  • andrax
  • andrax's Avatar
03 Jan 2026 09:02
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
How can I adjust this?
I searched for this because it seems that other users had the same problem.
It was recommended to set the value HOME_ABSOLUTE_ENCODER = 2 and omit HOME_SEARCH_VEL; HOME_LATCH_VEL.
So I set the following.
HOME = 0.0
FERROR = 1000
MIN_FERROR = 1000
MAX_VELOCITY = 100
MAX_ACCELERATION = 750
MIN_LIMIT = -1800
MAX_LIMIT = 100
HOME_OFFSET = 0.0
# Sequence for homing Start at 0
HOME_SEQUENCE = 0
HOME_SEARCH_VEL            = 1
HOME_LATCH_VEL            = 1
HOME_IGNORE_LIMITS        = YES
CIA402_HOMING_ENABLED = 1
CIA402_HOMING_METHOD=4
CIA402_HOMING_SEARCH_VELOCITY=100000
CIA402_HOMING_LATCH_VELOCITY=50000
CIA402_HOMING_ACCELERATION=131072
This now works for at least one axis, but all the others still malfunction.
  • nanowhat
  • nanowhat
03 Jan 2026 06:12
Replied by nanowhat on topic StepperOnline A6 Servo
Category: EtherCAT
Er87.1 is "One-time excessive position reference increment". It sounds like your drives are trying to move from $home to the last commanded target position in one CSP period.
Try commanding the drive to find home using its CIA402 home method, and immediately (before the homing sequence finishes) set the target position to 0.
  • Thllll
  • Thllll
03 Jan 2026 04:36
Replied by Thllll on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
Absolutely I would like to try it
  • cmorley
  • cmorley
03 Jan 2026 04:05
Replied by cmorley on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
I discovered that the bottom right button is disabled by default.
I didn't notice this as I had a 'hidden' modification to enable it.
It was experimental, that is why it is disabled. I could show you how to enable it, if you wish to try it,
03 Jan 2026 03:27
  • rodw
  • rodw's Avatar
03 Jan 2026 03:24
Is this QTPlasmac Expected behaviour - Cycle Start and Jog disabled.
Category: Plasmac
V2.8 is indeed very reliable but Qtplasmac on 2.8 is not. So many changes since then. In fact there Is a strong case to run 2.10 master branch to get th latest and greatest qtplasmac.
  • freylax
  • freylax
02 Jan 2026 23:44
Dear Oliver,
I got my Setup of RPI5,OlimexICE40EVB working in the test-gui.
(3 stepdir plugins, and some bitinputs) These working all in the test gui.
I did the halcompile step. starting linuxcnc with the created ini configuration.
The linuxcnc app cannot be switched on,
it reports USRMOT: ERROR: command timeout.
I'm a linuxcnc newbe so I would appreciate some hints how I could proceed to get linuxcnc running.
Thank you for your time!
regards Robert
  • spumco
  • spumco
02 Jan 2026 23:22
Replied by spumco on topic Fusion 360 Win 10 EOL
Category: CAD CAM
I will have to look back to see how to do Win11 LTSC.
I bought a W11 Enterprise LTSC (not IOT) from pckeys.uk.  UK distributor.  There are cheaper vendors areound, but I had a good experience when I did 5 or so PC's a few years ago using W10 LTSC.  At the time they were about the only place online where you could buy less than a block of 200 license keys.
I bought the 'euro' version of LTSC which does not have Windows media player or MS store (Windows 11 Enterprise N LTSC).
Most people buy the non-N version.
  • Make a list of hardware (graphics card, chipset, etc) and make sure you can get the drivers from the hardware vendors
  • Download ISO file from MS link provided by pckeys (or other vendor)
  • Burn USB using Rufus
  • Install W11.  You get numerous options during installation (no games, no AI, security stuff, privacy stuff, etc.)
  • Enter license key emailed by vendor.
  • Update any drivers that didn't automatically install
Pretty easy.
02 Jan 2026 21:53
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Tittle changed back to original on request of original poster.
Please do not change the subject tittle when replying.
Thank you.
02 Jan 2026 21:50
Replied by tommylight on topic Retrofitting Deckel FP4ATC
No, Mesa 7i80 does not go with 7i77 and 7i85, the Mesa 7i92TM goes with those. 7i80 is 50 pin, 7i92 is 25/26pin.
There are other options also, the 7i77 is hard to find so a bit more searching is needed, on the 50 pin stuff i can not help, but for 25 pin stuff i used a lot, here are some options:
-7i97T it is roughly the same as 7i92TM with 7i77, with 7i85 or even better with 7i74 as this needs plain LAN cables to wire the 7i70 (48 inputs) and/or 7i71/7i72 (48 outputs sinking or sourcing), or 7i84 (32 in and 16 out)
-7i92TM (notice the M, makes it directly plugable into 7i77 so no need for IDC26 to DB25 cable and adapter), with 7i85 OR 7i74
-7i96S (step/dir and spindle) with 7i83 (analog outputs) and 7i85 (encoder and SSerial) for 7i70/7i71/7i72/7i84
I think there is also 7i93 IRC should have 3 of IDC26 headers, but not sure, should be same as 7i92 with more IO. Again, do double check this.
  • Mbrand1901
  • Mbrand1901
02 Jan 2026 20:26
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
The original contoller (in the control cabinet) has 56 Inputs and 92 Outputs.
I am going to ned an analog Output for the servos and a sin/cos (1 Vpp)u Input for the linear encoders. The servos also have some encoders on them, but these are only for the velocity.
Later i am going to need another analog Output for the spindle.
In my mind i am going to use a mesa 7i80HDT as a base for the daugthercards. For the spindle and the servos a 7i77 and for the linear encoders a 7i85, because that one can read the 1 Vss signal.
For the other I/Os i would use some 7i70‘s and 7i71‘s.
Please correct me, if i am going to make a mistake?
  • Mbrand1901
  • Mbrand1901
02 Jan 2026 19:51 - 02 Jan 2026 19:57
This machine has a Contour 3 controller.
At first i want to move all axis. Then the spindle and at last the toolchanger.
I want to keep the old simens servos with the bosch servocontrolls. I also want to keep the linear Heidenhein encorder. They are still in a good shape and still work.
A list of all the components on the machine i want to keep to move the table:
Heidenhein LS904
Bosch tr15-xa-140-230V
Simens 1HU3071-0AC01-Z
  • cmorley
  • cmorley
02 Jan 2026 18:32
Replied by cmorley on topic Auto Tool Probe - not callable
Category: Qtvcp
Well i guess I should ask is the program prefix (~/home/cnc/linuxcnc/nc_files) a valid path too.
  • cmorley
  • cmorley
02 Jan 2026 18:29 - 02 Jan 2026 18:30
Category: Qtvcp
ok.
I see there two entries for:
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
should only be one entry and they are both wrong. should be:
PROGRAM_PREFIX = ~/home/cnc/linuxcnc/nc_files
I don't think this is the problem bit please fix it anyways,
Then can you run linuxcnc from a terminal, do a MDI tool change and post the terminal output.
  • Mbrand1901
  • Mbrand1901
02 Jan 2026 17:57 - 02 Jan 2026 19:04
Retrofitting Deckel FP4ATC was created by Mbrand1901
Hello!
I currently bought a used Deckel FP4ATC. Now the want to retrofit it. I am going to document my journy and hopefully is going to be successful. It would be nice if someone could help me a bit. Thank you!
Displaying 8281 - 8295 out of 13510 results.
Time to create page: 0.399 seconds
