  • heaven
  • heaven
26 Dec 2025 22:10
Recommend hardware solution for multi rs485 channel?
I have three RS485 devices (each operating at 115200 baud) and one BNO08x IMU, which supports UART at 3,000,000 baud, as well as I2C and SPI.Currently, I am using three USB-to-RS485 adapters and one USB-to-UART adapter to connect these devices. This setup is bulky and inconvenient.I am looking for a more integrated solution, such as a single controller or I/O board, that can communicate with all these devices independently and reduce cabling and USB usage.Any recommendations?
  • NWE
  • NWE's Avatar
26 Dec 2025 21:07
DIY CNC Mill - Random Limit Switch Errors
Category: Milling Machines
I have most of the electronics mounted to a piece of sheet metal, which is connected to main ground by the green/yellow terminal block by the contactor. Should I not do this?
That should be fine. I mount a lot of stuff to DIN rail like that on top of metal plate, seems to me sheet metal should be about the same. I try to keep low voltage DC circuits completely separate from AC circuits. Sometimes it is inconvenient to do so then I run them together a bit like you did. And then sometimes it just doesn't work then I have to separate them.
It seems as soon as there are some electronics directly connected to a PC's parallel port or PCIe slots a bit like these BOBs work, things get a lot more sensitive. Lately I've been using mostly ethernet connected 'BOBs' Mesa electronics or Beckhoff etherCAT because I rarely have interference troubles with those. (ethernet has very good isolation)
I used a BOB some years ago on a cnc plasma cutting table retrofit, I was happy with it. I probably went to the extreme shielding that BOB. Mounted it inside a die cast aluminum box that cost more than the BOB. All shielded cords to the die cast box, and no AC power into it. You should not need to go to that extreme. Plasma cutters make more interference than most VFDs.
  • tar_san
  • tar_san
26 Dec 2025 20:44 - 26 Dec 2025 20:56
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
Thank you so much.
Result:
A12 Servo driver alarm has vanished.
I could "ServoOn", "Jog move". without any error in Servo Driver LED.
Buf I got this  message "Failed to get reference clock time: Input / Output error"  many times. (screenshot)
I attached dmesg log.
But you see automata's posts here? Do not be surprised if it still does not work.
Thankfully, automata has kindly posted the solution here.
Please report back how it goes and if there are problems with lcec
I hope automata will guide you to use his solution.
Thanks, I will report back as much as I can for a while.  ( I'm borrowing Yaskawa-Sigma-X motors for just a few weeks)
But I'm not familier about EtherCAT master, I'm not sure what to do next, so please guide me, everyone
And I'd like to summerize procedures what I have done with your great help to get Yaskawa worked with LinuxCNC for those who are not so familier with EtherCAT master in detail like me.
  • NWE
  • NWE's Avatar
26 Dec 2025 20:42
A couple years ago I bought two BOBs and never did anything with them. Just now dug them out for a closer look. So I have two different BOBs, both look different from yours. It seems to me, if your BOB had a ground screw that had direct connection to the metal shell of the parallel cable, that would be a prime location to connect the shields of any cables connected to the BOB. That is what I am referring to as frame ground.
  • sorokin_pro
  • sorokin_pro's Avatar
26 Dec 2025 18:43
Replied by sorokin_pro on topic Mesa 6i25 not working?
Category: Driver Boards
That's really odd
You are not running as root are you?
is this a normal Linux installation?
What does
uname -a
report?
user@denc:~$ uname -a
Linux denc 6.12.57+deb13-rt-amd64 #1 SMP PREEMPT_RT Debian 6.12.57-1 (2025-11-05) x86_64 GNU/Linux
This is a fresh installation from LinuxCNC website.
But I downloaded  www.linuxcnc.org/iso/linuxcnc_2.9.7-amd64.hybrid.iso instead of provided  www.linuxcnc.org/iso/linuxcnc_2.9.4-amd64.hybrid.iso  by replacing 4 with 7 in the URL.
I am NOT running as root, because other commands require sudo.
  • PCW
  • PCW's Avatar
26 Dec 2025 18:21
Replied by PCW on topic Mesa 6i25 not working?
That's really odd
What does
uname -a
report?
  • NWE
  • NWE's Avatar
26 Dec 2025 18:03
Connecting all grounds to the buss bar sounds great.
One way to track down redundant grounds is to disconnect the known grounds then take an ohm reading to find out whether it is still connected to ground via an unexpected route.
Like I said, you can cheat some. I am not real strict on my projects about having no redundant grounds, but it is one of the things I work on if there are interference problems.
In your case, I would suggest concentrating on the shield grounds right at the BOB as that seems to be a pain point what with it acting up as soon as you so much as connect stepper signals and start the vfd.
Please, did you try moving those AC wires that are parallel to the BOB and within inches of it?
  • tlightus
  • tlightus
26 Dec 2025 17:59
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
thank you for testing. i have been getting a very different result but will go back and see if it was something i was doing wrong.
  • sorokin_pro
26 Dec 2025 17:55
What version of mesaflash do you have?
user@denc:~$ mesaflash --version
Mesaflash version 3.5.11
No warnings without sudo.
  • MaHa
  • MaHa
26 Dec 2025 17:32
I was just working on a mdi command, so it was easy to have a look at this in FlexGui.
Starting with  G0G55X0Y0
Then pressing the button with MDI command
and it goes to    G0G54X0Y0
the subroutine:
o<work_zero> sub
G90 G54 G0 X0 Y0
o<work_zero> endsub [1]
M2
  • sorokin_pro
26 Dec 2025 17:27
5i25 is not 5I25
Linux is case sensitive.
Here is a piece of code from mesaflash:
access.device_name[i] = toupper(access.device_name[i]);
Device names are converted to upper case automatically.
  • dann1324
  • dann1324
26 Dec 2025 16:57
7c81 + 7i73 was created by dann1324
7c81 + 7i73
Hello all! I'm new here on the forum, I've been searching for a day or so now and can't really seem to figure this out. I've been using the machine with a rpi4, with the 7c81 running the 5abobx2 bitfile setup for a little while now and decided to expand with the 7i73. From what I've read, when using pncconf I should see the 7i73 or at least a way to set pins on the smart serial interface, right? So far, it never seems to show up. I have it connected to the 7c81 via a cat6 cable, and I have a power light on the 7i73. I've set the jumpers on the 7i73 to all the default locations (terminated serial, no lcd, no keypad). when using mesaflash to check the config of the 7c81, I can see the smart serial interface. I feel like there's something very simple I'm missing. I hope this isn't a repeat question, I couldn't find it here. I appreciate any help you can offer
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 64 bytes
26 Dec 2025 16:53
Replied by tommylight on topic Mesa 6i25 not working?
user@denc:~$ sudo mesaflash --device 5I25
i
is not
I
5i25 is not 5I25
  • zippoffs
  • zippoffs's Avatar
26 Dec 2025 16:47
Replied by zippoffs on topic DIY CNC Mill - Random Limit Switch Errors
Wow, that's a lot to take in. I may have a ground loop to the machine frame. There is a ground wire in the spindle cable that is grounded to the motor frame, which is in contact with the rest of the mill. But I also do have a ground wire on the frame going to the ground bus in the breaker box. I will remove that.
There is continuity from the BOB end of the parallel cable to the PC when the PC power is disconnected, so it probably is shielded.
I currently have all the grounds and shielding grounds running to the ground bus in the breaker box. Are you saying this is causing issues? What would be the BOB's frame ground?
  • PCW
  • PCW's Avatar
26 Dec 2025 16:46
Do get a warning when not using sudo?
If not, something really basic is broken here.
pcw@pcw-HP-Compaq-Elite-8300-USDT:~$ mesaflash --device 5i25
You need root privileges (or setuid root) to access PCI hardware
No 5I25 board found
Displaying 9721 - 9735 out of 11221 results.
Time to create page: 0.322 seconds
