feb 2026 13:00
Replied by Hakan on topic Ethercat beckho el2819 conf
Category: EtherCAT
The output of the command "lcec_configgen" should give you something you can use.
Cut out the part for the el2819. Adapt the names of the device and pins as needed.
Two examples for naming of bit outputs
forum.linuxcnc.org/ethercat/58248-kinko-ect-coupler#341688
  • GDTH
  • GDTH's Avatar
15 Feb 2026 11:07
Ethercat beckho el2819 conf was created by GDTH
Category: EtherCAT
Hi,I'm using LinuxCNC with the linuxcnc-ethercat driver and noticed that the EL2819 is not supported out of the box.The slave is detected by the EtherCAT master, but it isn’t mapped correctly in linuxcnc-ethercat.Since the EL2819 is a 16-channel digital output (similar to other EL28xx modules), is there an existing definition I can use, or do I need to manually add support (e.g. by copying a similar module and adjusting the PDO mapping)?Thanks for any guidance.
  • BIBIGUL
  • BIBIGUL
15 Feb 2026 11:06
Replied by BIBIGUL on topic socket raw Eth.
socket raw Eth.
If I have violated something, then the moderators must somehow notify about the violation. Maybe I'm asking something wrong, revealing some secrets? I don't blame you for deleting the topic......... Okay, we drove.
  • rodw
  • rodw's Avatar
15 Feb 2026 10:35
Category: EtherCAT
I always worried about joint axis homing but I think now it can be done in the drive with homing offset 0x607c which is really the same as our HOME_OFFSET. This probably would need to include  an indrive position adjustment for the last joint that makes it home to square the gantry. I need to think through the application of this as its just at the idea stage now.
I really appreciate the input here about the state machine. Homing sounds simple until you go to do it!
I think the homing bits I mention are often described as mode specific or some such garbage, but it is part of the cia402 homing standard that is not well desribed by many manufacturers.
  • Hakan
  • Hakan
15 Feb 2026 10:18 - 15 Feb 2026 10:27
Replied by Hakan on topic XHC WHB04B development?
Had event logging on today. It failed again (loop =10).
libusb_submit_transfer failed with LIBUSB_ERROR_NO_ DEVICE (-4)
github.com/tenderlove/libusb/blob/763471...libusb/libusb.h#L750
github.com/tenderlove/libusb/blob/763471...13/libusb/io.c#L1288
Syslog is absolutely full of usb disconnects of the xhc device. Every 16-17 second the device disconnects and reconnects.
Must be the xhc component that does this? It only happens when linuxcnc is running.
If I look in github.com/tenderlove/libusb/blob/master...usb/os/linux_usbfs.c and search for LIBUSB_ERROR_NO_DEVICE,
they are there.
Why are all the disconnects/reconnects there? Wouldn't surprise me if that can cause something.
  • Aciera
  • Aciera's Avatar
15 Feb 2026 10:08
socket raw Eth.
I did not remove the new topic, must have been some overlapping moderator work there.
Restored the post here.
  • andrax
  • andrax's Avatar
15 Feb 2026 09:45
Category: EtherCAT
So, I see two ways to monitor the reference run.
I can only describe it using SCL Logic.
If I have understood the documentation correctly...
in principle as follows:
case homing_status of
0:
     0x6098 := (-2 to 35);
     0x6099-01 := 13981013 or default from .ini;
     0x9099-02 := 1398101 or default from .ini;
     0x609A := 131072 or default from .ini,
     0x6040 > Bit 4 :=1; // start homing with rising edge
     homing_status :=  10:  // next step
10: // 1st safety monitoring 0x6041>Bit 9=1 Homing started
      // 0x6041>Bit9=0 start timer
     IF  (0x6041>Bit9=0) THEN
           TON(IN := TRUE, PT:= T#1s); // example 1 second
           Error_Bool:= TON.Q; // time expired error is set
    ELSE
          TON(IN:=FALSE) //timer break
          homing_status:= 20
          END_IF
20: // 2nd safety monitoring Speed comparison
     IF target speed <> current speed THEN
            Error_Bool:= TON.Q; // Time expired error is set
     ELSE
           TON(IN:=FALSE) //Timer break
           homing_status:= 30
     END_IF
30://wait for homing to finish
IF (0x6041>Bit15=1) THEN
     //prevents the axes from jumping and gives linuxcnc the opportunity for synchronization
    set halui.axis.n.jog-speed 0.06
    homing_status :=0
END_IF
Displaying 6211 - 6225 out of 13544 results.
Time to create page: 0.488 seconds
