  • grzester
  • grzester
22 Jan 2026 21:31
Replied by grzester on topic Cia402 no connection
Category: EtherCAT
OK I hope that now is much more clear, thanks.
  • rodw
  • rodw's Avatar
22 Jan 2026 21:27
Replied by rodw on topic Cia402 no connection
Category: EtherCAT
Please revise your post to get rid of the rubbish and lets start again
  • rodw
  • rodw's Avatar
22 Jan 2026 21:25
Replied by rodw on topic How good is Ethercat motion control?
Category: EtherCAT
Hi Rod,
Is there a big difference between using the CiA 402 driver and the also implemented Delta ASDA driver (DEASDA) with Delta drives?
I don't really know. I've always chosen CIA402 devices because they are a known quantity. (eg I'm risk averse) There are some drivers for other hardware which I would include in my list but I have no experience.
  • rodw
  • rodw's Avatar
22 Jan 2026 21:21
Replied by rodw on topic LinuxCNC S-Curve Accelerations
I thought jerk limiting was purely about acceleration. To extend it to varying the path seems to me is really scope creep. Get it working without changing the path and include path optimisations at a future time and write better gcode for now.
jerk limiting may permit higher maximum acceleration. Currently MAX_ACELERATION is set from a combination of motor dynamics and physics by the machine builder Eg the inertia in a heavy moving table may require a lower acceleration than what the motors are capable of so they are not overcome by inertia on deceleration and cause following errors. Its probably valid on a jerk limited machine to increase acceleration. In this context, some violations may be valid.
  • Gogonfa
  • Gogonfa
22 Jan 2026 21:03
Replied by Gogonfa on topic How good is Ethercat motion control?
Category: EtherCAT
Hi Rod,
  • grzester
  • grzester
22 Jan 2026 20:57 - 22 Jan 2026 21:29
Category: EtherCAT
Hallo Hakan, thanks for Your response .I do like You sad but after removing sim files there is another problem like in the picture
 Only for another try i create separate second config, files like .hal , .xml are exactly the same as before., but there is simlar problem like in the picture
My goal for that moment is only confirm that drive is talking to LCNC.Thanks again.
File Name: axis_2026-01-22.ini
File Size:5 KB
File Name: ethercatCA...1-22.hal
File Size:3 KB
File Name: ethercat-c...1-22.xml
File Size:1 KB
  • 5_Zylinder
  • 5_Zylinder
22 Jan 2026 20:39
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
Hello,
It would be very kind and helpful if you could create a bitfile for a 7I97, 7i89, and 7iA0.
Currently, not all 14 encoder inputs are needed; this is just a preparation for glass scales. Currently, the encoder for the handwheel would be connected there.
The 7iA0 is to be connected to the 7i89 via the serial interface.
I managed to establish a connection in the old configuration of 7i97 + 7i74 and 7iA0, and the watchdog was gone. But this configuration no longer exists.
  • DemonClaW
  • DemonClaW
22 Jan 2026 20:24
Replied by DemonClaW on topic Generating a own Popup
Category: Qtvcp
Sure I will let you know about the finished Project
  • cmorley
  • cmorley
22 Jan 2026 20:21
Replied by cmorley on topic Generating a own Popup
Category: Qtvcp
Excellent! Thanks for not giving up.
In this kind of trouble shooting details really matter.
qtdragon is not the same as qtdragon_hd, error messages need to be quoted exactly etc.
When you get everything finished I hope you post a pic of your creation.
  • DemonClaW
  • DemonClaW
22 Jan 2026 20:14
Category: Qtvcp
It worked, i forgot the handler in the /share/ path the Terminallog showed it wanted to load it. After deleting it started with the Button and i can Open the Pop-up too. Thank you very much for your Help and stamina with me
  • cmorley
  • cmorley
22 Jan 2026 19:47
Category: Qtvcp
If you run linuxcnc from a terminal then there should be more information on that error.
it's not enough for me to track it down
  • DemonClaW
  • DemonClaW
22 Jan 2026 19:41
Category: Qtvcp
This is interresting with your files i still get the error message:
AttributeError: 'MainPage' object has no attribute 'PREFS_'
  • cmorley
  • cmorley
22 Jan 2026 19:32
Category: Qtvcp
Ok I edited your handler file - I should have explained how to combine the code.
I didn't remove your popup code but it's not used.
I used your modified qtdragon_hd.ui file
I made a sample vacuum panel based as a mainwindow with just an LED in it.
I confirmed this works on my system
  • PCW
  • PCW's Avatar
22 Jan 2026 19:30
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Category: Driver Boards
At the moment, whether or not "sserial_port_0=0xxxxxxx" is added to the hm2_eth line, all 7i42TA pins behave as GPIO - they can be set/cleared in halshow.
This is expected behaviour: if a sserial device is not found on a particular channel, its I/O pins revert to GPIO
I would be grateful if you could send the firmware for that card including: 6x analogue servo, 6x encoder, 2x pktuart and 2x sserial modules, for 7i80HD-25, 7i48, 7i52 combination.
I'll try and get to this sometime today or tomorrow.
  • DemonClaW
  • DemonClaW
22 Jan 2026 19:21
Category: Qtvcp
OK this worked and we got rid of the type error, if i start i now i get a attribute error: object has no attribute 'PREFS_' , i hope you dont get frustraded with me its all very new for me. I really appreciate your work with me. And it means a lot.
Displaying 7456 - 7470 out of 13542 results.
Time to create page: 0.464 seconds
