10 years 5 months ago #74524 by lexxa
Replied by lexxa on topic Gmoccapy - A new screen for linuxcnc
Dear...
Do you use momentary switches?
Yes, I am use a momentary switches for all spindle button.
I'll try
PB spindle forward halui.spindle.forward ------------| |-----------------------------------------------------------( )---------- | | | h.sp.fwd h.sp.stop h.sp.rev | |------| |-----------------| / |-------------| / |-------------| etc
Or do you refer to the F value in active gcode?
Yes, I refer F value in active G-code. Value F in "feeed override" is coorect with override value.
Sorry for my English...
10 years 2 months ago #79100 by sxyuklad
Replied by sxyuklad on topic Gmoccapy - A new screen for linuxcnc
I tried to change GUI but no success. It gives me a bunch of errors, please see attached file for error log. Can please someone point me out what I am doing wrong?
I did change my settings in my INI file as described in the following documentation link under display section:
linuxcnc.org/docs/html/gui/gmoccapy.html
And the settings I set:
[DISPLAY]
DISPLAY = gmoccapy
PREFERENCE_FILE_PATH = gmoccapy_preferences
DEFAULT_LINEAR_VELOCITY = 166.666
MAX_LINEAR_VELOCITY = 166.666
MAX_FEED_OVERRIDE = 1.5
MAX_SPINDLE_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
LATHE = 1
BACK_TOOL_LATHE = 1
PROGRAM_PREFIX = ../../nc_files/
But that is the only thing I changed believing settings only will do the whole job, no file copying, no installation or anything else. Am I doing it correct or I need to copy past some file in my config/turn folder or need to install anything extra?
Please help me out looking at the error log. Error log link:
forum.linuxcnc.org/media/kunena/attachme...82/gmoccapyerror.txt
10 years 2 months ago - 10 years 2 months ago #79102 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
custom_postgui.hal:15: Pin 'pyvcp.spindle-speed' does not exist
You have connections to a pyvcp panel, that will not work with gmoccapy.
Just comment everythink related to pyvcp out and restart the GUI.
Norbert
Later connect the spindle speed to the related gmoccapy hal pin.
Last edit: 10 years 2 months ago by newbynobi.
10 years 2 months ago #79126 by sxyuklad
Thank you for your quick reply sir.
But I do want the gmoccapy to show my spindle speed. On top of that I also have a an ATC comp link.
I am attaching my config folder. Can you please have a quick look at my files and let me know where and how to connect my which pins to qhich gmocappy signals?
10 years 2 months ago #79127 by sxyuklad
Please excuse my ignorance, I am like only a week older to linuxcnc.
10 years 2 months ago - 10 years 2 months ago #79142 by newbynobi
Only three changes needed ;-)
Iin the INI changed DISPLAY = axis to DISPLAY = gmoccapy
In the postgui hal file
the pyVCP connections to match the gmoccapy hal pins
from documentation :
5.9. Spindle Feedback Pins
There are two pins for spindle feedback
gmoccapy.spindle_feedback_bar
gmoccapy.spindle_at_speed_led
gmoccapy.spindle_feedback_bar will accept an float input to show the spindle speed.
gmoccapy.spindle_at_speed_led is an bit-pin to lit the GUI led if spindle is at speed.
But I deleted also unneeded files and some useless entries in your INI File.
Just copy the zip to your config folder (Not in your existing one !)
Uncompress it and start it, report if it works (it should )
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.778 seconds
